Question about Mitsubishi WT-42315 42" TV
WT-42413 continues to shut down. Need to wait 15 minutes to restart
This appears to be a common problem with this Mitusbishi TV. I had a 2003 WT-42413. It would run anywhere from 20 minutes to two days and then quit. If this is happening to you, do the following. Press the menu and input keys on the front of the TV at the same time. The green light on the front panel will flash. Notice the two digit number that is flashing. It flashes a series of times, pauses, flashes for the second number and repeats for about 30 seconds. My code was 2,3. This is a problem with the CRT deflection. Basically, the TV is registaring there is too much current, so the protection circuit is shutting it down. After 15 to 20 minutes the TV resets and can run again. Most repair people I found replace at the board level, not component. This repair is very costly. Alot of it is in the labor, because the repair man has to redo the convegence setup per factory. There are special codes they enter in your remote to do the factory convergence. The user convergence is just minor adjustments. My repair man spent over two hours doing this for both the 'regular' mode and the HDTV mode. Two separate convergences that should be set up if you use HDTV. He asked me if I wanted to skip it to save money. After this was all said and done, the repair bill was $750. I held off paying until I made sure it worked. It did not. I then swapped them for a 2004 WT-42315 they had on a trade in with the same problem. However, the board fix above did correct this one. So, my Stereo Store was gracious and did the swap at a discounted price of $500 (yes, less than the repair that did not work). This TV is working great. Of course, many are saying for that money, just get a new LCD, but I was a fool who had a cabinet built to fit it perfectly. With my home being only three years old, did not want to hack on the cabinet yet. Bottom line, if you have this problem, and your TV is out of warranty, it may be best to buy a new LCD or find a repair man that can replace on the component level. Don
End of year Followup: 2004 TV I swapped for is still working great. No issues of any sort.
Happy New Year,
Don
Posted on Dec 31, 2007
Mitusbishi dlp tv shut off
hi when you replace the lamps, the lamp counter needs to be reset,thanks
shaun
Jun 28, 2017 | Mitsubishi WD-73737 73 in. HD-Ready TV
When turned on mitsubishi WT-42413, it turns off itself within a second. any help?
Check you -24and + 24 on power supply and you green fuses if open fuse replace fuse and the stk394-250 good luck
Jan 16, 2011 | Mitsubishi WT-42413 42" Rear Projection...
Mitsubishi WT-42413 Red Convergence will not move left right
U check all the resistors with the Ohm Meter?All the resistors u check it in tolerance?Resolders all the resistors,so it make good resistance for the ICS?U do all these steps,u still have problems,Ur ICS some how it shorted it dead,again.
Apr 02, 2010 | Mitsubishi WT-42413 42" Rear Projection...
Model D52W135D shuts off and restarts
one big resistor is on power supply you need resolder
Dec 16, 2009 | RCA D52W136D 52 in. TV/DVD Combo
Jeep liberty will shut off and gives a no buss indication light on dash. sometimes restarts and sometimes you have to wait 10 or 15 minute to restart
a bad crank sensor shuts off while going down road. then restarts after 10 minutes, but only until it happens again.
Oct 13, 2009 | 2005 Jeep Liberty
Mitsubishi WT-42413 Blue Green and Red Line
there is a section in the tv working just to keep the screen fitting top to down (vertical section) some capacitors are dry now in that area. this one has not to be a expensive job in the workshop. Try estimates
Apr 14, 2009 | Mitsubishi WT-42413 42" Rear Projection...
Wt-42313
there probably is a fuse blown. but something made the fuse blow. If you can take the back off and find out if one did blow and the location for it i can probably help you further.
Sep 22, 2008 | Mitsubishi WT-42413 42" Rear Projection...
Power on
From what you have said it seems like the thermal fuse of the set is down... You will have to replace it and then check if it works..Post back if you need more help..
Good Luck!
Jul 16, 2008 | Mitsubishi WT-42413 42" Rear Projection...
Mitsubishi wt-42413
No you have to push the buttons on the set that say menu and the button that says Input or device both in together for 8 seconds to initiate the self diagnosis feature.
Apr 26, 2008 | Mitsubishi VS-45607 45" Rear Projection...
Mitsubishi WT-42315 42" TV Logo
234 people viewed this question
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
