Question about Krups 296 ProChef Ultra 1500 Watts Toaster Oven with Convection Cooking
Krups 296 Toaster Oven will not heat
The red light goes on but the coils will not heat.
  • Anonymous Mar 20, 2014
    The red light comes on but the oven has no heat.
    Can it be repaired?
Fusible link inside the unit is probably broken.
Posted on Jul 21, 2009
Where can i get a diagram of a Krups FBC412?
Maybe Krups can provide the diagram if you inquire.
Aug 20, 2016 | Krups FBC412 1600 Watts Toaster Oven with...
I need a Manual for a Krups Counter Convection Oven
Krups has one manual for the FBC2, FBC3 and FBC4 models. Start here: and use the drop-down menu on the left to select Toaster Ovens. Then select the FBC2. Click on the green and black icon to download the manual. The direct link to the manual is . The manual is also available here: . You can also get this manual from the Krups FBC2 product page: . Click on the Instructions link.
I hope this helps.
Jul 27, 2016 | Krups FBC4 1600 Watts Toaster Oven with...
My Krups FBC 1 toaster oven has a broken spring for the glass door.
Most of the time a hardware store will have a variety of springs or try home depot.
That's if you only don't want to wait for a manufactors spring.
Dec 19, 2010 | Krups FBC1 1600 Watts Toaster Oven with...
Toaster not heating high enough
either the high voltage regulator is failing (you can test with voltmeter) Or the heating element is bad. You can test power to element.
Oct 24, 2009 | Krups FBC112 1600 Watts Toaster Oven with...
Light turns on, but no heating.
Pull apart again. you will see leads insulated with cloth-like insulation. feel for a bulge or two - usually a fuse is hidden in one of those insulations. Find it test it for continuity. If flown, cut it out, replace or just short out that connection.
Jul 21, 2009 | Krups 296 ProChef Ultra 1500 Watts Toaster...
The heat element doesn't go on
FInd the break in the heater eliment and twish it bac together. It will then work again for a while.
Jun 29, 2009 | Krups FBC1 1600 Watts Toaster Oven with...
Quartz heating elements problem in Krups toaster oven
you can touch the element but be carefull the glass is thin .... so scrape it and do what you can . THEN USE A COTTON BALL AND ALCOHOL and clean the element that will get rid of the oil you left behind ,you will be fine ......Please if this answer helped , please rate this 3 or 4 stars . and keep me in the paid answer department . A 1 or 2 may knock me down into the unpaid ranks. Thanks Cactus Bob
Mar 02, 2009 | Krups FBC2 1600 Watts Toaster Oven with...
Krups Toaster Oven elements stopped heating up
this is all to common . what thought happend did happen . the control board went bad and the elements where stuck on . inside there is a thermal fuse ,it blew out and saved you from haveing a fire but now the oven is dead . if you replaced the fuse it would just do it again and the board cannot be bought so your out of luck . on your next oven stay away from electronic controls . i am shocked you got 3 years out if it ,most go bad mutch sooner
Feb 26, 2009 | Krups FBC1 1600 Watts Toaster Oven with...
Krups fbc2 toaster oven cuts off while toasting
returned it to vendor and asked for exchange.  decided no way I should fix it after less than 5 days of use.  Curious if others have encountered a similar problem.
Sep 27, 2008 | Krups FBC112 1600 Watts Toaster Oven with...
Krups 296 ProChef Ultra 1500 Watts Toaster Oven with Convection Cooking Logo
573 people viewed this question
Top Krups Toaster Ovens Experts
Tom Chichester
Are you a Krups Toaster Oven Expert? Answer questions, earn points and help others
