Question about Wurlitzer Jukebox CD Player
Rowe CD Jukebox
I have a Rowe CD Jukebox. It sometimes skips when it plays a CD. I open the box and can sometimes hear what appears to be rubbing when the arm is down. If apply light upward pressure to the arm, it stops rubbing and plays fine until a new cd is selected. Is this something I could fix myself, or should I get service. Thanks
  • Brian
    Brian Nov 25, 2008
    Thanks for the comment. Is there any other options?
  • 1,879 Answers
Since it is a CD Player (compared to the old jukes where there are some adjustment screws to play with), better have it serviced.
Posted on Nov 24, 2008
    Sergeant:
  • 291 Answers
Check inside if any part is loose or any screw has wornout.just make it tight and checkout.if it still makes such noises.do not use it further just take it to the repair center and get it serviced to avoid further problems.as this is common problem and gets resolved after servicing.not to worry. thanks.
    Scholar:
  • 126 Answers
Hello bschad,
As you may know CD's are read via a laser light. When you apply light upward pressure you are basically aligning the arm so the laser is able to read the spinning disc without missing bits of info on tha disc. It sounds like a bushing may be worn in the actual arm assembly. If you are confident with your skills and have the correct tools, you may be able to fix it, however, unless you have a diagram showing all the parts I would have a tech come to the house. I am looking to see if I can find a diagram for you. Will post back.
  • Slick54 Nov 24, 2008
    You can purchase a service manual here http://www.jukeboxparts.com/ami-rowe.htm
    I found another site but they are asking a minimum of $ 89.00. As I said, if you are confident with yuyour electronic skills and you have the manual you can attempt the fix, but I would seriously consider a tech as this is an electronic peice of equipment and if you mistakenly do soemthing incorrect it may cost you more in the long run.
    Sergeant:
  • 276 Answers
Getting it serviced is much advisable.as it will give the device a long life without any problem
I have a Rowe Ami cd 100 that we just got.The cd,s skip-music starts and stops, and it seems like the machine is not reading them [sometimes it picks a cd and returns it to rack].Anyone have any...
Did you lock down the jukebox mechanism (caurosel) during transportation?
Make sure that all the plugs that go to the all the circuit boards are fully seated, Unplug each in turn and plug back in MAKE SURE YOU UNPLUG THE JUKBOX FIRST if this does not sort out your problem look at the microswitches on the transfer motor (this is the mptor that tranfers the CD onto the deck) the spades on the microswitches are uninsulated so they can short out if pressed together.
The other main problem with Rowe Ami is that the boards are prone to the connection pins having dry joints (cold joints in the USA) on the soldinging to these connection pins.
It may be as well having all the boards tested by a Rowe Ami specialist.
In the USA the best guy is Bruce Wentworth (search for his details on Ebay by putting in Bruce Wentworth jukebox) or you could contact me in the UK.
Regards
Alan Hood
ami-man
UK
Apr 29, 2010 | Wurlitzer Jukebox CD Player
Rowe Jukebox Model R-93
I suggest that you get a manual from www.victoryglass.com if you do not already have on, all the instructions for setting up the CCC will be in the manual.
Regards
Alan Hood
ami-man
Record tracking problem
There is a switch, or lever to a switch, that detects the end of the arm travel. For some reason, it is being tripped early. Try to open it up, and see what you can see. It doesn't sound like a broken part, but a dislodged part, maybe. That's all I remember, only had this problem once, years ago.
Mar 14, 2010 | Audio Players & Recorders
Rowe Nostalgia jukebox will only play a few of the numbers of the 100 cd;s. Is there anyway to reset it so it will play all numbers?
You will need to go into the programming section on the menu.
I suggest that if you do not have a manual that you obtain one from Rowe Ami, Victory Glass or distribution.
Have you initalised all of the CD's on your jukebox? Every time you replace a CD you have to initalise it.
Regards
Alan Hood
ami-man
UK
Jan 31, 2010 | Wurlitzer Jukebox 1015 One More Time...
WURLITZER OMT CD 100 D picking problem
Hello J.P.,
You need to get the manual for this jukebox.
You have to however confirm what the manufacturer and the model number of this is. The One More Time was made by the following manufacturers:-
Wurlizer, Rowe Ami, Rock Ola, Antique Apperatus and Sound Leisure.
Look for a serial plate on the back of the jukebox in order to get any information.
You can get manuals in the USA from www.victoryglass.com
Regards
Alan Hood
ami-man
UK
Nov 17, 2009 | Wurlitzer Jukebox 1015 One More Time...
My rowe cd 100 sometimes doesnt play the cd and it spins it back
Clean the laser eye with a cotton bud. Otherwise it is probably a laser unit problem.
Oct 21, 2009 | Wurlitzer Jukebox CD Player
I have rowe ami jukebox Eagle Laser Star and its amp seems to be dead sin have no sound justa a buzz. Need to find one or how to repair it.
CALL AB JUKEBOX SERVICE--ASK FOR BRUCE--TELL HIM LES FROM RMC VENDING SUGGESTED YOU CALL HIM.-
603-382-6272
Apr 27, 2009 | Wurlitzer Jukebox CD Player
Will jukebox read custom made cds?
Hello donovan_k111,
I should be able to play them since mosy CD jukeboxes play stock CDs anyway.
Thank you,
Shuttle83
Mar 26, 2009 | Wurlitzer Jukebox CD Player
Rowe CD 100 that will not play all Tracks
Are you initalizing the CD's in your jukebox after you install them?
If so it should play all of the tracks.
Regards
Alan Hood
ami-man
UK
Feb 01, 2009 | Wurlitzer Jukebox CD Player
Song Programming
With regards to your problem with the Rowe Ami 100 cd jukebox.
Do you have a manual, if not I suggest you buy a printer manual or one on CD and refer to the Programming and Installation section.
In order for the jukebox to know about the cd's that are installed in the jukebox it has to initialize all or the changed cd's that have been replaced within the jukebox.
Put the jukebox into the Service Mode (the service mode should appear on the display)
Type 3 to select the Initialize sub menu
Type 0 and full initialize will appear on the display
Press Popular to start the initialization
Place the jukebox service switch into the normal mode
Initiazation will take around 30 minutes to complete.
Regards
Alan Hood
ami-man
Jan 05, 2009 | Wurlitzer Jukebox CD Player
Open Questions:
See all Wurlitzer Jukebox CD Player Questions
Wurlitzer Jukebox CD Player Logo
29 people viewed this question
Top Wurlitzer Audio Players & Recorders Experts
jasbo
jasbo
Donald Chadwick
Donald Chadwick
Level 1 Expert
Are you a Wurlitzer Audio Player and Recorder Expert? Answer questions, earn points and help others
