Question about Toro "Toro" Super Blower/Vac
Where to find repair service
I live in zip code 02675
I have a Toro Super blowervac and the plug has melted
Do you know where I might bring it to find out if it can be fixed
Thank you
Mary Pintabone
2 Suggested Answers
garageadict
SOURCE: The plug on my Toro power blower vac got super hot and melted the inside of the extension cord plug. what happened?
It appears that for some reason, the connection at the extension cord, overheated. Could be caused by: 1. a problem with the vacuum unit (bearings, jamming up, something like that)
2. The extension cord itself was defective. Could have been abused, moisture could have broken down the "contact" or the point of contact or blades of the extension were loose and caused excessive current draw at that point, overheating the device.
Or, it could have been a factory fault with the extension.
Plug your blower into a good receptacle, and see how it runs. If it is
sluggish or not coming up to speed, the problem could be in the unit.
Check manufacturer's recommendation for extension cord size and length.
Posted on Dec 02, 2016
What's the cost to replace an 08 Cadillac thermostat? And how much time would it take if I did it myself?
Auto Repair Estimates Know How Much Car Repair Costs AutoMD
plug in your year make model engine
the work to be done
and zip code
have fun! this tool gives me the ballpark estimate before i even DIY or bring it to the shop
Apr 03, 2015 | Cadillac Cars & Trucks
Problem is my hardly used Toro Blower Vac is getting no Power
If it has not run for awhile, check the brushes. they might need to be replaced. The plug is usually moulded right on power cord. That might have to be replaced because if there is a problem with a broken or disconnected wire right at plug there is no way to see it. Hope this helps.
Dec 07, 2010 | Toro 51599 Electric Blower 12 Amp
Plugged it in and it won't run but it was running fine when I put it away two weeks ago.
Check the plug for loose wire or at blower where wire it enters to make sure the wire was not pulled and disconnected inside. If after looking and it is not a wire, check the brushes on the motor. They could be worn out or not making a good contact. Blow out brush housing and re-install brush sometimes this works. That's about all I can think of unless there is a safety switch then check that. Good luck.
Nov 22, 2010 | Toro Craftsman 225 mph Electric BlowerVac
I have one of these heaters and it is not starting is there a place local to me were i can bring it to get it looked out i live at 51 crescent st yaphank, ny 11980
Sears has repair shops that could take a look and repair it for you, since I don't have a zip code I can't give you a exact place to go. normally if they don't start it's due to a faulty therm switch inside the heater where the flame blows out, it's not to difficult to fix, if you can give me a model number I can get a diagram for you to show you how to do this let me know.
Aug 31, 2010 | Reddy Heater-170,000 BTU Kerosene Deluxe
I have a Hayward super pump for inground pool and after 4years it went out. It is plugged in to a 110 out let for that is what the guy wired it to.
WELL IT WILL WORK OK ON THAT . 230 IS THE BEST 115 IS THE CHEAP WAY. PUMPS NEED SERVICE NOW AND AGAIN , TAKE THE 4 BOLTS THAT HOLD THE MOTOR TO THE TANK BODY ,UN-PLUG IT AND BRING IT TO YOUR LOCAL POOL PUMP MOTOR REPAIR GUY.. BEARING & SHAFT SEAL AROUND $75. ..USE YOUR ZIP CODE IN YOUR SEARCH .. AND PRIME THAT PUMP AFTER ANY REPAIRS !!
HEY IF'N I WAS OF HELP ..VOTE .. JAY
May 26, 2010 | Hayward 1 Hp Max - Flo Swimming Pool Pump
No compression release; can't turn over
well if you can pinpoint the leak you may be able to repair it. if you test the compression in the engine you can tell if the rings or valve are bad. you need a specail tool to test compression, $45. let me know what you find
Mar 17, 2009 | Toro Lawn Mower With Toro Power Tools
Toro blower model 51591 electrical prong melted. help!
The answer is wrong. This model and other Toro blowers with the plug built into the body (as opposed to the new design with plug on cord) has this problem when the plug does not completely mate with the cord. This happened to mine too. Unfortunately Toro does not provide a replacement part. HOwever, perhaps the new designed cord will fit as a replacement, but I am unsure of this. When my plug melts completely I will try that.
Dec 22, 2008 | Toro Blowers Rake and Vac - Electric...
Hello, I want to know where i can go for repair my laptop. He doesn't open. I receided it for my birthday in september 2008. I live in Canada and my zip code is J1N 2J8. It's in Sherbrooke (city)...
Just enter your zip code in the box on this side ------>>> where it says repair service, and you should find any repair services near you. Hope this helps you find what you need.
Nov 27, 2008 | Computers & Internet
My zip
There are too many to list for your area just enter your zip code into the boz that says repair service and it will bring up all the ads for your area as they have about 10 pages all covering different areas.
Jun 29, 2008 | Panasonic PT-47WX49 47" Rear Projection...
Toro "Toro" Super Blower/Vac Logo
41 people viewed this question
Top Toro Garden Experts
Jim Parker
Jim Parker
Joseph Mueller
Joseph Mueller
lnbn1975
Are you a Toro Garden Expert? Answer questions, earn points and help others
