Question about Honda Hmantis Mantis Garden Tiller with Engine
I am looking for fender for honda fg100 rototiller?
I have a fg110 mini rototiller that needs a new fender as the tines went through it. I need the part number and can not find my manual.
If It is a Honda FG100 like in the title the part number is 65141-V06-003
If it is a FG110 like in the description the part number will be 63411-V25-000 FENDER, RR. and 65141-V25-000 FENDER, FR.
Posted on Nov 24, 2008
My Honda FG100 tiller's tines spin when not in the dirt but as soon as I put them in the dirt they stop. What could be wrong with it?
My guess is the clutch shoes bite enough to turn when unloaded but slip when loaded. Try www.hondalawnparts.com for a view of the parts. You will need your chassis number off the machine label as there are several versions of the FG100. A good handyperson/home mechanic should be able to change these / establish the fault. Parts are at your local Honda garden agent or online.
Aug 14, 2016 | Honda Garden
I need a parts manual for a earthquake model 5020 rear tine rototiller
contact the manufacturer on the net and look for a pdf version if available.
Jun 17, 2015 | Ardisam 5.5 Hp Rear Tine Rototiller
Have a Honda FG110 - today I found a large puddle of "clean" oil under it! does not appear to be engine oil .. gear case maybe?
Look at the shaft seals on the output shaft where the tines are attached. If it's wet then the oil came from the gear box.
Sep 24, 2014 | Garden
I have an FG100 that will start up, but the tines won't spin when squeezing the throttle lever. I already pulled the tines, and dust cap off the axle, cleaned things up, and lubricated the...
If the motor will accelerate, does it sound like there is a load on the motor? If the motor accelerates easy and does not seem to be under a load you may have a problem with the clutch. Are you getting power thru the clutch to the gearbox?
Regards Outback
Apr 25, 2011 | Honda 25cc 4-cycle Mini Tiller
Motor runs but the tines want turn
Either the clutch is gone or the transmission gear is stripped. These need to be properly greased annually so that this happens less. The transmission replacement can be done but the dealer will charge you about what you paid for it ($250) or if you know someone handy they can order the parts here: http://www.planopower.com/store/honda/fg100.shtml and rebuild it for you. It would cost about $85 for a full transmission rebuild.
Good luck.
BW
Jun 19, 2010 | Honda 25cc 4-cycle Mini Tiller
I need a worm wheel for a Honda minitiller FG100.
You can buy parts for this from www.petessmallengine.com
I had to replace the tine shaft w/worm wheel assy. This is usually the weak point in the transmission. The worm is made out of brass.
Jan 03, 2010 | Honda 25cc 4-cycle Mini Tiller
Honda FG100 Tiller - Tines wont move
I took the transmission apart and the gears were fine. The friction pads on the centrifugal clutch don't seem to make full contact with the drum. Does anyone know what the thickness of the friction pads are suppose to be? I used some belt dressing on the pads and got some movement on the tines. With no wear on the gears, I guess I'll be replacing the clutch.
May 02, 2009 | Honda Hmantis Mantis Garden Tiller with...
Honda Hmantis Mantis Garden Tiller with Engine Logo
482 people viewed this question
Top Honda Garden Experts
John Trevino
JOHN LAPIER
Marvin
Marvin
Are you a Honda Garden Expert? Answer questions, earn points and help others
