Question about Panasonic PT-51SX60 51" Rear Projection Television
On/off Having a problem with set turning on,then after about 1/2 hour or so it will shut off.wait a few seconds or so and it will come back on by itself.or use the front switch ,or remote. Seems like something heating up,then shuts off.Thought it was the panel switch(it was broken) so I put new one in. But it does it even when using remote? HELLLLPPPPP.
  • Anonymous Nov 29, 2007
    Having same problem,but shut down after 2-3 minutes or more,Tech told me it was solder joint on regulator,Not sure where that is but if i knew i`d resolder it.Anyone know where to get schematic for this tv?
Sounds like you either have a bad solder connection heating up and becoming an open circuit or a capacitor that is going bad as it heats up. Either way, you'll probably need a tech to properly troubleshoot it.
Posted on Jan 01, 2007
Pump on my Intex air mattress shuts off before the bed is inflated
Pump is ng and needs replacement. Take it back if under warranty.
May 03, 2017 | Intex Pool & Spa
Tip
How to get rid of xbox 360 red rings of death
  1. turn on x box
  2. let it sit for a hour or two
  3. shut it down wait a few second
  4. turn on xbox
  5. fixed
  6. if this dosent work follow next set of tips
1. turn on xbox
2. let it set on for a day or two
3.turn off wait a few seconds
4.turn on
5. fixed
on May 04, 2010 | Video Game Consoles & Games
When I go to settings and hit Wi-Fi, my networks do not appear. Have no scanning abilities
Samsung Galaxy S4: WiFi not scanning for networks:
Hello:
Try these troubleshooting tips:
1. If this is happening at home, it could be your network setup is having issues, turn off your router/modem, wait 2 minutes, and then turn the router back on.. wait for the router to connect and then try again..
OR
2. Go to:
Settings > WiFi > (remove your network & then re-add it, don't forget you need your WiFi password in order to log back in)
OR
3. Go to:
Settings > Connections (Network Connections) > More Networks > turn on Airplane Mode > wait a few seconds and then turn off Airplane Mode
OR
4. Go to:
Settings > My Device > Turn Power Saving Mode Off
Feb 13, 2016 | Samsung GALAXY S4
S4 wifi will not scan for networks
Hello:
OR
2. Go to:
OR
3. Go to:
OR
4. Go to:
Feb 13, 2016 | Samsung SGH Cell Phones
Where is the reset button on the kindle fire?
According to eHow.com: " E-Reader Soft Reset
  • 1 Open your Kindle's Menu while on the Home screen. Do so by pressing the Menu button, or the onscreen Menu icon for Kindle Paperwhite owners. Select the "Settings" option.
  • 2 Choose "Menu" again from within the Settings menu. This displays a different menu than before.
  • Sponsored Links
  • 3 Choose the "Restart" option. Wait while your Kindle powers off and on again.
E-Reader Hard Reset
  • 1 Charge your Kindle e-reader before performing a hard reset. Charging helps ensure your problem isn't related to the device having a low battery.
  • 2 Hold down the Power button for 20 seconds. The screen will change after a few seconds, but continue holding the power button for the full 20 seconds before releasing.
  • 3 Wait while your Kindle restarts.
E-Reader Factory Reset
  • 1 Press your Kindle's Menu button. Select "Settings" from the menu.
  • 2 Open the menu once more from within the Settings window. Select "Reset to Factory Defaults," or "Reset Device" if you're using a Paperwhite.
  • 3 Select "Yes" in the confirmation window after reading the warning. Wait while your Kindle restarts and restores.
Fire Soft Reset
  • 1 Hold the Power button down for three to five seconds. A Shutdown window appears.
  • 2 Tap the "Power Off" button in the Shutdown window. Wait for the Fire to shut down completely.
  • 3 Press the Power button to turn the device on again.
Fire Hard Reset
  • 1 Plug your Kindle Fire in and give it time to charge before performing a hard reset. This helps ensure your issues aren't related to having a low battery.
  • 2 Hold down the Power button for 20 seconds. The Kindle Fire will shut down.
  • 3 Press the Power button to turn the Kindle Fire back on.
Fire Factory Reset
  • 1 Swipe your finger down from the top of your Kindle Fire's screen, presenting the Quick Settings menu.
  • 2 Tap the "Settings" option and select "Device."
  • 3 Select "Reset to Factory Defaults," then tap the "Reset" button. Wait while your Kindle Fire restarts and restores.
Read more : http://www.ehow.com/how_6122863_reset-kindle.html
May 10, 2015 | Tablets & eReaders
Sleep timer will not shut off We can not turn it on to shut it off.
unplug for a quite few hours, press and hold power button for 5 full seconds while it is shut off, then wait half hour more and plug back in and it should reset itself.
Jan 22, 2010 | JVC AV-27D203 27" TV
It won't stay on!
airindanyell Did you get this problem fixed? I am having the exact same thing happen to me.
Jul 23, 2009 | UTStarcom Blitz Cell Phone
Horizontal Lines
The unit most likely has a short in the horizontal section and would require repair by a service center. Go here to find a JVC repair center in your area http://maps.jvc.com/cAscList/
Sep 18, 2006 | JVC AV-56WP74 56" Rear Projection...
Panasonic PT-51SX60 51" Rear Projection Television Logo
46 people viewed this question
Top Panasonic Televison & Video Experts
 Grubhead
Grubhead
Demonic-2011
Demonic-2011
Are you a Panasonic Televison and Video Expert? Answer questions, earn points and help others
