Question about JVC HD-52G886 52" Rear Projection HDTV
JVC HD-52G886 TV - can't view any channels
I just bought this TV (used) and I can't get it to tune into any channels. I found instructions on the web for troubleshooting problems, so I set the TV into Service Mode. It shows the following error codes - TUN: NG9, Sync M:NG, S:NG and HDMI:NG2. All others are ok. It looks like the TUN:NG9 is what the problem is with the tuner. How can I fix the TV? Where can I get the service manual?
  • Anonymous Dec 07, 2008
    i have no remote and would like to manually set the t-v to channel #3/4 for my cable service to work on auto tuner.
SOURCE: hd 52g886
Your Lamp is burned out.
Posted on Sep 07, 2007
BMW Rider
  • 232 Answers
SOURCE: jvc hd ila model hd 52g886 red light blinking, and wont turn on
Hi, don`t know if you`ll be able to find this but D9405 a surface mount diode on the main power supply board is a known issue for yours and many other models, it has to be re-soldered not replaced, other joints in area may also need to be "touched up", other than that I had one where connector CN310 was not seated correctly, one side of plug was cocked way up, other than those 2 you may have a bad ballast (board that the lamp is connected to), Be sure that the lamp door is securely closed as they have a switch built into them and if the switch is not closed the set WILL NOT start, hope this helps you out, BMW Rider
Posted on Dec 12, 2007
Slinteriors
  • 8617 Answers
SOURCE: replacement lamp
www.alltvlamps.com should have the lamp your needing
Posted on May 18, 2008
  • 556 Answers
SOURCE: my tv don't have sound', who can help me !
check and see if you have the center channel on in the menu if you do turn it off and also see if you have the internal speakers turned off if so turn them on.
Posted on Sep 15, 2009
  • 5 Answers
SOURCE: Last night my JVC HD-52G886 picture turned dark
SRP-9022A main power board is bad, usually the cp9211 fuse is bad on this board. Board runs about $150
Posted on Jan 12, 2010
JVC HD-52G886 HDTV Television screen is dark
usually it is the lamp this set uses, has it been replaced or is over 2 years old?
Oct 29, 2012 | JVC HD-52G886 52" Rear Projection HDTV
HOW TO REMOVE THE SCREEN OF A 52G886 JVC TV
This set should never need cleaning--only has a single optical lens--I suggest you do not attempt to take it apart at all. l cannot imagine any possible reason or benefit from doing this.
May 01, 2012 | JVC HD-52G886 52" Rear Projection HDTV
My JVC HDTV station is locked on Channel 3, How do I unlock it from this station
Hello
To unlock the panel lock of your JVC tv do the following.
Turn on the JVC television and press the "Menu" key on the remote control.
Use the Up and Down or Channel buttton to toggle through thre menu selections until V-chip appears.
Stop on V-chip and press the right arrow button to display a padlock icon
Enter the four-digit code by pressing the numbers on the keypad. If a code has not been entered, the default code is 0000 (four zeros).
Press the right-arrow key to unlock the channels
Unplug the JVC television for at least 15 minutes to reset the code to 0000 if a previously set code has been lost or forgotten
OK
Mar 22, 2011 | JVC HD-52G886 52" Rear Projection HDTV
My tv don't have sound', who can help me !
Sep 13, 2009 | JVC HD-52G886 52" Rear Projection HDTV
My 52' HD television will not turn on, it is a JVC HD-52G887. The blue light comes on but there is no blinking red light. Please help
unplug the tv, then reinstall the bulb,if that doesnt work youll need a tech to help. (dont buy another jvc tv)
May 19, 2009 | JVC HD-52G886 52" Rear Projection HDTV
Is this TV HD capable?
This is not an HDTV. However, that does not mean you cannot use it to view the HD channels with DirecTV, you just wont be able to view them in hi-def. Use the component inputs from the directv tuner and plug those into the proper component inputs of your JVC. Once you see the DirecTV picture on the screen, go into menu... setup (with the directTV remote) and make sure that the only resolution checked is 480i. DirecTV with 'downconvert' those cannels to standard def, and they will still look pretty good though the component connection...
... now, in answer to your next question: "What exactly do I need to view HDTV with DirecTV?"...
1. A television that will accept 720p or 1080i signals.
2. A DirecTV HD Tuner.
3. Any DirecTV service BUT you must purchase the HD pack so that they will 'unlock' the HD channels
4. The proper cables to hook in between your DirecTV HD receiver and your HD-capable TV/Monitor. You may use either HDMI or component video cables, so long as your TV will accept them. Tune your TV input accordingly. When using component video cables, you must also run a separate cable(s) for audio...
Take care,
Rob
ps. DirecTV HD tuners do not have an RF 'out'. ("coaxial or ch3/4 connection")
Mar 05, 2009 | JVC AV-32D502 32" TV
No OTA channels
This television has an extremely weak tuner. It is very sensitive to both ghosting (multipath) and weak signal conditions, which cause it's digital decoder to "error out". Coupled with this is the decoder's long set-up time (time to actually begin a decoded video stream after signal is selected)and you find that every time the decoder loses sync it takes several seconds to reestablish normal decoding. The net result is the possiblity that the tuner will be continually restarting and never display anything. An extremely directional antenna may help. Otherwise, find a good external tuner box and use that.
Oct 03, 2007 | JVC HD-52G886 52" Rear Projection HDTV
JVC HD-52G886 52" Rear Projection HDTV Logo
118 people viewed this question
Top JVC Televison & Video Experts
Jaime Hernandez
Are you a JVC Televison and Video Expert? Answer questions, earn points and help others
