Question about Dymo LabelWriter 400 Turbo Thermal Printer
CONNOT CHANGE PRINTING MARGINS
RIGHT HAND (PORTRATE) MARGIN IS 1/2 THE LABEL & DONT SEEM TO BE ABLE TO SET IT CLOSER TO THE EDGE OF PAPER.
  • Oscar Carl Henrik
    Oscar Carl Henrik Aug 19, 2016
    I have this problem too. Very annoying. It seems there is a (ridiculously large) minimum distance from the left edge of the edge.
I'VE TRIED A NEW DRIVER BUT THATS NO HELP. THANK ANYHOW.
JOHN
Posted on Nov 25, 2008
What should the zebra printer be set at for a 4x6 label
Label size should be as follows;
Width 4.00 cm
Height 6.00 cm
Margins;
L 0.20cm R 0.20cm T 0.15cm B 0.15cm
Basically Label setup should be the physical size of the backing paper, the L/R margin size is the gap between the edge of the backing paper and the edge of the label and the T/B margin size if half the gap between two adjacent labels....... Hope this helps.
Jun 09, 2014 | Toshiba TEC B-SX4 Thermal Label Printer
On my Laserjet 3015, in Microsoft Word, if I set top, bottom, left, and right margins to 1", on the printed page, the margins print as Top 1", Left 15/16", Right 1-1/8", and Bottom...
The default paper selection/ size in MS Word is 'letter'. you may have designed the document on letter size and while printing you have A4 size paper in the printer.
So, Make sure that you design the document on the same paper size (such as A4, which is commonly used). Secondly, while printing don't print the document directly. From the Print dialogue option choose the exact paper size and un-check (de-select) any option of paper resizing (if available). You will have the documents printed exactly as designed.
Let me know if any further clarification/ assistance is required.
Hope it helps! Good Luck! Thanks for using Fixya!
CreativeTECH
Jul 12, 2011 | HP LaserJet 3015 All-In-One Printer
I am printing a booklet using the bookfold option in Word 2007 on my Windows 7 laptop. The margins page has normal margins (1,1,1,1) highlighted. Page setup, in Word, says my margins are 1,1,1,1 with no...
Sounds like you need to go into Properties in the Brother, possibly in advance options for a setting that over-rides the printer settings for the page settings.
What happens if you choose a 1.5" right margin in the document.
Mar 25, 2017 | Brother MFC495CW
I want to print a brochure in word or psd and how I can print edge to edge, borderless.
Within MS Word, minimize the "left-margin" and "right-margin" settings/
Use "printer setup" to minimize the margins.
Oct 31, 2009 | Microsoft Office Word 2007 Full Version...
The printer will not print on the half inch left edge of the page.
go to settings and change the left margin to 0.0. if in Word, then file->page setup and set the margins to what you want, left margin to 0.0 in your case.
Sep 02, 2009 | Laser Office Equipment & Supplies
Cannot print avery labels, get message the margins of section 1 are set outside the printable page, or will run thru printer , printing complete get blank page
I assume this error is occuring in Microsoft Word.
  1. Create a new document, with a full page of the label you are having trouble printing.
  2. To see the margin settings of your document, go to File > Page Setup (or Page Layout > Margins > Custom Margins for Word 2007).
  3. Click OK on the margins dialog, and Word will check the settings against your currently selected printer. If a margin is set outside the printable area (usually the bottom margin set to zero), you should see the warning message.
  4. Click the Fix button to have Word change the margins
    to match your printer. You should now see the Margins dialog with the new margin settings.
  5. Click OK.
One thing to watch for- on some inkjet printers, the printable area is narrower than the labels. This will cause the labels to shift to the right on the page and be misaligned when you print.
If the labels run off the right edge of the page display, or are misaligned when you print, an extra procedure is needed.
  1. Undo ([Ctrl]+[Z]) the new margin setting, or create a new page from the label template again.
  2. Select the entire table of labels ([Ctrl]+[A]).
  3. Right-click the table, and select Table Properties.
  4. Click the Text wrapping "Around" option, then the Positioning button.
  5. Change the Horizontal position to Center, Relative to Page.
    Uncheck the "Move with text" option. Click OK to the Table Positioning dialog, then click OK to the Table Properties dialog.
  6. Left-click (or press an arrow key) to "deselect" the table, then go into the margins dialog (see above) and allow Word to fix the margin settings again.
With the labels aligned to the page, rather than the margins, the new margin settings should not cause the labels to shift.
Once you have the margins set correctly for your printer, I would save the empty page of labels to use as a "template".
Jun 29, 2009 | Lexmark P3150 All-In-One InkJet Printer
HP Deskjet F2180 Margins incorrect for label printing
I eventually managed to print my labels one sheet at a time by forcing the label top edge down the page. You can insert one or two lines above the label template and adjust the font size to get the right distance. It took a bit of trial & error but got there in the end. Hope it helps you
Dec 08, 2008 | HP DeskJet F380 All-In-One Printer
Missing left edge
try to change the settings of the printer. maybe your document is on portrate position and your margins.
Jan 31, 2008 | Samsung CLP 300 Laser Printer
Margin problem
Problem---Printer prints email on the very edge of the paper and leaves off the first 3 letters of every word down the edge of that margin. If you have Windows Live Mail forget trying to fix it from there. Clicking File will not give you the page setup option you are looking for. Go to the bottom of the screen, click "all programs", look for and click "Internet Explorer", click File, click "page setup". A screen comes up in which you can change the margins. The left margin is probably set on .25. Change it to .75. Okay. Go back and run a test email.
Dec 19, 2007 | HP Photosmart 7450 InkJet Printer
Envelopes and labeles
Go the "print" dialog and select "settings". Ensure that the paper size, margins and orientation are not set for 8.5x11.  You did not mention the software you are using to print the envelopes/labels so this is the only guess I can give.   I have seen software that made me have to override the settings before.
Oct 15, 2007 | Samsung ML1740 Laser Printer
Dymo LabelWriter 400 Turbo Thermal Printer Logo
1,180 people viewed this question
Top Dymo Office Equipment & Supplies Experts
Marvin
Marvin
Jose Pino
Jax Planet
Jax Planet
Are you a Dymo Office Equipment and Supply Expert? Answer questions, earn points and help others
