Question about Frigidaire 30" Self-Cleaning Freestanding Electric Range - White-on-White
Self-cleaning heat stains on the front facing panel
I have the Frigidaire self-cleaning white-on-white oven. I like it and have not had any trouble with the door, broiler, clock, etc. However, the last TWO times I used the self cleaning cycle ( I always do the 2 hr) the front panel gets brown heat stains on the enamel right outside of where the vents are. Nothing takes them off. So now the front of my stove has these two carmel colored streaks on the outside.
Help! Has anyone else had this happen? I line the bottom of my stove with Aluminum foil and my oven is very clean. I really wouldn't even have to use the cycle. I am a neat freak so my oven is not gross. The glass on the front is stained also. Do I have to take the door apart to clean that? Thanks for your help and reply!!
Mary
Minnesota 11/24/08
  • dougballard Dec 14, 2008
    I have the same exact problem - it had never happened until we used the self cleaning cycle recently. There must be some way to get this off.
    Scholar:
  • 145 Answers
Use DeBruce polish. We Use Debruce Polish on all our cooktops and ENAMELED SURFACES. Debruce also works on stainless steel polished granite, marble, porcelain, formica and glass. DeBruce is non-toxic odor-less and eco-friendly. You can get DeBruce on line at debrucepolish.com.
Posted on Aug 24, 2009
  • Bruce
    Bruce Aug 24, 2009
    Use DeBruce Polish on the glass also!
The oven door wont release after self cleaning
Check to see if a spill has glued the door shut from the heat of the cleaning. Remove it with oven cleaner. Some devices have a timer that waits for a while before releasing the door. I had a front load washer that did that, very exasperating.
Sep 24, 2011 | Frigidaire 30" Self-Cleaning Freestanding...
Frigidaire free standing, electric, self cleaning oven
Before you go working too hard to get you oven to go into the self clean mode....check out this tip...
http://www.fixya.com/support/r3969401-self_cleaning_oven_problem http://www.fixya.com/support/r4511800-oven_problems_electric_oven_heating
heatman101
" Wish I had read this first. I never would have used the self cleaning option. Thanks for the info!! "
Apr 18, 2010 | Frigidaire 30" Self-Cleaning Freestanding...
Model FEFL78CBC frigidaire oven bottom (bake) burner won't work everything else works fine --even broiler element works fine. Just used self-cleaning cycle, which did work. Next morning oven won't heat ....
We had the same thing happen and now they came and said it was the clock that needs to be replaced. They said that controls the oven. Even though clock is on and working the function for turning on the oven is not
Nov 28, 2009 | Frigidaire 30" Self-Cleaning Freestanding...
Aft self-cleaning, top of oven door and knob panel discolored
This is a problem with a bad door gasket, or a mis-adjusted latch. That needs to be addressed, then you can replace the discolored parts. The discoloration is permanent.
Oct 24, 2017 | Frigidaire 30" Self-Cleaning Freestanding...
Oven wont heat
This may be a control panel issue. i would also check the glow ignition as well , assuming it is a gas range.
Feb 11, 2009 | Frigidaire 30" Self-Cleaning Freestanding...
Frigidaire oven overheating
I would say that the oven thermostat is malfunctioning, and you will probably need a new one fitting.
Make sure the sensor inside the oven has not become detached, as this will make a differance.
Plz leave feedback.
Ta.
Dec 09, 2008 | Frigidaire 30" Self-Cleaning Freestanding...
How to remove smoke stain ?
Try a mild abrasive cleanser like Bon Ami or Soft Scrub and wipe clean.
Nov 10, 2008 | Frigidaire 30" Self-Cleaning Freestanding...
Oven window
in your manual the is a section about how to remove the oven door. after removing the outer panel is removed by a few phillips screws around perimeter, of panel perhaps 2 for handle need to be removed depending on model. not a terribly difficult task, but take time and youll be fine
Nov 06, 2008 | Frigidaire 30" Self-Cleaning Freestanding...
Frigidaire 30" Self-Cleaning Freestanding Electric Range - White-on-White Logo
1,448 people viewed this question
Top Frigidaire Ovens Experts
Dan Webster
Dan Webster
Oloyede Monsuru
ashburton
Are you a Frigidaire Oven Expert? Answer questions, earn points and help others
