Question about Bosch SHU9925UC Built-in Dishwasher
My dish washer won't stop trying to drain
If I open the door it still tries to drain with no water in it - it wont do anything else but run the pump
My dishwasher would fill up and start draining when washing watt should i do
Posted on Feb 11, 2009
5 Suggested Answers
Macmarkus
  • 2605 Answers
SOURCE: dish washer stays on water drain
The reason this is happening is the overflow basin has likely filled and activated the overflow float switch. The cause is a little more involved to explain from afar, I`ll try.
The number one cause is a clogged drain hose, check at the point of entry to the household plumbing, usually under the sink.
Other possible causes (among many) include, baking pans like cookie sheets being placed along the right hand side of the lower rack which in turn cover`s over the vent.
An improper install of the dishwasher by the absence of a ``hi-loop`` in the drain line,(refer to the installation guide, you`ll see what I mean) this can manifest in dirty water being allowed to ``backflow`` into the dishwasher creating an overfill scenario.
Drain hoses connected to food disposer`s/garberator`s with-out a check valve...a hi-loop isn`t sufficient in these situation`s, I`ll explain.
In the event a home owner has a full sink of water, and a continuous feed disposer heavily loaded, then turn`s the disposer ``on`` the volume of water being pushed out the garberator into the drain can and often does flow back to the dishwasher ultimately filling the overfill basin, hence activating the overfill float. This will automatically activate the drain pump which will run until the water level in the basin evaporates ( there is no automatic device built in to the basin to drain it, hence it must evaporate or be physically absorbed via a sponge, towel etc.) to an acceptable level to satisfy the float switch and shut off the pump, and the pump will run whether the door is opened or closed...it`s a safety device which overrides all other function`s.
Another possible cause is a contaminated/dirty float switch has become ``stuck`` in the overfill position. The float is located in the basin, but the switch is located on the left side of the dishwasher in the switch housing assembly and activated via a linkage. The switch can be accessed by removing the left side panel, which is fairly involved and I`d suggest hiring a pro for such a matter.
Those are a few possibilities. I hope this was helpful without seeming overwhelming, such is the case from afar unfortunately. I believe it`s needed to provide possible solution`s to explain actual causes.
If you`ve found the info I provided here for you at fixya, please take a second and rate it. Let me know if I can be of any further assistance. Thank you.
Good luck.
macmarkus :)
Posted on Dec 05, 2009
  • 22 Answers
SOURCE: bosch dish washer SGS56E02GB
anti flood device has been activated, this means you have water in the base of appliance. most likely a leak, or if you have been using 3 in 1 tablets, and rinse aid this will over foam appliance and foams leaks into base.. try tipping d/w back to let water out of base..then try d/w again... if anti flood activates again...call an engineer.. ps check big nut that secures salt container to base of d/w, it can come loose which will cause water to leak into base ally
Posted on Jul 02, 2007
  • 75 Answers
SOURCE: water wont drain after wash!! Dishes wont dry all the way also
If your unit is over 10 years old buy a new unit. They are cheap enough.
Posted on Jul 19, 2009
localwonder
  • 6784 Answers
SOURCE: dish washer wont drain
HI. check the following areas for faults.
1. Air gap / Drain hoses
If there is an air gap (located in the sink, near the faucet), check to see if it is clogged. Unscrew the top cap and see if there is anything blocking inside. Note: If there is no air gap installed, the dishwasher might not drain properly.
If the drain hose is clogged, the dishwasher would not drain. If there is an air gap installed, it is very common that a hose going from the air gap into the garbage disposer is clogged. Remove and clean the hose. Make sure to reattach the hose before starting the dishwasher.
Note: If you recently had a garbage disposer installed, it is common to overlook removing the drain plug.
2. Broken belt
Some dishwasher models use a belt to drive the pump. Replace the belt if found broken.
Note: Sometimes the belt would just come off the pump. Even though it might not be broken, it is recommended that you replace the belt, because it is probably too stretched out.
3. Pump
Some models have two impellers inside the pump - one, wash impeller, takes care of the wash cycles, the other, drain impeller, drains the water out. If the drain impeller is broken (broken blades, shaft), the dishwasher would not drain. Replace any broken pump components.
4. Drain solenoid
Some models (for example most GE dishwashers) use a drain solenoid to drain water out. Sometimes the solenoid gets stuck, preventing the water from draining out. Try to free up the solenoid. If unsuccessful, you might have to replace the pump assembly.
5. Motor
If the motor is stuck, it is sometimes possible to free it up by manually spinning the motor.
Replace the motor if defective.
6. Timer
Replace if defective (note: uncommon problem).
Posted on Aug 26, 2009
Samsung dish washer won't stop running event with the door open no leaks no water anywhere pump pushes water out drain hose
if you can hear it running even with door open its probably in a fault mode as this the only circumstance in which it will run with the door open, what you are hearing is the drain pump and its doing that because there is a leak in the base of the machine setting off its flood switch, if you pull the dishwasher out and lean it back you will see water run out the bottom, then you need to find where its leaking from
Dec 26, 2016 | Samsung Washing Machines
Machine had been giving E20 error code - filter cleared and it re-started ok. When wash was in progress - jammed at rinse stage and all lights came on (except spin speeds) and humming noise and nothing...
