Question about Brother DCP 115C All-In-One InkJet Printer
How to print picture using 10x15cm photo paper? usually the pictures printed only half
  • 13 Answers
Hi
1) when you begin to print have you set the paper size to the size you require ?
2) If not when you press print a grey box appears to comfirm printing yes!
3) press properties top right of page
4) open tab basic
5) Alter paper size to correct size
6) Also check your paper setting on the programme you are using to print from,
7) Also that the orientation is correct "portrate or landscape"
grandpaben
Posted on Dec 08, 2008
Why does printer only print half of the picture
Your paper size may be samller then the size of the image you are printing. Try changing the size of the image or size of paper to match.
Aug 12, 2014 | Sony Picture Station DPP-FP90 4x6 Photo...
I can print on plain paper but when I use photo paper it tells me there is a JAM although the paper is barely in the printer.
Do not mix photo paper in the feed with any other type paper. Also, when you attempt to print, specify what type of paper you will be using to print pictures. Plain paper usually prints with no problems.
Dec 01, 2009 | HP Officejet Pro L7590 All-in-One InkJet...
Photos print wet and smudged
all the dx /cx range do this when printed on the high quality settings you just have to let ink dry about half hour or use a lower seting when you print on gloss paper hope this helps
Dec 07, 2008 | Epson CX8400 All-In-One InkJet Printer
Pictures printed from computer are pale and faded
Are you using photo paper to print your pictures? If you print your photos on regular paper the ink on the photos can bleed or run together in the paper fibers. Try using paper made to print photos and see if that helps
Dec 05, 2008 | Office Equipment & Supplies
Picture only prints on one half of page
Try printing a testpage just press print + cancel and make sure you have a paper loaded
Nov 15, 2008 | Kodak EasyShare Thermal Photo Printer
Printing is printing blank sheet of paper
Lots of reasons here but usually it is because the software you are using to print is not compatible with the operating system anymore. Example: you used MS Photo Editor which was discontinued in 2003 and never supported under Windows XP. The one function that is broken is printing...it looks like it printed but a blank sheet of paper comes out. (exactly what you described)
Instead, use MS Picture and Fax Viewer or the follow-on product, MS Office Picture Manager.
If you remove the MS Photo Editor application under Control Panel/Software Programs then your picture files will open with a different (more print compatible and friendly) program.
Jun 21, 2008 | HP OfficeJet 6210 All-In-One InkJet...
Epson RX520 dont print the full picture
It's a problem with the paper not feeding straight. The printer will make a pass & sense the width of the paper & print accordingly. If it feeds in crooked then it sees it as being narrow & only prints to that width. Happens more easily with heavy photo paper.
Apply a bit of pressure to the paper as it feeds & it's happy days.
Feb 20, 2008 | Epson Stylus RX500 All-In-One InkJet...
PHOTO paper
The HP printer was prepared to use HP's photo paper to print borderless pictures among other things.
If you use a third party photo paper, try using A4 size, position the picture in the paper using MS Word or another WYSIWYG program and, after printing, cut the picture in the right size.
Dec 31, 2007 | HP PSC 950 All-In-One InkJet Printer
Brother DCP 115C All-In-One InkJet Printer Logo
115 people viewed this question
James Cagle
James Cagle
Samyfam
Samyfam
Jim Keysor
