Question about LG WM-2277HW Front Load Washer
LG Tromm Not Dispensing Bleach
Several times, after a bleach load, I noticed my bleach dispenser still full of bleach. Was using HE bleach, then noticed on a different website that the gel bleach (which HE bleach is) is to thick to go through the siphon. Started using regular bleach. Worked several times in a row. Today, bleach was still in the dispenser again. LG said check intake water hoses. I did. No crimps. Any other ideas?
  • 5 more comments
  • jdsmith77 Jan 16, 2009
    My LG frontloader is having the same problem. The bleach stays in the dispenser tray. Does anyone have an idea what I should be looking for?
  • DesignerA Jan 27, 2009
    This washer not dispensing bleach of any description...
  • Anonymous Jan 28, 2009
    We just got our LG Steamer installed on Saturday January 24th, 2009 and it is not despensing bleach either. It takes three washes in a row to dispense all of the bleach. Also my Tub cleaning cycle is not working. Vernon, Atlanta Georgia.
  • King Faruc Jan 29, 2009
    The washer may not be dispensing the bleach and always have liquid in bleach tray after cycle is completed.
  • Anonymous Feb 21, 2009
    Mine is doing the same thing. I thought it was because I was using the thicker bleach, but I bout the regular kind and it still won't dispense
  • Anonymous Feb 23, 2009
    Have same problem. Not dispensing bleach.
  • Wendy May 17, 2014
    having the same issue as well, plus the detergent cup and fab soft are full of water at the end of the cycle
    New Friend:
My wife has been complaining that the bleach and fabric softener dispenser still had water in it after washing. After removing the top to the washer I found that there are 4 components to the dispenser. 1. the solenoid (part of a 3 solenoid bundle) for the cold water, 2 the controller to the solenoid 3. The hose from the solenoid to the dispenser, and 4. The dispenser. After checking that there were no kinks in the hoses. I checked the solenoid found it had power at the right time but the flow was low. I shut off all the water and disconnected the lines going into the back of the washer I found that the cold water filters were clogged. After cleaning them (there were 2 for each hot and cold) The washer worked correctly.
Posted on Aug 09, 2014
    New Friend:
  • 3 Answers
I also had the same problem of bleach not dispensing and water residue in detergent cup after each wash. After reading several blogs about water pressure in the LG washers, I checked my water hoses to the washer. Over time, my metal sheathed lines had kinked near the input due to sagging because of the weight of the hoses. When hot water went through, they sagged more, cutting the flow. I reconfigured the hoses to support them to avoid sagging. Now my bleach dispenser works and my detergent cup is no longer filled with residue water after each wash.
Posted on Nov 30, 2012
I will figure it out mine is doing the same - sherman@all-waste,com
Posted on Jul 25, 2010
How do I get the bleach dispenser to drain?
Hello Denise C - There are several things that could cause the bleach to not dispense into the washer. Are you sure the liquid in the dispenser after the wash is bleach? If it is pure bleach, the solenoid that lets the water into the dispenser is not working. This solenoid is located on the back of the dispenser. It only gets voltage during the dispense time and fills the bleach dispenser with water. The bleach dispenser fills while the washer is filling for the rinse cycle.
When the washer begins to fill for the rinse cycle, the bleach solenoid is energized and water flows into the bleach dispenser cup. When the cup is full the water siphons out and bleach and water flow into the tub.
If the liquid in the bleach dispenser is pure bleach you may need a technician to diagnose and repair the problem. The voltage will have to be tested to the bleach solenoid and a volt meter is required.
If the liquid in the bleach dispenser is water you probably need to clean the dispenser cup. Scum will build up in the siphon tube and stop the liquid from going into the washer tub. The incoming water will dilute the bleach and overflow the dispenser cup and run into the tub.
Remove the insert from the bleach and fabric softener compartments. Clean the bottom of the insert and the bleach and fabric softener compartments. Reinstall the insert and put the drawer back inside the washer.
To test the siphon action slowly pour water into the bleach compartment. When the water level goes above the maximum line stop pouring. The water should all drain out. You may also test the fabric softener compartment the same way.
I do hope this information proves to be helpful.
Jan 01, 2013 | Frigidaire Affinity ATF7000E Front Load...
Bleach not dispensing
Make sure it is actually bleach, and not water. Most models with a bleach dispenser in the drawer actually dispense the bleach by adding water to the cup and allowing the mixture to overflow into the machine- so that pure bleach doesn't land on your favorite shirt before there is any water in the machine.
Jul 30, 2009 | LG TROMM WM2688H 4.0 cu.ft. Front Loading...
Bleach and Fabric Dispenser not working
Got a Brand new LG ~ WT5001CW toploader today. I did 2 loads of wash. Theres a Bleach Dispenser on the top left side but I didn't use it. In the middle of my 2nd wash I noticed the bleach dispenser was full of water. I thought well maybe after the rinse and the spin it would take the water out. Well when the cycle was complete the Bleach Dispenser was still full of water.
I took the Bleach dispenser out and checked the holes to see if anything was plugged, didn't look like it. Was wondering if anyone knew how to solve this problem or do you think that since I took the bleach dispenser out and put it back it that it might work for my next load ??
Any opinions will be greatly appreciated !! Thanks Much !!
Apr 26, 2009 | LG Washing Machines
Whirlpool bleach dispenser not dispensing properly
It sounds like the bleach dispenser is clogged or has a crack in it. What we do, is when we bleach our clothes and I know that this is extra work, but we wait until the washing machine is full of water, then add the bleach directly to the wash.
Jan 18, 2009 | Whirlpool Ultimate Care II LSQ9549L Top...
Bleach Dispenser not relaesing bleach during cycle
I have the same model # and same problem!!!
Worked fine for few months and then it started.
Sears technicians came twice but couldn't fix the problem. Now they have ordered a new dispenser door. Sears said they changed the design. Will see if the new door will work. Hope that helps.
Jan 12, 2009 | LG WM2455 Front Load Washer
Dispenser problems
Open dispenser drawer and push down on center plastic tab at back of dispenser to allow you to take dispenser out of machine. Take the plastic pieces off and clean them. (they need to be clean in order to siphon the bleach, softener, etc out. If there is water left in them, the water fill valve is OK. Cleaning should fix your problem. If you are using concentrated additives, try diluting them a bit with warm water when you add them to the dispenser. Remember, only one tablespoon (max) detergent, one teaspoon (max) fabric softener per load.
Oct 18, 2008 | LG WM-2277HW Front Load Washer
Bleach not always being emptied, bleach marks on clothes, bleach sometimes runs right out when you fill it.
The dispenser works on a siphon principal. If you over fill the cup it will start the siphon and empty before it should. If that's happening you're using way too much. You only need about a tablespoon of soap, softner and bleach for a full load.
Aug 11, 2008 | LG TROMM WM2688H 4.0 cu.ft. Front Loading...
Fabric Softener & bleach dispensing
The control board program has many sensors built into the unit to determine when to dispense the bleach and the softener.  LG tech documents doesn't list when these liquids are dispensed so there must be a program that matches the current operation and loads of each wash program.  That's the best answer I can give you at this time.
Jun 05, 2008 | LG WM2688H Front Load Washer
LG WM-2277HW Front Load Washer Logo
2,696 people viewed this question
Top LG Washing Machines Experts
Gerry Harvey
Gerry Harvey
Marvin
Marvin
Are you a LG Washing Machine Expert? Answer questions, earn points and help others