E20 is an error code for drainage failure.
Check where the appliance drain hose connects to the house drains for a blockage.
If it's onto a spigot under the sink, take them off and check both for a blockage.
If these are ok then it's likely to be a blockage in the pump.
You'll need to drain the water out manually.
Put a shallow dish below the filter and slacken the filter.
Tighten it to stop the flow of water while you empty the dish.
Once empty, take the filter out, clean out the debris and ensure nothing is left jamming the pump.
Before refitting the filter, put the machine on drain or spin and listen at the filter housing to see if you can hear the pump running.
If you do, fit the filter and try the machine again.
Thanks for using FixYa
Oct 11, 2011 | Zanussi ZWD1470W Front Load Washer / Dryer
The door wont open . I have tried to put it on for a cycle and you can here the the water for around 5 seconds then it stops and does nothing.
Check and make sure your pump or filter is not clogged, then next I would suspect you have a faulty door lock mechanism
More common issues with the door lock.
Is water hooked up to the washer?
The door will remained locked while draining water. If during installation the washer was plugged in and turned on without water hoses attached, the washer may attempt to drain for 8 minutes before the door unlocks. Let the washer run until the door unlocks. Do not turn off the washer or unplug the washer.
Does water remain in the washer after the final spin?
If water remains in the washer after the final spin, then the door will not unlock. Select Drain/Spin or Spin Only to remove any remaining water from the washer. The door should unlock at the end of the cycle. For models that have Rinse/Drain & Spin, push the Extra Rinse button to turn off the rinse to remove excess water.
Is the door locked and the Add A Garment light on?
If the Add A Garment light is on, then the washer door will unlock after the Pause/Cancel button is pressed once. Pressing the Start button will restart the washer at the same point where it left off in the cycle.
Is the door locked and the Add A Garment light off?
If the Add A Garment light is off, then the washer door will unlock after the Pause/Cancel button is pressed twice. The door will not immediately unlock while the cycle is running due to a possible high-water level in the washer, high-water temperature, tumbling or spinning. It may take up to five minutes for the washer to stop spinning and draining before the door will unlock. You will hear the door click when it unlocks.
Trying to gain access into a locked door can be a bit frustrating. Upon researching your question I found some links that may help you unlock your washer door. I attached all links below. I hope this helps!
http://www.managemylife.com/mmh/questions/204092-how-do-i-get-the-door-open-on-my-kenmore-washer
http://www.managemylife.com/mmh/questions/220303-does-front-loader-door-open http://www.managemylife.com/mmh/questions/134692-why-wont-the-door-open-on-my-kenmore-frontloading-washer
Jun 10, 2011 | Washing Machines
Whirlpool frontload washing machine door will not open after the
if there is still water in the washer you can use a wet dry shop vac and attach it to the end of the drain hose.Once all the water is removed from the washer you should be able to open the door.
then you need to check the drain pump for anything that may be obstructing the pump. make sure to check the hose that leads from the bottom of the tub to the drain pump.
Jun 21, 2010 | Washing Machines
Washer was running doing load and heard a solid beeping the h and f were flashing on panel heard pump sound like it was working but machine had already drained water unplugged and waited plugged in socket...
This error code means"No water detected entering machine or Pressure switch trip not detected".
Is the machine getting any water? Check that the water supply is turned on.
Press pause cancel twice to clear the display.
Try to run another cycle.
Let me know if I can help with anything else.
Mar 30, 2010 | Whirlpool Duet GHW9150P Front Load Washer
My washer is not draining. I used to be able to reset it and it would work but now it wont start on any setting and is full of water. Is there anything i can try.
If your Maytag washer is not draining, follow these procedures to find out what is the problem.Set the timer in the spin cycle and pull the knob to turn the washer on. If the washer motor doesn't run, check the following parts.
The wall outlet: Make sure that there are about 120 volts present at the wall outlet. Connect a good working hair dryer to see if it works.If the hair dryer works ok, then the problem has to be in the washer. If the hair dryer doesn't work, then look for a blown fuse or tripped circuit breaker.
The lid or door switch : The lid switch is a safety device use to stop the motor from running if the washer door is opened during the agitation or spin cycles. A bad lid switch could be the reason for your washer not draining.
The pump : Check for obstructions inside of the pump and inside of the tub.
Check the pump impeller, the pump belt, check the drain hose for any kinks. Any problems in these parts could be the cause for the Maytag washer not draining.
Lower the drain hose to a bucket to see if the water drains out. If the water won’t drain or just trickles out, most likely there is an obstruction on the pump or inside of the tub and that could cause the washer not draining.
To check the pump, remove the front panel, lean the washer against the wall and bail the water out with a plastic container.
To check the pump, remove the pump belt and turn the pump pulley to make sure that the pulley is turning freely.
