Question about Kenmore Refrigerators
Kenmore refrigerator Sold my Kenmore refrigerator and they are saying it does not work at all. First they told me the refrigerator works and not the freezer. it is a side by side model 41514100 manufacturer date of 07/02 full load 6.5 amp. They are saying it is the compressor. They cleaned it underneath. It worked fine when it left my house. Any suggestions on what it might be other than that?
fridgetech
  • 473 Answers
SOURCE: My kenmore refrigerator side by side
Sounds like it has a defrost problem.  Check for thick frost buildup on the back bottom panel in the freezer first and let me know what you find so I can steer you in the right direction.  Also, give me the entire model # from the sticker inside fridge.
Posted on Oct 18, 2007
fridgetech
  • 473 Answers
SOURCE: refrigerator compartment not cooling
If you are sure the fan in the freezer is running and you don't feel any air flow out of the top middle vent inside the fridge section, then the damper motor must be bad. The damper motor is behind that vent cover inside the fridge section.
Posted on Nov 16, 2007
tech master
  • 120 Answers
SOURCE: Compressor running, I can hear the fan but only blowing warm air
not realy if compressor is running you are sure of that and condenser motor is running as well the open the evapoartor are if no frost then there is a leak or restriction best bet call a tech to make sure but it looks like etheir case it will be more then 200 dollars new fridege 450 to 500 balance out or you can call sears buy the service smart agreement for 300 dollars and they will fix it
Posted on Oct 15, 2008
rpbuice
  • 161 Answers
SOURCE: kenmore refrigerator compressor clicking
Relay on the compressor bad.
Try unpluging for 30 - 45 min until the compressor has cooled down then plug it back in. If it doesn't start replace the relay. Most service techs carry a universal relay and wiil put the relay on, if it starts, your good to go, if not, then the compressor is bad.
Posted on Dec 17, 2008
  • 58 Answers
SOURCE: Refrigerator is running but not cooling
You have a bad compressor relay. to check it you will need a voltage meter. Remove the rear cover and you will see the compressor remove the relay held on by a wire. If the relay sounds like a maraca replace it with part #8201769. If is donesn't sound like somethings broken inside it check for continuity on all 3 compressor terminals ( all terminals should read closed ) now this can go to ways if the terminals read good and the relay is good then the compressor is lock rotor and has to be replaced. Most cases it's the relay Good luck hope this helps
Posted on Jan 08, 2009
I have a kenmore side by side it has power and the light bulbs works but the freezer and frige are not cooling and the digital thermometer and and controls or out what could I check
depending on who manufactured it for kenmore which can be told by the first 3 digits before the dot in the model number as in 110.xxxxxxxxx who made the unit,then it could be your mainboard thatcontrols all functions and/or the ptc overload on the compressor
May 28, 2011 | Kenmore 53642 / 53644 Side by Side...
The freezer will not freeze, but refrigerator side is workingfine
the freezer back wall need to be open and check the heat element and the thermostat , also make sure the fan is working in the freezer. if the frost on the coils are not even then it is sealsystem that is bad news, but if it is just frozen defrost it with hair dryer and check the elements i told you to check
Dec 30, 2009 | Kenmore Refrigerators
Kenmore fridge not working, ice cubes wet, freezer frosting up
You may need a new defrost module. The coils ice up when it is not working. This makes the fridge and freezer only a little cold. About 150 to 250 bucks to fix if you call a service person. Under a hundred for the part.
Apr 13, 2009 | Kenmore 55612 / 55614 / 5561 / 655619 Side...
Kenmore elite refrigerator, model # 59676534500
I went ahead and signed up for Sears' service warranty since I knew I had to get someone to come out.  IT costs $200/yr.  They say it covers everything, but when the technician came out, he told me that it just covers $500 per visit.  He said that a new motherboard and the labor alone was going to make it $498.  Anyway,   he had ordered a new motherboard. Apparently the motherboard wasn't working.  It is located in the back bottom left side of the refrigerator behind the panel.  There is a compartment on the lefthand side that slides out and houses the motherboard.  He put that in and also had to fix the fan that is in the back of the freezer.  That fan is the one that sends cool air up to the refrigerator part. When I had looked at the fan before the repair man came, it was not moving at all.  So at least take a look at the fan in the freezer.  Just take out the freezer drawers, and the fan is located in the top center of the freezer behind the compartment cover.  Maybe that's the problem with your refrigerator, the fan.  Hope that's all it is. Good luck!
May 29, 2008 | Kenmore Elite 22.4 cu. ft. Bottom Freezer...
Kenmore 50392
We were low on freon . This refrig's internal fans don't run until the proper temperature is reached
May 21, 2008 | Kenmore 53092 / 53094 Side by Side...
Kenmore
problem has been almost certainly caused by freezer door not being completley closed allowing warm humid air into freezer, (do not say this could not happen because it often does), sollution, turn off defrost overnight, turn on following day, within 24hrs unit will work ok. Regards Adviso
Aug 22, 2007 | Kenmore 52632 / 52634 / 52639 Side by Side...
Kenmore Side by Side Refrigerator, freezer doesn't work, refrigerator works
Unless specifically made for use in a garage most units won't work properly. The owners manual should say what the temp range for proper operation is (usually 55F is the low range). This is because the refrigerator section doesn't need to be "cooling" to maintain 37F if the temps on the outside are below 55F. These things are made to work in a 70F room and will not work properly if under 55F. Stupid thing thinks it's cold enough so it will never turn on, the refer section will stay cold/cool due to outside temps but since the compressor never runs the freezer will just be the same temp as the refer section (at best). Sorry, but in order for a freezer or refrigerator to work in an unheated space it must have the temp control device controling the freezer section NOT the fresh food section. In other words, that model will not work in a garage unless the temps are above 55F always.
Feb 06, 2007 | Kenmore 50522 / 50524 Side by Side...
Refrigerators Logo
89 people viewed this question
Top Kenmore Refrigerators Experts
Sal De
Jim Goldsmith
Jim Goldsmith
Arnel
Arnel
Are you a Kenmore Refrigerator Expert? Answer questions, earn points and help others
