Is there an easy way to tell if my intertherm furnace is programmable for variable fan speed. It has about 6 wires into the motor so I'm guessing it can . Or what do I need to do.
  • 30 Answers
I have never heard of a variable speed Intertherm. If it has multiple wires it is likely just an adjustable fan where you can use a different lead for a different speed. Usually black is high blue is med. hi, red is low, ect. Check your wiring diagram on the furnace door. Why do you want to change the speed?
Posted on Nov 24, 2008
Nordyne furnace FEH017HA-04 the fan runs full force when the ac is on but half speed when the furnace kicks in
That is probably normal if it is electric heat to slow the air over the heating elements. Even some gas units do this. Check to see if the unit blower motor has wires for multiple speeds.
Oct 24, 2013 | Coleman Intertherm Nordyne Miller Furnace...
Intertherms fan stalls
If this fan uses a run capacitor, I'd check it and its wiring and connection first. No problem there ? Then ohm out the motor winding in the fan. If this is a variable speed ECM motor Then you may want to check the module for a burned out thermistor (inrush current limiter) or even check the wiring harness on the motor for tightness. If the thermistor is defective, you can order one from Digi key for less than $2 + postage, adn then solder it in or pay about a grand for a new motor.
Feb 22, 2013 | Intertherm Heating Cooling System 15kw...
Bryant programmable thermostat doesnt keep the temp have to put it on fan instead of auto
My guess is that you have gas heat. If this is the case, sounds to me like your main control board or depending on age of furnace, fan controller is not working. With gas furnaces, it utilizes 2 fan speeds. High for cooling, & Low for heating. Your thermostat only controls the High speed - switches when you turn your fan on & when there is a call for cooling. The only other thing I can think of is it is possible that the Low speed windings on the blower motor are open causing it to not turn on. Most motors have 3 to 4 speeds & only 2 are used. Switch the heat motor wires in the furnace (on the control board) with one that is on a spare terminal.
Feb 21, 2013 | Bryant Cube Series 1 Stage Heat/ 1 Stage...
I have a E2EB-017HA air handler and I want to change it to a variable speed motor. Is this possible
Some companies do sell a variable speed kit. It includes the motor and controls. Get your model and serial number of your unit and contact your local Payne dealer. The can locate the proper kit if available for you.
Feb 03, 2013 | Intertherm E3EB-017H Furnace 17Kw 2
Intertherm furnace has no flame
It has an ignition control problem. Check the ignition transformer, relay, and the fuse.
Oct 28, 2012 | AO Smith Intertherm Furnace Motor 1/8hp...
Have an Intertherm thermostate in mobile home controlling gas hearing and elec ac. Blue wire to thermostat connects to the "A" terminal on the thermostat...Blue wire goes to a terminal on the...
If there are only two wires going to the thermostat? Then you will not be able to use a Digital Programable stat. Intertherm and Coleman furnaces do the switching different than regular furnaces. They use the switching from heat to AC at the furnace with the rocker switch. They use the thermostat to either break the connection or make the connection. They use a heating only thermostat.... Hope this helps
Jan 02, 2011 | Intertherm P3RA-048K Air Conditioner
Intertherm Gas Furnace MiMB 077ABW We have just had this furnace and heat pump installed and we find that it takes at least 1 1/2 to 2 hours in the morning to bring the heat up from 15 Celsius to 21.5...
Yes it is. I hear that all the time how this unit does not heat/cool like the old one. Energy efficiency, variable speed motors, your pocket book will thank you!!
Aug 10, 2017 | Heating & Cooling
I HAVE AN INTERTHERM FEB-017HAC-04 ELECTRIC FURNACE THAT IS PRODUCING HEAT,BUT THE FAN DOESN'T SEEM TO WANT TO KICK IN. THE BLOWER IS SET TO AUTO.
Probably a time delay relay fan switch not working.
Could be a bad low speed winding in the fan motor.
Set the wall T-stat for ON fan and see if it works.
Mar 02, 2009 | Intertherm P3RA-048K Air Conditioner
Intertherm furnace not getting hot after motor swap. PLEASE HELP
You already diagnosed it yourself. The motor may have been the same physical size but it operates at a higher speed and doesn't remove enough heat from the furnace. You need to have the right motor installed period.
Jan 17, 2009 | Intertherm P3RA-048K Air Conditioner
Blower speed
Yes usually the black is high speed, the blue is low and red medium speed. plug the black wire from the fan motor to where the blue wire is, then put the blue where the black wire was
Jan 10, 2009 | Intertherm P3RA-048K Air Conditioner
Heating & Cooling Logo
145 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Tim Whalen
