Question about Soundstream XTA880.2 Car Audio Amplifier
Amp staying in protection mode
Brand new xta880 wont stay on - the protection circuit light comes on as soon as the amp does, then goes off and doesn't come back on until I reset the remote/head unit. Same results each time. I tried unplugging my ground wire to see the effect and when I did the amp stayed in protection mode without turning off. I performed an exact switch from a alpine amp and after soundstream wouldn't work switched em right back and it works fine. The Alpine is only a 200 watt mono tho. Any ideas here? Weak ground? Not enough power to the amp? Is this amp a heavy power consumer? thanks, in advance, and happy new year!
  • Anonymous Mar 25, 2009
    im having the same problem
No, this amp is not a heavy power consumer- matter of fact it takes very little power to run.Maybe you should check the fuses on the amp to see if they are what is recommended.Also check your fuse kit to your amp- your fuse might not be big enough.If neither works take it back where u got it.
Posted on Jan 02, 2008
SOURCE:
Blue light comes on then goes red pr1.1000 MEPHIS AMP
make sure your power wire and ground wire are big enough and that they are the same gauge
Jan 29, 2013 | Car Audio & Video
ZX 1000.1 amp stays in protection mode
It is normal for them to go into the protect mode, If the speakers are not hooked up to it,
Nov 09, 2012 | Kicker Car Audio & Video
Why my jl audio 1400d amplifier stays in protective mode?
Check for a speaker wire that come come of , Or a loose grond wire on the amp or where ever you have the ground wire connected two,
Oct 31, 2012 | Jl Audio Car Audio & Video
The Ground wire is hooked up right but the red light wont go off and stay green so the amp will work. It is very frusterating all the cables are the right size its is a 1000 watt amp. I have two 500 watt...
Sounds to me like the amp is going into protection mode. Try placing one sub on the amp with very little gain. One of the biggest reason why this happens is because the subwoofers are wired wrong. What is the brand and model number for your amp?
Apr 14, 2011 | Car Audio & Video
Amp wont stay powered on as soon as bass hits in goes into pm
The amp is not geting enough current.You need to use some larger gauge cable and it would probably be best to add a small power capacitor.If your not familiar with a cap then stop by your local car audio store or google it and you will get a lot of imfo.
Sep 06, 2009 | Sony XM-2165GTX Car Audio Amplifier
Mxa422 protection
Outputs are fried. Try disconnecting your speakers and see if it still goes into protection mode. If it does then you A thumbs up would be greatly appreciated if answer is helpful for your question. THANK you and GOD BLESS
May 24, 2009 | Lanzar MXA422 Car Audio Amplifier
Protect led light
It appears that the amp is going into protect mode. To eliminate external causes, read through the following page. Let me know if you have any other questions.
Amp in Protect Mode - Troubleshooting
Oct 10, 2008 | Car Audio & Video
Sonamp 260 cuts out
Normally this denotes a protect condition. Remove the speaker wires from the back of the amp and see if the green light stays on. If this fixes the problem, then there is a short circuit in your wires, speaker level volume control or speakers. The amp sees the short and goes into protect. After a couple seconds it closes the connection again and if the short is still present it goes back into protect.
Aug 03, 2008 | Sonance Sonamp 260 MKII 2-Channel...
Why does my amp stay in protect mode?
The most common reason an amplifier goes into or remains in protect mode is shorted output transistors. To eliminate other possible reasons for it to go into protect, read the following page.
Troubleshooting - Amp in Protect Mode
Aug 03, 2008 | DHD NTX-2139 Car Audio Amplifier
Blown amp
hi, try connecting the power b+ and gnd and remote turn on cables only (dont connect rca input or any spks), if amp doesnt turn on you will have to take in for repair. no need to buy new amp, coz problem could be a burnt pcb track or even a faulty remote or FET circuit.if amp turns on then connect other cables slowly and monitor the power lite as you do connections. you may have a faulty spk load that will cause amp to stay off or in protection mode. cheers
Jul 22, 2007 | Kenwood KAC-7202 Car Audio Amplifier
Soundstream XTA880.2 Car Audio Amplifier Logo
497 people viewed this question
Top Soundstream Car Audio & Video Experts
Philip Armitage
deton8 von Splosion
Are you a Soundstream Car Audio and Video Expert? Answer questions, earn points and help others
