Question about HP Computers & Internet
My monitor won't come back on after it's been in sleep mode overnight. I have an HP Compaq Presario model SR5502FH with a9" flat panel moniter model #WF1907 Why is this happening and what can I do to fix it?
    Sergeant:
    Champion:
  • 334 Answers
It takes 510 mb for this program to operate properly are you sure you have enough memory ? I myself find it easier to shut off the monitor when not in use rather than go into hibernation.
God Bless Greg
Posted on Nov 24, 2008
Sr5502fh fan noise
hi
most laptops and pcs accumulate dust in the fan and they have to be cleaned out
one of the most effective but can be messy it with an air hose it is very thorough but dusty or you can clean it with a brush as long as you can reach it
but its the dust that normally causes it to over heat and make noise besides a worn bearing
aries
Nov 14, 2013 | HP Compaq Compaq SR5502FH-E Presario...
Computer starts but moniter stays in sleep mode .. moniter works on different comp .. will adding a vid card to my comp fix this problem ??
Actually, Yes. It seems like you have answered your own question... Especially considering the monitor works on another computer.
Do you have another monitor to test on this computer?
Although another consideration could be if you recently installed or downloaded a program which may have changed your video output range to a setting your video monitor wont handle. If this is the case and you can start the computer in safe mode, this will allow you to go into your properties settings and change it back. This way, a new vid card is not req.
Good Luck
Sep 14, 2012 | HP Compaq dx2300 Microtower - RT950UTABA...
Hi,.. I was given a compaq FP 7317 with the tower, key board,...monitor keeps saying "going to sleep" when I finally got it all pluged in. HELP. HOW TO GET OUT OF GOING TO SLEEP?
To disable sleep mode in vista follow the steps
Go to start and type in the search box Power Options hit the enter button
On the Left side there is a panel Click Change when the computer sleeps
Click the drop-down box which says Put the computer to sleep and select Never
Click Save changes
Jun 28, 2011 | HP Compaq FP 7317 17" Flat Panel LCD...
My moniter goes to sleep as soon as its onhat does that mean
restart the computer press f8 f8 until the dos menu appears select enable vga mode your problem will be solved
Nov 07, 2010 | HP Compaq WF1907 Monitor
My monitor has kicked into sleep mode and won't "wake up".
Unplug all the Cables from Compaq Presario 5103 CL and leave the Keyboard, mouse and monitor cable pluged in.
Now make sure the power cable of the monitor should be pluged in and the power cable of the tower should be pluged in.
Now to check if the montor is fine just unplug the video cable only which will show no input signal on the screen. If it shows this signal the monitor is fine. Plug back in the video cable.
If the monitor is going to sleep mode it might be possible that the old computer ( Compaq Presario 5103 CL ) is in stand by mode. hit any key on the keyboard and it should come back .
If it is not in the stand by mode then do one thing. Check the same monitor with the new computer. If it is working. Perfect ..!
Do one thing now ..!
Unplug all the cables from your old system and then press the power button for 30 sec and let it go. Now plug the keyboard, mouse and the monitor try again.
If it works Perfect. If not ..!
Then you need to open the tower and check on the processor FAN is it running..? If its not running you will not get the display as the fan is responsible for the display on the screen. Otherwise...!
Check the Tower possibly the Tower is not getting the power.
Try these steps and let me know If it works
May 04, 2010 | Compaq Presario 5000 PC Desktop
Compaq Presario stuck in sleep mode
Connect the monitor to some other computer, e.g., a notebook, and see if it does the same thing. If it does, then the monitor is the problem.
If it does not, then your computer is not putting-out any "video" signal, and so the monitor goes to "sleep".
If you have MORE than one VGA-output port on your computer, connect your monitor to the "other" VGA port.
Or, press-and-hold the ON/OFF button on your computer, to force it to completely shutdown.
Jan 13, 2010 | HP Pavilion a1710n (RK573AA#ABA) PC...
Why is my moniter in sleep mode .when turn on it's in modesleep
You may have it swiched to the wrong imput. Try changing the input on the monitor. Perhaps it has both vga and dvi.
Sep 29, 2009 | HP Vs17 17" LCD Flat Panel Monitor
Compaq 1701 Flat Panel Monitor Powers Up but screen is blank
no when u power up the system press F8 key then u got safe mofde menu.
then go to enable vga mode then change resolutioin to 800 *600 or 1024*768
then apply and ok.
thats it.
Nov 11, 2008 | HP Compaq 1701 17" Flat Panel LCD Monitor
Hp computer monitor
Hey, the problem you are getting is caused by the pc, when you switch on the pc it sends a signal from the graphics card to the monitor to come off sleep mode and display a picture,
it could be the graphics card, or memory or something more serious,
would try taking out the graphics card and memory and putting them back in see if the machine starts up.. works most of the time..
All the best
John
Jul 26, 2008 | Compaq Presario SR1103WM-B (PC183B#ABA) PC...
Open Questions:
Computers & Internet Logo
90 people viewed this question
Top HP Computers & Internet Experts
pontelemon
pontelemon
Alun Cox
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
