Question about Brother MFC-8440 All-In-One Laser Printer
Hello,to print it's ok,because i just changed the ink,but when i try to print from my computer exemple word or my paie programme well it prints very very pale when i fax well the writing is so pale people cannot read it. please help.thanks
    Sergeant:
  • 291 Answers
The print out is pale because the print quality is on draft mode.make it to normal mode to get dark copy.or make it to best mode to get even extra dark copy.you can check out the print quality option in the printer properties.
Posted on Nov 28, 2008
    Genius:
  • 2,035 Answers
Follow the step listed below for cleaning the laser glass:
1. Turn off the power switch and open the front cover.
2. Lift the drum unit slightly and pull it out. Place the drum unit on a
drop cloth or large piece of disposable paper to avoid spilling and scattering the toner.
3.With the drum removed from the machine, clean the laser glass with a
DRY cloth. The laser glass is located on the roof inside in the machine
where the drum unit is installed. DO NOT use isopropyl alcohol or any
liquid to clean the glass
4. Remove the toner cartridge from the drum by holding down the lock
lever (purple tab) on the right side of the drum unit and lift the toner
out.
*Handle the toner cartridge carefully. If toner scatters on your hands
or clothes, immediately wipe it off and wash with cold water.
5. Gently rock the toner cartridge from side to side five or six times
to distribute the toner evenly inside the cartridge. Then, reset the
toner into the drum (be sure it clicks into place).
6. Reset drum unit in the machine.
7. Close the front cover, pressing firmly on each side until the cover
clicks into place..
Then try to print ,Is this original brother cart...
  • 1,879 Answers
Remove the toner and gently tip side to side (this is posted under LASER printers right) and re-install it.
reset printer settings then do a copy.
  • 162 Answers
Perform head cleaning at 3x consecutively
  • 94 Answers
  1. Select File menu and then Print... to open the print dialog.
  2. Press Properties button and then select Print Quality tab in the dialog.
  3. Make sure the resolution is set to Fine.
Posted on Nov 24, 2008
    Sergeant:
    Champion:
  • 435 Answers
Hi, Did you try increasing the print quality in the printer settings before you print.
Increase the dpi or select high quality/ fine print.
    Genius:
  • 1,550 Answers
Check whether you have placed the cartridge properly .
If it is not seated properly you will face problem like this .
  • SAM ANDERSON Nov 25, 2008
    Clean the rollers, reinsert the ink cartridges and reset the
    printer. Take a test page to ensure that everything works fine .
    If you still have problem remove the print head and check the base
    whether it is clogged with ink. Clean it and place it properly and
    plug back the power chord to printer and take a test page .
    This will solve your problem .
MX360 won't print in color
Use the machines programme to clean the ink jets
Mar 01, 2016 | Canon PIXMA Office Equipment & Supplies
Lexmark x7170 changed ink cartridge. test sheet comes up great, print something and it says ink low. i tried to shut off 5x's to maybe reset/ reinstalled ink cartridges same message. cleaned heads
The Lexmark x7170 should let you continue printing with the ink cartridge regardless of the estimated ink with most cartridges. The only exception to this is if the cartridges are part of Lexmark's returns programme. I would advise removing the cartridge and checking for small text stating "Return Programme Cartridge" on the label. If this is present sadly there is no way of continuing, apart from buying a new cartridge.
With regards to the low ink estimate, am I right in assuming you are using a refilled or remanufactured ink cartridge? If so this is unavoidable but should not prevent you from printing until the ink physically runs out.
Nov 29, 2012 | Lexmark X7170 All-In-One Scan/Copy/Fax and...
Black colour is not printing
When you print in color is does it show black ink?
Sep 23, 2010 | Office Equipment & Supplies
Printer is not printing
hello...........
It seems this is a problem of ink.....
Try to get a new cartrage................
If that is ok then check the driver whether it is install or not.............
If that dont work let me know ill give you detailed instruction .........
happy computing
Jun 21, 2010 | HP LaserJet 1020 Printer
Just changed the yellow cartridge. The printer says it's full. No ink. Same thing with last cartridge. Tried deep cleaning.
Ok I understand the printer says its full but are you saying your computer says no ink? or that it prints no yellow ink?
Ok assuming you mean that it prints no yellow ink, the culprit ususally means that the print head needs replacing! Call Canon with your model and you can buy the part for new print heads for your printer
Mar 16, 2010 | Canon PIXMA iP4200 InkJet Photo Printer
My black ink will not print. If I change the colour, it prints find. It is a new cartridge.
First you need to ensure that this is not a driver problem, by reinstalling drivers and testing the printer on a different computer.
Also ensure that ink cartridges are OK, try replacement inks.
If the problem is not a software problem, and the printer is recognised by computer, and the printout is coming as a blank or faded page, then you usually have a faulty or clogged printhead.
Try first performing print head cleaning procedure from printer tools, that may not fix the problem, but do the cleaning a couple of times, just in case.
If the print head is clogged, that can be fixed soaking the print head in isopropyl alcohol overnight.
If still no luck, then the printhead must be replaced, here is the part: Canon MULTI-PASS F-80 Print Head $61.00
Apr 26, 2009 | Canon MultiPASS F80 All-In-One InkJet...
After changing the blank ink cartridge a test print was done. Now every time I switch the printer on to print a page I get another test print page before i can print what I need to print. This is stressful...
hi my name is pete and hope you are not stressing out to much here how you fix your printer when you change a blank ink carriage and stop printing off test prints you will notice on the back of the inks theres a chip something like what you would find on a visa card now the printer uses these chips to reconise the carriages are there so the ink will work now unplug the printer from the computer and switch off the printer from the mains leave for 10 minutes so it can reset the inks for you after doing so plug the printer back in but dont plug into computer yet let the printer set it self up when ready plug back in to computer open programme you use and find out if the test page is on or got a tick on it if so click it off and then try to print anymore problems let me know
Oct 06, 2008 | HP Office Equipment & Supplies
CANON S9000 won't print in black
Here's what just fixed mine... I was having the same issue...
Mac:
Go to System Preferences
Open Print & Fax
Select your printer and open Print Queue
Click Utility
Select your printer & click Maintenance
Select the "Deep Cleaning"
That worked for my black ink!
Aug 09, 2008 | Office Equipment & Supplies
Brother DCP-115C
good chance....Print head is blocked very common, what sort of inks were used?
 Not economical to repair, buy new!
Oct 19, 2007 | Brother DCP 115C All-In-One InkJet Printer
Canon bjc-80 - no print appears but cartridge & paper move normally
I had this problem too. It turned out there was old dry ink in there clogging up the printerhead and it was fixed after I ran the cleaning programme several times. However I can't for the lifeof me remember how to do that now. I know I found it online but it has since vanished. Maybe check your manual?
Nov 12, 2006 | Canon BJC 80 InkJet Printer
Brother MFC-8440 All-In-One Laser Printer Logo
32 people viewed this question
James Cagle
James Cagle
Samyfam
Samyfam
Jim Keysor
