Question about Minolta Maxxum 7000 35mm SLR Camera
Snapped off flash; how to remove flash mount from camera body?
I accidentally sat on my camera, and broke off the flash at the base. I am left with a piece of the mount still attached to the camera body. How can I remove this broken piece of the flash, to leave behind just the camera body? Thanks
    Scholar:
  • 185 Answers
What kind of camera ?
Take the batteries out of the flash. Try to fit the pieces together and hold down with pressure it should just slide off. Don't touch any bare wires if showing.
Posted on Dec 08, 2008
Nikon N80 film door replacement instructions (Focus area selector)
It does snap on. If it doesn't then you probably broke it trying to get it off the old door.
May 08, 2013 | Nikon N80 35mm SLR Camera
We installed a lens onto a N2020 that snapped right in and now it won't come off, any suggestions?
There is a lens release button to the right of the lens mount - make sure it is pressed fully before trying to rotate the lens to remove it. When you press the release button, there is a little pin in the lens mount that is retracted to let the lens turn. If you do that and the lens still does not rotate to be removed (and you are rotating it the opposite direction that you mounted it) then the release button assembly is probably broken and the camera will need servicing.
Nov 07, 2010 | Nikon N2020 35mm SLR Camera
F EEwhen i put the camera on don`t shut
This means one of two things:-
1. You have not set the lens to it's smallest aperture before fitting it to the camera body; or...
2. The EE servo coupling post on the outer edge of the lens mounting flange on the body has broken off. This is a switch which senses when the lens is set to it's minimum aperture. Looking at the camera body, with the lens removed, it's at about the eight o' clock position on the outer edge of the body lens mounting flange.
1. is easily fixed:just fit the lens correctly. 2. Really needs a professional repair, but as you can get a used F60 (N60 in USA) for free these days (FreeCycle/Freegle) it's not worth doing: just fasten it permanently in the "activated" position. Do a bit of googling and you'll see what I mean.
I hope this has solved your problem, if so please rate my answer.
Feb 25, 2010 | Nikon F60 35mm SLR Camera
I have a Maxxum 7000i 35mm camera and in the display there is the word Help flashing what does this mean This happend after i tried a differnt lens, the lens opened than closed The lens that i tried was a...
Konica lenses do not fit Minolta cameras. I think you messed something up.
Minolta MC and MD lenses worked on the older manual focus Minolta bodies. They will also work on the Phoenix and Seagull clones of the old Minolta bodies.
The Konica lens should only ever be mounted on a Konica camera.
Your 7000i is now a Minolta paperweight. You need to send your 7000i for repair or replace it.
You could also look on Ebay for another Maxxum body to use your lenses designed for the Minolta A mount. As a rule, camera lenses are not interchangeable. You can use any Maxxum lens on any Maxxum body as a rule, but Minolta changed their flash shoe after the original 7000 series. Flashes that work with your 7000i will work with any subsequent Maxxum.
lightspiritphotography.com
Oct 25, 2009 | Minolta Maxxum 7000 35mm SLR Camera
Can sigma lense fit to canon av-1 camera body
Normal 0 false false false MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-ansi-language:#0400; mso-fareast-language:#0400; mso-bidi-language:#0400;} Greetings!
Answer to your question is, ‘Yes’ we can. Use Sigma FD lenses.
As we know Canon AV-1 has electronically controlled AE (Automatic Exposure) & has a Canon Breech-lock lens mount.
Original generation of FD lenses featured a silver locking ring at the base. Only that locking ring turns to lock the lens to the camera body; the lens body remains still.
In the newer lens system which was introduced with this camera, the user has to line up the red dot on the lens, with the red dot on the camera and simply turned the whole lens clockwise until it clicked into place.
Note: FD-mount cameras could use FL lenses in stop-down metering mode.
Thank you & have a nice day.
Warm regards,
William
Feb 20, 2009 | Canon AV1 35mm SLR CAMERA SPARES OR REPAIR...
EOS50E Program ring on the top moves hardly
I have just submitted a solution today for a broken dial which explains how to remove the dial assembly.It isn't difficult.Bob Carllson.
Dec 26, 2008 | Canon EOS-50E 35mm SLR Camera
SLR Camera
You don't say whether ou've tried using the reset button, which unlocks the mirror after lock up. As you look at the camera face on (shutter top left, rewind arm top right) then its about at 5pm on the lens mount. Whilst pressing that down, rotate the manual speeds band (found on the lens mount on the body) round to B, which should unlock the mirror.
If it does, it should work normally with new batteries in.
Aug 15, 2008 | Olympus OM-4TI 35mm SLR Camera
Flashing F in LCD panel
While looking at the camera front with the lens off, you will see a small tab sticking out just on the outside of the mount ring at about 7 oclock.
You should be able to move the tab down with your finger and it should snap back. If it is loose or doesn't snap back, it will need repaired/replaced
Dec 31, 2007 | Nikon F65 35mm SLR Camera
Fee to error
Remove the batteries for 5 or 10 minutes. Remove the lens from the body and replace it. Make sure the lens is on f22 before you put the batteries back in and turn on the camera. If this doesn't solve it, try rewinding the film you have in the camera and try a new roll. The other thing to check if none of the above works is to remove the lens and check the small tab just on the outside of the mount ring at about 7:00. The tab is spring loaded and you should be able to push it with your finger and it will snap back. If it doesn't, the tab plate will need repaired or replaced
Dec 25, 2007 | Nikon N55 35mm SLR Camera
Minolta Maxxum 7000 35mm SLR Camera Logo
53 people viewed this question
Top Minolta Photography Experts
Mark Schmit
Mark Schmit
TC CAMERA REPAIR.Com...
Are you a Minolta Photography Expert? Answer questions, earn points and help others
