Question about SanDisk Sansa e260 MP3 Player
Creating+ Saving Playlists and Doubled Songs
Okay, recently I got my SanDisk Sansa E260 for x-mas, it started acting up when I got it. *Doubled songs Problem: After I found out how to fix my mp3 player after it froze, I addad a couple of songs to it, nad while my Windows Media player 10 synchronized those newly added songs it started to re-sync the old songs that were on there before. It is like 6 days later and I still can't figure out if it is the WMP or my mp3 player that is not funcioning correctly. But get this, everytime i plug up my mp3 player to the USB and open up the WMP, the songs that are doubled(which are basically the songs straight off of cds and copied to the library) don't even show up, PERIOD! I am not even gonna start on how my RealPlayer pissed me off. *Playlist Problem: How do you set up, well, save playlists on this thing? Why does the 'Go-List' on stay together until you turn the mp3 player off?
If you open the Sansa as normal Win file directory, can you see them? Is "Show Hidden Files" enabled in the file options?
Posted on Jan 02, 2007
SanDisk Sansa E260: How do I reset the WHOLE thing?
Reset All
NOTE: THIS IS AN ADVANCED OPERATION AND RESTORES ALL SETTINGS
TO THE FACTORY DEFAULTS. NORMAL USERS ARE NOT RECOMMENDED
TO PERFORM THIS OPERATION!
If your device freezes up press the Menu button and hold for 15 seconds.
This is like a power down of the device. Once you perform the reset, the adjustments you made during last operation
will be gone.....look and see if there is a boot file in one of the folder on the player. If there is delete this file....This file gets put on the player when booting your computer with the player connected.....Download Update (http://mp3support.sandisk.com/sansa/Installer/1082/SansaUpdaterInstall.exe)
I had to use my labtop to recognize 2.0usb port Go to my computer scroll to sansa or your MP3 player and open the music folder and open each sub folder and delete Songs manually then delete the folders them selfs then format a couple of times hope this works One of the cd's I put on my sansa had some file in it that made my tracks bad and was hard to delete follow above it worked
Apr 20, 2009 | SanDisk Sansa e260 MP3 Player
Songs are doubled when downloaded.
The Sandisk knowledgebase has a solution for this. They suggest that Windows Media player may be automatically syncing with the device.
http://kb.sandisk.com/cgi-bin/sandisk_en.cfg/php/enduser/std_adp.php?p_faqid=2531
Dec 25, 2008 | SanDisk Sansa e260 MP3 Player
My new 8Gb Micro Chip Will not except music
The chip may be locked - consult the documentation for details. Also, that card is too big for the e260 to read - 2GB or less.
Jul 01, 2008 | SanDisk Sansa e260 MP3 Player
To reset your device to the original setting...go under settings in the main menu, select reset and hit yes... Should you have any questions..let me know..
P.S.Please rate accordingly...
Thank You
Computerrep
Apr 22, 2008 | SanDisk Sansa MP3 Player
Double Songs?
It is virus problem. Proper format it and/or disinfect it. It will be OK. If it solve your problem vote here.
Jan 05, 2008 | SanDisk Sansa c200 MP3 Player
SanDisk Sansa e260
When it comes to deleting songs, I went on the program I use to get my music on and clicked on the sansa 260 and found my playlist. I bet if you connect your sansa and look around that program, you could probably find your playlist and start deleting.
Dec 30, 2007 | SanDisk Sansa e260 MP3 Player
Double Songs?
you go to computer than go to sansa e260, than you will see music after that you delete the songs that are doubled.
Dec 05, 2007 | SanDisk Sansa e260 MP3 Player
Plug into your computer, click on the driver letter it represents, and empty all folders it displays. Don't delete the folders just delete the contents in each one.
Nov 11, 2007 | SanDisk Sansa e260 MP3 Player
How do i delete songs off of my sansa e250?
You can manually delete the music thru My Computer. Just click on the device name, and open the Music folder. If you dont have a Music folder, you need to enable hidden files and folders on your computer. Best of Luck.
Sep 23, 2007 | SanDisk Sansa e250 MP3 Player
SanDisk Sansa e260
Try this: disconnect the player from the computer, hold in the volume + button, and reconnect the player to the computer while holding the volume + button in. Keep holding the volume + button for an additional 5-50 seconds. Windows should eventually go into recovery mode and revive the player- it will pop up a window that says Found New Hardware Wizard.
Download the Sansa Recovery Tool from the Sansa website.
Format - Erases Everything: Connect your Sansa player to the computer and open Windows Media Player. Click on the Sync tab. Pull down the drop down menu underneath the Sync tab by moving your cursor over the Sync tab and left clicking on the little black arrow underneath the Sync tab. Highlight "Sansa 1GB" (wording may vary slightly), and then select "Format." - this should erase everything.
Firmware Upgrade- Erases Everything: Get the latest firmware upgrade from Sansa - it updates the firmware and erases every song in the player all at once. Note: this method doesn't work if already have the latest firmware. Go to this website and click "Firmware Updater" to find out: http://www.sandisk.com/Retail/DriverDownloads.aspx
or
http://www.sandisk.com/DriverDownload/driverList.asp
-Tha Mp3 Doctor
Jun 30, 2007 | SanDisk Sansa e260 MP3 Player
SanDisk Sansa e260 MP3 Player Logo
83 people viewed this question
Top SanDisk Audio Players & Recorders Experts
Gyula Lacz
Mohamed Ismail
Mohamed Ismail
 Ben
Ben
Level 1 Expert
Are you a SanDisk Audio Player and Recorder Expert? Answer questions, earn points and help others