Put a couple towels near the pump to catch any water from the pump. Remove the tub to pump hose at and check inside of the pump for any obstruction. If you find an obstruction remove it.
If you don’t find anything, reinstall the hose and remove the hose at the tub, and check for obstructions.
A Maytag washer not draining could be cause simply by a kink drain hose.
You need to make sure that when you replace the pump, you adjust the belts properly.
Jan 29, 2010 | Maytag Washing Machines
Whirlpool washing machine wont stop all lights
Check your washer plug to see if the connections are tightly screwed. Next check your filter if you haven't for long.
Remove the 3 screws at the bottom of the front panel under the washer door. Your filter door will be light brown. If you find a hose there it is to drain out excess water (water that could not be drained by your pump) After you hv drained unscrew the cap and remove all the junk inside. Have a large plastic bag to catch junk and water. Refit carefully after cleaning out. If not solved, something shd be blocking your pump, check this out.
While the machine is on press "end of cycle" for 3 seconds, then wait for 2 minutes to try the door. Try this again if it does not open, this is the child lock program - to lock and unlock; it is the same procedure.
How abt a nice rating for the free help? Thnks
Jan 17, 2010 | Whirlpool Duet GHW9150P Front Load Washer
CDA dishwasher (model number CW496) , stops working at the rinse cycle, and does not empty, filter is ok, tried re-setting the programme but unless there is no water being held the programme won`t work
my dishwasher starts off with good intentions then a couple of minutes later it starts beeping non stop.I open the door to find it has turned on to the rinse cycle and will not do its job.I continue to start it again and then it repeats the problem again.Can you help?
Sep 21, 2009 | Dishwashers
My dishwasher doesnt drain and the drain button is flashing
ok if it doesnt drain properly... it means the drain hose isn't carrying it to the drain pipe, or the house's drain lines are backed up.
check these: Drain line/air gap Pump Drain valve and/or solenoid Belt Motor Timer
A clog in the drain line or air gap (if there is one) is the usual reason that a dishwasher won't drain.
Air gaps are installed in the drainage system to prevent the discharge from the dish washer to enter the sewer system and the contaminated water to drain back into the dishwasher after the pump stops.
When we install a dish washer we loop the discharge hose as high up under the cabinet as we can and secure it with pipe straps.
This creates a air gap so that when the pump stops nothing from the drainage system can flow back into the dish washer.
Often the problem is at the point where the drain line attaches to the garbage disposer or household drain line.
If you remove this line, you can clear any debris from the hose or hose connection. Be sure to reattach the hose before starting the dishwasher again.
we ll now see how to check the pump
Your dishwasher pump ejects the water. The pump is usually mounted directly to the motor, then attached to the bottom of the dishwasher You can reach the pump from inside the dishwasher, but first you need to remove the lower rack, the spray arm, and the spray arm support. Look for an impeller--a round plastic fan blade-type of device that spins around. This is the wash impeller, which forces the water through the spray arm.Beneath the wash impeller is the drain impeller, which is similar in size and shape to the wash impeller.
The drain impeller pushes the water toward the drain port.
if u see any of these parts broken u wud need to replace themnow the next thing to check wud be the drain valveMany dishwashers use a drain valve with an electric solenoid.When electricity flows to the solenoid, the valve opens and diverts the water to the drain.Sometimes the solenoid, or the diverting lever, sticks and prevents the dishwasher from draining or filling properly. Try to free up the solenoid to lubricate the lever. Otherwise, you may have to replace the solenoid or pump assembly.To access the drain valve remove the lower panel located beneath the door. The panel is usually held in place with two screws either above or below the panel.It may be necessary to first open the door to the dishwasher to reach the screws over the panel, then close the door to remove the panel. Look for a water hose running from the motor or underside of the tub. The hose should lead to the drain valve. now we need to check the motor ... now u might not be required to come uptill this iam giving u instructions just incase
If the motor isn't turning or working, the unit won't drain If the motor hums but doesn't turn, it may need to be replaced.
Some dishwashers are susceptible to getting stuck if you don't run them regularly. If you haven't run the dishwasher for more than a week,you may need to manually spin the motor to free it up. If the motor is defective, you need to replace it. Dishwasher motors just can't be serviced.also refer the following links http://www.acmehowto.com/howto/appliance/dishwasher/check/airgap.php
http://www.acmehowto.com/howto/appliance/dishwasher/check/timermotor.php
regardsiversh
Apr 27, 2009 | Miele 24 in. G645SC Plus Free-standing...
Washer Dryer - drum is filled with water even when switched off and door can still open!
Try the valves inside the back where the water hoses connect to the machine they should default to the closed position when water is not required
Oct 31, 2008 | De Dietrich LZ9619 Front Load Washer /...
Bosch SHU9925UC Built-in Dishwasher Logo
549 people viewed this question
Top Bosch Dishwashers Experts
Gerry Harvey
Gerry Harvey
Are you a Bosch Dishwasher Expert? Answer questions, earn points and help others
