Question about Sony Cybershot S650 Digital Camera
Will the memory stick work with
Will the memory stick pro duo work with a vista and if so where do i put it?? im barrowing the camera from a friend and i dont know where to put the memory stick.
  • 56 Answers
Yes make sure its atleast a 1 gb sticlk though
Posted on Dec 20, 2008
Camera keeps telling me to reinsert the memory card. I've tried to new cards. When I put the memory card I was replacing because it is full, it goes back into the camera just fine.
As a last resort you could copy the full card to a computer and then delete the pictures on the card and use that again.
Here is the error list from the camera manual.
This is all I can suggest from here.
"Reinsert the Memory Stick Error"
Insert the "Memory Stick Duo" correctly.
The inserted "Memory Stick Duo"cannot be used in your camera
(See below).
The "Memory Stick Duo" is damaged.
The terminal section of the "Memory Stick Duo" is dirty
Compatible cards.
Memory Stick Duo (without MagicGate)
Memory Stick Duo (with MagicGate) *1 *2
MagicGate Memory Stick Duo *1
Memory Stick PRO Duo *1 *2
NOT compatible
Memory Stick (without MagicGate)
Memory Stick (with MagicGate)
Memory Stick PRO
Some Memory Stick Duo have a write protect switch on the back.
You cannot record, edit or delete images if you
slide the write-protect switch to LOCK with a
fine-tipped object
*1
"Memory Stick Duo", "MagicGate Memory
Stick Duo" and "Memory Stick PRO Duo" are
equipped with MagicGate functions.
MagicGate is copyright protection technology
that uses encryption technology. Data
recording/playback th
at requires MagicGate
functions cannot be performed with this
camera.
*2
Supports high-speed data transfer using a
parallel interface.
Oct 12, 2014 | Sony Cybershot S650 Digital Camera
Memory Stick Pro Duo with adapter not compatible with the camera
I am so sorry my friend, you have same problem as we all have, no memory bigger that 1 gb will work in cameras older than 3 years, I think yours is yes? the camera simply does not see those, sad I know, but that is how it is, I know because I have 3, yes 3 adaptors and 3 big mem bits here, and my money is lost.
David
Suffolk
Jun 12, 2010 | Sony Handycam DCR-TRV22E Mini DV Digital...
Plz help me!
sony is for sony, reformat it
Mar 25, 2010 | Sony 4GB Memory Stick PRO Duo Memory Card
Sandisc 4 GB memory stick PRO Duo not working
According to the users manual, the camera does not support above 512 MB cards, however I noticed that there is a firmware update which might address the issue. Go to www.sony.com and support, electronics. Put your model number in the selection box and you'll be taken to the drivers download page.
Feb 14, 2010 | Sony Cyber-Shot DSC-T1 Digital Camera
I have a Memory Stick Pro Duo 8GB will not open on my computer or camera..was working then quit. Advice please
Problem for Sony Memory Stick PRO Duo (2GB) for PSP I have a Memory Stick Pro Duo 2GB will not open on pc &also not formated
Jan 02, 2010 | Sony Memory Stick PRO Duo (2GB) for PSP
How to repair a memory stick duo turn that to raw
Put memory stick in camera and format it, this is the only way to fix some problem in memory stick.
If that does not help, memory stick got hardware problem that is irreparable. Buy new memory stick then.
Thanks.
Nov 05, 2009 | Sony 1GB Memory Stick PRO Duo Memory Card
SanDisk memory stick pro duo 4GB not reading
does ur camera recognize ur mem stick if yes then copy all ur pics to a computer then format it an insert the stick to ur cam and u can copu it again to the stick. check it out.
Oct 13, 2009 | SanDisk 4GB Memory Stick PRO Duo Memory...
MY PROBLEM IS THAT MY LAPTOP HAS WINDOW VISTA SYSTEM AND I CANNOT LOAD MY PHOTOS FROM MY SONY CYBERSHOT DSC P73. I NEED THE PROGRAM OR WHAT I NEED TO DO?
To make things easier, you should buy a card reader. There are different types.
MS Pro Card Reader - Is ONLY for the sony memory cards
Multi Card Reader - Will read sD, xD, Ms Pro Duo, Ms Pro, Compact Flash, Smart Media, etc.
Sony has a new memory stick out called the memory stick pro duo. Your P73 does not take this. The P73 takes the Memory Stick Pro. Which is a longer stick. You can go out to best buy or ritz camera and buy a card reader (Memory Stick Pro) and stick your memory card into the card reader and stick that into your USB port on your computer. Since it is USB, this will require NO SOFTWARE.
Your camera came out in 2004. Vista did not come out until early 2007. A lot of software does not work with vista.
Mar 29, 2009 | Sony Cyber-Shot DSC-P73 Digital Camera
Maximum Memory Stick size I can put into my Sony DSC-N1
Unfortunately, there is no way to change the internal card reader in the camera to accept higher density memory cards. You can find the memory stick compatibility list here: https://esupport.sony.com/perl/support-info.pl?&info_id=12 . Scroll down to the Cybershot N Series camera list. The maximum capacity memory stick is 4 GB memory stick pro or M2 Memory stick Pro. For the Memory Stick Duo, it looks like those have a maximum capacity of 2 GB.
I hope this helps.
Apr 14, 2017 | Sony Cyber-shot DSC-N1 Digital Camera
Pro duo memory
Well, maybe you've putted the memory stick upside down or something. Sorry, i have any other solution. But you can still use the 31 mb intern memory :S.
Nov 13, 2007 | Sony Cyber-shot DSC-H7 Digital Camera
Sony Cybershot S650 Digital Camera Logo
21 people viewed this question
Top Sony Cameras Experts
james laughton
james laughton
JonSnell Electronic
JonSnell Electronic
Are you a Sony Camera Expert? Answer questions, earn points and help others
