Question about Sony KDS-60A2000 60" HDTV
Sony Lamp Cycles Off and On
Recently, the projection lamp on my Sony KDS-60A2000 began to shut itself off then turn back on for no apparent reason. This problem is not source specific. It occurred while watching basic cable TV, DVD and gaming.
The sound is still there, but not the picture.
  • 2 more comments
  • RM30 Dec 04, 2008
    exactly the same problem--sony support is not helpful
    wondered if the lamp is going--anyone try replacing lamp to fix this problem?
  • Anonymous Dec 27, 2008
    same problem for the last month or so, tv turns on fine but after a few minutes the picture goes black, the sound is still there but there is no picture, after 10 or 30 seconds the picture comes back up, this repeats itself every few minutes...any solutions?
  • luptak Jan 07, 2009
    my KDS-55A2020 just started doing the same thing. Some days works, some days picture off then on a few times then works fine, some times cycles for hours, about 50 seconds on, 36 seconds off. I cleaned the back which was quite dusty and worked fine the first day then started to cycle again today.
  • bswendorf Jan 10, 2009
    Same problem here. It's gotten to the point of being ridiculous now. Picture is on for less than a minute and then off for two minutes. Then the cycle repeats. Sound is fine. And no flashing lights.
  • 24 Answers
Bad lamp>replace lamp and reset timer in customer menu .Common problem with SOny.
Posted on Jan 10, 2009
Sony KDS-60A2000 - no sound.
If you are lucky, a new lamp will restore the sound as well otherwise you may require a new ballast unit as when the lamps explode, the supply board sometimes destroys itself.
Mar 19, 2014 | Sony KDS-60A2000 60" HDTV
Sony kds-r60xbr2 power wont come on and hte power led is blinking red 5 times
The 5 blinks is indicating the lamp ballast needs replacement your model uses the Sony lamp Ballast 147401211 for sony models KDF42E2000, KDS-50A2000, KDS-50A2010, KDS-55A200, KDS-60A2000, KDS-60A2010, & KDS-60XBR2 amd LDS-R60XBR2
Which is available at the bottom of the page at the following link. The ballast comes with installation instructions,
Aug 04, 2012 | Sony KDS-R60XBR2 Television
Sony kds-60a2000 power light flashes 5 times, no picture
5 flashes - Lamp Driver - (lamp driver faulty)
This is the error code that usually means the ballast (it is the power supply for the lamp) is bad.
Apr 20, 2012 | Sony KDS-60A2000 60" HDTV
How to reset sony tv KDS.60A2000 after replacing lamp so the warning doesn't keep coming on
With the set turned off:
When replacing the lamp, use the following to reset the lamp time.
1. If the Self-Diagnostic screen is already displayed, proceed to step 4.
If not, Power off (Set to Standby mode).
2. Press DISPLAY Channel 5 Sound Volume -
3. To access the Lamp reset, press 5 until the TIME category displays.
4. Press 1 until the RSET item displays.
Mar 01, 2012 | Sony KDS-60A2000 60" HDTV
My sony is turning on and off when I turn it on. The picture and sound appear and disappear. What is wrong and do you have the part..
The most common cause of picture disappearing and returning in a Sony LCD Rear Projection TV is a faulty bulb. Replacing the bulb is the first step in troubleshooting this type of problem in KDS-60A2000 and all other Sony Rear Projection LCD TVs.
Sony Lamp Gallery
shows all Models and Lamps for Sony Rear Projection LCD TVs. KDS-60A2000 uses XL-5200U Lamp.
May 06, 2011 | Sony KDS-60A2000 60" HDTV
3 times red light blinking indicates that Lamp Cover has not been fixed in its location properly after lamp replacement.
Please make sure lamp cover (its first thing that was removed to replace lamp) is installed securely.
Mar 11, 2011 | Sony KDS-60A2000 60" HDTV
Sony rear projection tv picture going on and off
change the lamp is is too weak to operate properly.
Sep 20, 2009 | Sony KDS-60A2000 60" HDTV
Sony model kds-55a2000
Go to
Jun 11, 2009 | Sony KDS-60A2000 60" HDTV
Sony kds-r50xbr1 turns itself off and then green light blinks 52
I too have a Sony KDS-R60XBR1 tv and the issue that you are experiencing is due to one of your fans in the rear of the tv is not working.  The tv automatically shuts off in protective mode.  Make sure the POWER/STANDBY light is blinking and not the lamp light below it.  Is the power/standby blinking 4 times in red? If, yes then its a fan that needs to be replaced.  If its the lamp light blinking then you need to replace the lamp.  The lamp is easy to replace by ordering the lamp either from Sony for $250 or find it cheaper for approx. $150 from other DLP sources and replace youself by following your manual.  I hope this helps you.
Apr 22, 2009 | Sony KDS-R50XBR1 50" HDTV
No picture, but sound - Lamp shuts off and on intermittingly
Replace lamp and reset timer in customer menu.Common problem with SOny.
Jun 29, 2008 | Sony KDS-60A2000 60" HDTV
Sony KDS-60A2000 60" HDTV Logo
143 people viewed this question
Top Sony Televison & Video Experts
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
