Question about Bernina Virtuosa 150
No power on foot pedal
I have a Bernina 153 QE and it was running great, until....I went to change the bobbin and the "bobbin assembly" came out once I got the whole assembly in place, I went to sew. Although my machine lights up and appears to have power the foot pedal won't make the machine run. I was told to check the bobbiin winder and that seems to be in the "off" position, so I don't know what else to check. I have double checked and the foot pedal cord is plugged into the machine. Any suggestions would be helpful.
  • 202 Answers
There is no way to change brushes on theses sealed motors and I highly doubt thats the issue. Most likely you didn't put the bobbinwinder back togeather correctly. The small spring type clip under it needs to be in the second notch of the teeth below the bobbinwinder to engage/disengage right. If you had the cover off its also possible you disconnected the wire to the circuitboard for the footcontrol, I beleive its black and red. Probably best for a tech to look at it.
Posted on Dec 01, 2008
My bernina 150 QE will not stitch. It has power but I press on the foot pedal and it just hums.
Check to see if your machine is set to load bobbins. Also, check to make sure that your feed dogs are set to the upper (on) position.
May 28, 2017 | Bernina Sewing Machines
Please supply a WORKING LINK for the Bernina Vertuosa 155 Owners manual PLEASE PLEASE
The manual is not available on Bernina's web site. So far, the only thing I've found is the Bernina Owner's Workbook (for several Berninas including the Virtuosa) that may be helpful:
https://www.google.com/url?sa=t&rct=j&q=&esrc=s&source=web&cd=10&ved=0ahUKEwjGs4PZjKXRAhXlllQKHfR_BnAQFghSMAk&url=https%3A%2F%2Fsiterepository.s3.amazonaws.com%2F01182201109290548032081.pdf&usg=AFQjCNFjtpMlQlwF0PF3JJ0c6pcJSiGiyg&cad=rja
or
https://www.manualslib.com/manual/803468/Bernina-Virtuosa-153-Qe.html#manual
You may also try checking out some Yahoo Bernina Groups. You'll need a Yahoo email account, then search the Bernina Groups, and request admission. From there, you can post your questions as well as view the various documents that have been stored. Some groups have great manual libraries and very knowledgeable, helpful individuals.
Jan 03, 2017 | Bernina Sewing Machines
Could a missing bobbin case keep a Bernina 1000 from running? It turns on, and the hand dial works, but foot pedal doesn't run the machine
no a bobbin case won't keep it from running, there may be a problem with the foot control, or the plug that you plug the foot pedal into may have a problem, may need to have the machine check along with the foot pedal
Mar 18, 2016 | Bernina Sewing Machines
430 aurora
Probably too thick to feed without dislodging the bobbin case, causing the error message.
May 07, 2013 | Bernina Activa 140
Bobbin thread tangling into knots on my Bernina QE 153
Its possible, refer to your machine manual to adjust the tension. You might need to change your needle to fit the thread you are using.
Feb 01, 2013 | Bernina Virtuosa 150
Bernine 153 QE motor sometimes does not respond to foot pedal
If its not the footcontrol (which it probably is) it is most likely the circuitboard acting up. Needs a tech.
Jan 24, 2009 | Bernina Virtuosa 150
Bernina Virtuosa 153 QE is jammed.
Where do you live in China? I'm in Hong Kong and have visited that dealer.
Jan 04, 2009 | Bernina Activa 130
Sewing Machines Logo
220 people viewed this question
Top Bernina Sewing Machines Experts
Tally Girl
Tally Girl
jnissen
Level 1 Expert
Chris Wetmore
Are you a Bernina Sewing Machine Expert? Answer questions, earn points and help others
