Question about Maytag HYG2460AWW Gas Dryer
Maytag electric dryer mod#DE612 series02
Belt broken,I have the replacement, how do I get in the dryer to replace it? Top doesn't pry up like any other dryer
  • mdgallant1 Nov 25, 2008
    I finally figured it out. On a maytag, the front comes off. Not the top or the back. the two screws on the front are not readily visible. You have to get on the floor and look up. Or as I did, lay it down on its back (put spacer blocks down to avoid crushing the exhaust pipe). After supporting the front like the hood of a car, the front of the drum comes off easily w/ four readily seen screws. Two on each side. Just lift the front of the drum off and drop the new belt around the drum. Reverse the reassembly process and stand it back up. Now you can thread the belt through the drive pulley and the idler pulley. Be sure to turn the drum by hand for several revolutions to be sure the belt is running true. Thanks, mdgallant1
    Problem Solver:
  • 7 Answers
U might want to look on the back of the dryer to see if there is a panel to take off. If not the hole top will have to come off. Is the top made on the rest of the dryer or is there a split between it.
Posted on Nov 24, 2008
  • robert nealey Nov 25, 2008
    I'm glad you got it fixed .They change them everyday so they are all different.
Dryer just stopped wont turn
More than likely a broken belt. A fairly easy fix. Disconnect Dryer electric by shutting off the breaker. Then remove the front panel that surrounds the door. There are ususally a couple of screws on the bottom and you have to pot the top. Get a belt off the net or from a appliance dealer. The belt slips around the drum over the motor shaft and on a tension Idler wheel. Pop is back together and you good to go. Try checking You Tube and see if there is a video on dryer belt replacement. Good luck! :)
Oct 07, 2012 | Maytag MDE308DAYW Electric Dryer
Dyrer wont run lights come on but wont run
If the belt is not off, it may be a loose wire to the sensor that switches the dryer off when the belt is off or broken. Mine had that problem. If that doesn't work you will have to replace the tension pulley sensor.
Oct 27, 2011 | Maytag MDE9700AYW Neptune 174 Electric...
Drum makes a squeeling noise
it pulley or there is two support wheels for drum.
you can oil them, but wheels could be broken and have to be replaced.
appliancesrepairla.com
Jun 26, 2010 | Maytag MDG9606 Dryer
WORN BELT ON MAYTAG ELECTRIC DRYER
Remove the two brackets on the back holding the top on. Then pry the front part of the top off with a flat screwdriver. Next remove the electrical connectors. The remove the front panel. Then pull the drum out. Install the belt and push the drum in place placing the belt correctly into the tensioner for the belt
May 10, 2010 | Maytag PYE2300AY Electric Dryer
How do take the front panel off?
remove the top panel first to get the front panel off. Remove the two brackets on the back and then pry the top up at the very front for two spring retainers clips hold the tops front down
May 08, 2010 | Maytag PYE2300AY Electric Dryer
It is a mod MDE4000AYW. How do I put the belt back on?
Hi welcome to Fixya
You must pop off the top of the dryer then remove the front after the front is off you can remove drum .
The belt goes around the drum and the motor pully and under the tentioner wheel after you get belt on replace front and top.
PLEASE MAKE SURE TO UNPLUG FROM POWER THIS IS 220volts AND CAN HURT YOU BAD
Thank You For Useing Fixya
PLEASE RATE ME
Jul 08, 2009 | Maytag Neptune MDE6700A Electric Dryer
Replacing the belt for Maytag Atlantis Dryer Model MDE7600AYW. What steps do I follow ??
The belt can be replaced as follows.
1 remove top and front of dryer shell
2 belt goes around drum around motor pully then under tentioner wheel
3 replace front and top of dryer
(top pops off use a slotted screw driver)
Thanx for using Fixya Please take your time to rate me
Jun 10, 2009 | Maytag Atlantis MDE7400AY Electric Dryer
Replace dryer belt
Pull the front panel off, remove the top screws and tilt top back. Rout the new belt around drum at the old wear spot with the grooved side against the drum. Next remove the back access door and rout the belt around the idler pulley and motor pulley. There is only one way to do this and get proper tension on the belt.
Also, when you order the belt, ask if it has a belt routing diagram on the belt package.
Apr 07, 2009 | Maytag PYE2300AY Electric Dryer
SOUNDS LIKE A BELT IS BREAKING AND HITTING THE INSIDE OF THE CABINET
Remove the top sheet metal screws at the top rear of this unit,,then pry up the top,,,back to forward!!!,,,then have a look at the belt,,,,Replacement cost of belt usually around $12
Jan 11, 2009 | Maytag Neptune MDE5500AY Electric Dryer
Maytag electric dryer will not run
belt around the drum is broken. The light you see is the glow of the heating element. No air flow will cause heater to get red hot. Danger!
Dec 03, 2008 | Maytag Atlantis MDE6400AY Electric Dryer
Maytag HYG2460AWW Gas Dryer Logo
434 people viewed this question
Top Maytag Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Are you a Maytag Dryer Expert? Answer questions, earn points and help others
