Question about RCA F27440 27" TV
Bottom of picture is cut off
Looking for a way to adjust the screen size. the bottom part of the picture is being cut off. you know when you're watching espn and the scores scroll at the bottom of the screen. Well, I see about half of it, and it drives me crazy. there is no adjustment on the back of the unit or in the on screen set-up. other than that, the picture is great. about 3 years old
    Sergeant:
  • 308 Answers
Usually when the vertical starts shrinking slowly, it is due to capicators getting out of tolerance in the vertical output section of the chassis. If it can be adjusted out through a service menu, you'll probably need a tech with the right equipment to perform it.
Posted on Jan 01, 2007
E472VL picture on HD cable channels does not fit screen correctly-how can we fix it?
Consult the manual---the answer lies in the size controls being grayed out so you cannot adjust or try to adjust the vertical size!
Mar 28, 2012 | Televison & Video
Watching espn hd, the picture cuts off on one side. How do I adjust this? The ESPN bug is well within the border in the right hand lower corner, but a chart that comes on perodically during play...
There's a resolution/aspect ratio you can adjust in the picture menu, or straight from the remote. Choose the size you want on ESPN that best fits the picture while watching it.
Jun 16, 2011 | Sony FD Trinitron WEGA KV-30HS420 30" TV
Picture too large for screen
It appears that on this television you can only adjust the picture size when you are using the twin picture feature. You must adjust the picture size with your other remote control. Since I do not know whether you are connected to a cable box or a satellite tv box or a blu ray player or a DVD player I cannot be very specific. On your other remote control you should had an hd zoom button, aspect, format, ratio, #, or etc. Those buttons change the picture size. The other factor determining picture size is the resolution the equipment connected to your tv is set to. This tv supports 1080i but you should also try setting the connected equipment to 720p or 480p or 480i. Also the connected equipment may be connected to your tv in two places so make sure you are on the correct selection using the tv video button on the Sony remote.
May 06, 2010 | Sony FD Trinitron WEGA KV-36HS500 36" TV
Vertical needs adjusted. both bottom and top of screen are cut off
On the remote look for a button labeled aspect,zoom or picture size. Press that button repeatedly until the picture is the desired size.
Nov 21, 2009 | Sony BRAVIA KDL-40XBR2 40 in. LCD HDTV
Picture is too big for the screen
go to page 37 of the manual and read through to RESET TO FACTORY SETTINGS
Thanks for using FIXYA
May 30, 2009 | Syntax Olevia 532H 32 in. LCD HDTV
VIZIO GV4VL cuts off the bottom of screen
on the tv's remote you have a button which says one of a couple things. 1) pic size 2) ratio 3) zoom 4) aspect. using that button push it a couple of times until you get to either 16x9 or full depending on the brand of tv you have
Jan 21, 2009 | Vizio GV42L 42 in. LCD Television
Picture is cut off on the bottom of my Hitachi 57F500
Verical position is hard to adjust and is in service menu. A service manual will get you there, but you might get lucky with the vertical size adjustment. If you open the front of the TV, the vertical size is adjusted with a knob on the deflection board. Remove the speaker grille and take off the access panel. You will see two knobs, one horizontal and one vertical. Be careful, those red wires have 30,000 volts on then, don't touch anything but those knobs. If its just an adjustment, the v-size knob will fix. Set it so ESPN ticker is just above the bottom of the screen. *Service mode - the manual tells little but entering is done by "press and hold the input button, press the power button, release both after you hear HV come up" .. the v-pos parameter is in there, but this manual doesn't say where or how to adjust, procede at your own risk. If you get into trouble, pull the power so you don't save any settings. I believe you just navigate through the menus to find the parameter and use arrows to adjust. Enter may save. Sorry the service manual I have tells nothing much.
Dec 07, 2008 | Hitachi 57F500 57" Rear Projection...
Picture Size
Also, try adjusting the settings on your cable box, not on the TV. The usually solves the problem and will then allow you to adjust the size of the picture.
Mar 03, 2008 | Samsung LN-S4092D 40 in. LCD HDTV
RCA F27440 27" TV Logo
328 people viewed this question
Top RCA Televison & Video Experts
Steve Allison
Steve Allison
matt martin
matt martin
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
