Can't find cd drive
Windows cannot load the device driver for this hardware. The driver may be corrupted or missing. (Code 39)
Click 'Check for solutions' to send data about this device to Microsoft and to see if there is a solution available.
  • Dyanne Reinis
    Dyanne Reinis May 11, 2010
    could you tell me the make and model number please and il try to find a link fo ya to sort it xx
    Sergeant:
    Champion:
  • 334 Answers
Actually windows should recognize it as a cdrom anyway unless you haven't check the settings on the back. There is three settings "master" "slave" and "cable select" if it is set to the same thing as a hard drive it won't be recognized. Some are connected to the same connection i would set it to cable select and it will set its self.
God Bless Greg
Posted on Nov 24, 2008
    Mentor:
    An expert who has written 3 tips or uploaded 2 video tips.
  • 162 Answers
Try this solution > http://support.microsoft.com/kb/314060
My DVD rom drive is not working I cannot "see" it on the system I have this error message "windowns cannot load the device driver for this hardware. the driver can be corrupted or m missing error code 29...
Check in device manager. To do this. 1st right click my computer, 2nd Click properties, 3rd click hardware, 4th click Device manager, 5th check that the computer is seeing the DVD/CD-ROM drives by double clicking the DVD/CD-ROM drives words or click the + symbol next to DVD/CD-ROM drives, the drop down menu will list your device if it’s there. If a device is listed double click the device. If it says it’s working properly click driver in the top bar and uninstall, then re-boot, the system will re-load the driver on re-booting. If the driver was corrupt it will re-install it correctly.
If the system cannot find the driver on re-booting it's missing from the systems file, go to the Support Fujitsu site and download and install the driver. Its free all you have to do is put the laptop details in the appropriate boxes and all the drivers for that laptop will be listed.
From your description of the error message it’s no doubt a corrupt or missing driver.
Hope this helps.
Feb 24, 2010 | Compaq Presario V4000 Notebook
Error 39 canot load the driver
Uninstall and reinstall the driver
Uninstall the driver from Device Manager, and then scan for new hardware to install the driver again.
You may be prompted to provide the path of the driver. Windows may have the driver built-in, or may still have the driver files installed from the last time that you set up the device. However, sometimes, it will open the New Hardware Wizard which may ask for the driver. If you are asked for the driver and you do not have it, you can try to download the latest driver from the hardware vendor’s Web site.
  1. On the device Properties dialog box, click the Driver tab, and then click Uninstall. Follow the instructions.
  2. Restart your computer.
  3. Open Device Manager, click Action, and then click Scan for hardware changes. Follow the instructions.
Nov 27, 2009 | Lite On (LTN486S) Internal 48x CD-ROM...
DVD/CD drives failed to load
go to 'device manager' from 'control panel' and find your drive
right click on it and choose 'update driver software'
if the option is not there choose 'properties' and go 'driver' tab and choose 'update driver software'
restart
May 08, 2009 | Computers & Internet
GMA 4082n device driver not working properly code 39
First go into Setup (usually F1,F2 or del) at start-up. See if your drives show up there. With Windows running, right click My Computer, left click Properties, left click Hardware, left click Device Manager, left click DVD/CD-ROM drives. Also check IDE ATA/ATAPI controllers. Do the drives show up there? If they do right click on drive and left click Update Driver. If they are not there go back to System Properties and left click on Add Hardware Wizard. This will search for devices. It may ask you to insert Windows CD which of course you can not do because the drives don't work. Try a different drive. When you cleaned out your computer did you delete or uninstall Office? That may be what caused this problem. None of this may work but it is a starting point.
Jan 06, 2009 | Dell Dimension 4600 PC Desktop
PC Saying there is a fault (code 39)
use this www.cdr-zone.com/forum/about4719.html&highlight=filtercheck
the 4.6 tool. download it. then run then click yess to all and restart. you havw corrupted upper or lower filter driver
Feb 10, 2008 | NEC ND-3540A DVD RW Dual Layer Burner
Pioneer dvd-rw dvr-k17a
Hi, the error code that you have on the CD/DVD drive is a known issue from Microsoft. The error code means "Windows cannot load the device driver for this hardware. The driver may be corrupted or missing. (code 39)".
Since you are using a Toshiba laptop; you can click on this link http://tinyurl.com/toshibadvd and click on the repair tool on the resolution. This is applicable on both Windows Xp and Vista and will delete the upper/lowerfilters on the registry.
In case that the error code still exist you need to manually delete the upper/lowerfilters under the registry by clicking on this link http://support.microsoft.com/kb/929461/en-us . You need to go the "Run" screen then type in "regedit" and click OK or hit the enter key.
This will surely fix the error code that you have on the CD/DVD drive.
Thanks
Nov 13, 2007 | Toshiba Satellite A100-S8111TD Notebook
Computers & Internet Logo
65 people viewed this question
David Payne
David Payne
