Question about SanDisk Sansa e200 MP3 Player
Sansa e260 problem
I recently had my mp3 player freeze up upon cable disconnection from the computer. The screen was stuck on disconnect for a long period of time. It eventually turned off about an hour later. Now it will not turn on. The only thing that happens when you hold any of the buttons down is the blue ring light in the center comes on. That's it. The battery should have plenty of juice since it was plugged in for 4 hours previously. Any ideas? Thanks in advance.
  • 2 more comments
  • Anonymous Mar 02, 2008
    i load some music on my e200 ang it went blank it turn on but gose to a blue screen and thats it
  • dabomb Apr 16, 2008
    When i was about to listen to my sansa260, the words on the screen messed up and the the only thing that happens know is no matter what i push the light in the center is the only thing on
  • bsmcm64 Dec 11, 2008
    my sansa e260 intro screen & sansa rhapsody intor screen cycle through each other over and over,removed bat, i can not get and menus. i can not format (computer, none, reads the mp3 as connected) i have tried resetting, nothing...any suggestions out there?
  • Anonymous Feb 27, 2009
    my sansa is disconneet screen what do i do
  • 40 Answers
It might just need to be reformatted. If you don't care about deleting and redownloading everything with songs and videos and pictures, too, then reformat it. Just plug the mp3 player into your computer and right click on the icon in the MY COMPUTER window, and click on FORMAT. It should come to a new window and click on start format. If this doesn't work, then call me to help you any further. Ask for Maxwell at 1-(239)-945-0583.
Posted on Jan 25, 2007
  • Maxwell Wild Jan 30, 2007
    Try the recovery mode. all you have to do is:
    put the HOLD icon on, and press and hold the RECORD button on the side. After about 2 to 5 seconds, it should come to a screen that says its in recovery mode, and make sure that you have the USB setting set to MSC, not MTP. if this is all in place, you should be able to plug it into your computer and wait for it to tell you when to unplug it and it should fix the problem. Good luck!
  • 4 Answers
You need to update the firmware,
This Link will help you to do that. http://blog.albinjey.com/category/sansa-mp3-player/
Thanks
Posted on Apr 08, 2009
My sansa e260 firmware is erased and it shows a black screen with this message load main image failed switch to recovery mode please tell me what i can do i am very depressed and i want a full version of firmware of sansa e260 please tell me sonn thanks
Posted on Jul 13, 2008
Try taking the back cover off, remove the battery for a few seconds, then reinsert the battery to reset the locked up mp3
Posted on Feb 28, 2008
This just happened to me too, only it was not frozen on disconnect mode. The screen did not work, but the blue ring lit up. I did like Wild said- put hold on and held the record button in. Nothing came up so I tried it a couple more times. I thought I would try plugging it into my computer again(only the blue ring lit up when I did this before)and it turned on and the screen worked and everything. Not sure why it did that, but thanks for the help and hope that works for yours!
Posted on Jun 20, 2007
My mp3 Sansa e260 is stuck on disconnected. How do i get it to be conneced.
on main screen 1 massage showing load main image failed switch to recovery mode
Jan 06, 2011 | SanDisk Sansa e260 MP3 Player
Sansa e260 Problem
I have the sansa e260 with the same problem as well. Can someone help....Please!!!
Aug 05, 2009 | SanDisk Sansa e200 MP3 Player
Frozen and stuck on screen disconnected
Hold the power off button continuously for 15 seconds. This should force a shutdown and reboot.
Apr 21, 2009 | SanDisk Sansa e260 MP3 Player
The sansa e 260 fails to work properly
Make sure that the USB mde on the player is set to MTP. Update player to the latest firmware.
http://www.sansaworld.com/
http://www.sansaworldmp3.com/
Mar 31, 2009 | SanDisk Sansa e260 MP3 Player
Busted?
Try to connected it back up to your computer in the msc mode and then disconnect it wait for it to refresh it's database and it should be working with titles.
Oct 10, 2008 | SanDisk Sansa e260 MP3 Player
Videos
You need to use the sansa media converter program that came with the sansa on the CD. This is used for photos1.gif and for video. The supported files are listed on the screen once you open it.You shouldnt have any problems transferring music to it using that program
Jan 25, 2008 | SanDisk Sansa e260 MP3 Player
Sansa e260 won't connect to my computer
see if thers a firmware update for it do windows update run ccleaner tool get out junk in computer may clog it up go to ther web site and download ther latest software and updates cheak for firmware updates ok uuiseing usb 2.0 ports also
SANSA E260 problems!! HELP!!
Try this: disconnect the player from the computer, turn it off, hold in the volume + button, and reconnect the player to the computer while holding the volume + button in. Keep holding the volume + button for an additional 5-50 seconds. Windows should eventually go into recovery mode and revive the player- it will pop up a window that says Found New Hardware Wizard.
Feb 21, 2007 | SanDisk Sansa e260 MP3 Player
SanDisk Sansa e200 MP3 Player Logo
975 people viewed this question
Top SanDisk Audio Players & Recorders Experts
Joe Negus
Joe Negus
Gyula Lacz
 Ben
Ben
Level 1 Expert
Are you a SanDisk Audio Player and Recorder Expert? Answer questions, earn points and help others
