Question about Iwill DH800 Motherboard
IWILL DH800 power problem ??
After ceaning dust in case machine won't start.
After pushing power button, all LEDs shine normally, CPU and other fans works normall, HDD LED shine continusly, there is no beeps and other sound, resetting CMOS (by jumpers and by removing battery) doesn't work.
  • Iwill Master
  • 4,806 Answers
Try removing, cleaning the contacts and reseating the memory, see if that works
regards
Posted on Nov 24, 2008
I have ( IBM ThinkCentre 80847eg ) after starting power it shutdown automaticly after 30 seconds so i push power button again ,then it takes 3 minutes to get windows logo . so what's the problem
OverheatingWhen the CPU overheats then it will shut down (i.e. thermaloverload) and won't boot up again until it has cooled down. If this is theproblem is not fixed then the CPU will eventually fail.
A faulty fan causes the problem or the fan and heat sink assembly are cloggedwith dust.
Check the CPU fan to see if it spins freely, if not replace the fan.
If the fan and heat sink is clogged with dust the remove the dust and make surethe vents are clear and dust free. Use a small brush and can of compressed airto do this.
Jul 29, 2012 | Computers & Internet
Hp 300 12z. Desktop i relocated and plugged everything back in. I push power button and the fans start to run however after 45 seconds they shut off and screen goes black. What could be wrong.
Jul 07, 2012 | Computers & Internet
Won't start but CPU fan vibrates but will not go full blast. Intermittant
It appears you have a faulty CPU fan and it is causing the CPU to overheat and shut down.
I suggest you replace the CPU fan. remove any dust from the heatsink and put new heatsink compound on the CPU/heatsink.
May 06, 2012 | Compaq Presario S5000NX PC Desktop
If a warning light indicates the CPU is not functioning, does that mean I have to get a new processor?
Yes! judging by all the cascade break downs, I would suggest replacing the motherboard, HP has a history with motherboard issues.
Mar 29, 2012 | HP Computers & Internet
Toshiba A135-S4527 starts to power up then shuts down.
Mar 08, 2012 | Toshiba Satellite A135-S4527 Notebook
I've got an Acer Travelmate 292LMI. My problem is: the notebook starts (leds on) for only a few seconds (I can see the acer display that preceeds the boot) but immediately it is dead. Only the AC leds...
It could be an overheating CPU problem.
When the CPU in the computer or laptopoverheats then it will shut down (i.e. thermal overload) and won't boot upagain until it has cooled down. If this is the problem is not fixed then theCPU will eventually fail.
A faulty fan causes this problem or the fan and heat sink assembly are cloggedwith dust.
Check the CPU fan to see if it spins freely, if not replace the fan. If the fan and heat sink is clogged withdust the remove the dust and make sure the vents are clear and dust free. Use acan of compressed air to do this.
Sep 06, 2011 | Acer TravelMate 292LMi Notebook
Won't Start
This happened to my to my HP Media center Edition PC. I'd have to unplug the power from the outlet, let it stop flashing and the power up again. It would run for a short time and then shut off with the annoying amber / blue flashing light.
I found it was a heat problem on mine - specifically, the CPU cooler. After shutting down and opening the PC, check to see 1) if the CPU fan is running smoothly and 2) if there is a lot of dust and dirt on the CPU cooling fan and heat sink (and rest of the case for that matter).
Gently clean / vacuum the insides of the case AND power supply as best you can. Carefully vac the fan blades and heat sink to clear the dirt and dust that prevents the heat from being blown away by the fans.
When complete, you might even want to take the PC outside and reverse the vacuum so that air can be blown into tight places in the case. A can og compressed air can do the job instead, too.
Reassemble and start up as normal. Good luck!
Sep 18, 2009 | HP Hewlett Packard Pavilion Slimline...
Problems after Power Management changes
Experience a similar problem with a FIC MB. I cleared CMOS then removed MB battery for 1 hour. Restarted the unit with just the video card and hard drive installed. After unit rebooted I added sound card, network card, etc.
Jan 06, 2008 | FIC P4M-915PD1 Motherboard
FIC P4M 915G/PD1 system fails to Power Up
You should always try a new power supply if possible. After all, it is one of the most likely components to fail - it's got moving parts (one or more fans), just like your hard drive (spinning platters), one of the other most likely parts to die.
That said, in this instance it probably is the mobo. FIC made great motherboards, but they got out of the business so you won't find the same one anywhere. If you have to replace it, you may be able to get out of a Windows reinstall by getting a motherboard with the same chipset, which looks like a 915/G, though any 915 based board might do. You may still need to do a repair install, but in many cases the same chipset allows you to boot and then just load all the new different drivers for the new board.
Jan 06, 2008 | Intel Motherboard
Iwill DH800 Motherboard Logo
100 people viewed this question
Top Iwill Computers & Internet Experts
Alun Cox
David
David
wahidmeer
wahidmeer
Level 1 Expert
Are you an Iwill Computer and Internet Expert? Answer questions, earn points and help others
