Question about Toshiba 32AF42 32" TV
Any Remote Control for my TV does not work!
Hi, couple of months ago both of my remote controls, the one that came with the TV and my DISH network remote control (programmed to work with my TV) have stopped working. Once in a while they will work but in most cases they will not. I have precluded that this is not a remote control problem, because both of them exibit the same problem, so it has to be a TV problem. I have replaced batteries in both, took them apart and cleaned them up to no affect. Has anyone else experienced the same problem? I have even turned all of my equipment off in the living room and just left the TV on, still no result. Satellite remote control functions work, but not the TV ones. Please help, this is really annyoing me now.
  • 2 more comments
  • lc_derek Jan 05, 2008
    I have the exact same problem. It is not a remote or IR window needing cleaning problem. Unplugging the set for a period of time or manually toggling the set power button a few times seems to reset the problem for a while. Also the programming lang keeps changing itself to a foreign lang. It is definitely a software/firmware problem. How to download and "reflash" the firmware could be helpful.
  • dorsey81 Feb 18, 2009
    I have the same problem ,my verizon fios remote stopped controlling TV (toshiba 32AF42 32" TV)I CHANGED batteries and went thru all the codes 'ABOUT 40 of them".But nothing worked! This after working fine for over a year,with verizon remote,since Ive had verizon.It sounds like I have the same problem! HOW DO YOU GET TO THAT LITTLE BOX ,TO GET TO THE LITTLE LIGHT???
  • dorsey81 Feb 19, 2009
    I can not get my verizon FIOS remote to operate my TV(32AF42)?There is about 40 codes,but none of them work.What is puzzuling is that they worked fine since June of 2008,when I got Verizon FIOS.What can I do?
  • Anonymous Mar 21, 2014
    the power indicator is green but once I turn on my TV using the remote control or even the power buttons on the TV, I just have a black display
    Novelist:
    Champion:
  • 236 Answers
If you're sure the proper codes have not been lost in both your remotes, then possibly the IR receciver in you TV has gone bad. Stargazer
Posted on Jan 21, 2007
  • Simpson Neal Jan 21, 2007
    The IR receiver is a little "box" about 1/2 in. cube with three leads to mounted usually on the front control board.
    Leads are : Signal, Ground,& 5 volts.
    IF you can locate this receiver, there is usually "window" covering the front but lets the IR signal through. This window may need cleaning.
SOURCE:
Cant change channels on my new Vizio HDTV with the dish network remote
There is no setup codes for Vizio TV with Dish Remote control.
Jul 25, 2012 | DISH Network IR Remote Control
Lost my Dish network remote for the upstairs tv (LG) - which has NO box. Is there anyway to program my TV remote, so I can access the TV staions - turn on the network basically???????
No,the Dish Network satalite box signals require it own remote for it INFER RED INPUT and INFER RED OUTPUT signals.Call Dish Network customer service ask for a another original Dish Network remote.U pay $5 or $6 dollars a month for the satalite box as rental.They should wave the fee or charge u very little for a another remote.
Sep 05, 2011 | Universal Remote Control Dish Network...
IM TRYING TO PROGRAM MY RCA TV REMOTE TO DISH NETWORK. PRODUCT INFO. MODEL # L40FHD41YX9 SERIAL # J516C40DI SERIES # F2 PLEASE CONTACT ME WITH SOLUTIONS TO THE PROBLEM
Hi amielynn221, my name is Mike Houston of DISH Network and I see youwant to program the RCA remote to the DISH Network receiver. We do have thecodes to program our DISH remote to the RCA TV we do not have the codes toprogram the RCA remote to DISH Network receivers, I will send a link to helpwith these steps. http://remotefinder.rca.com/default.aspx?site=rca
Apr 19, 2011 | RCA RCRN04GR Remote Control
What is my tv code for programming my dish network remote.
Hi!
Welcome to FixYa!
You can use these codes to program the Dish remote control to your Sanyo DS32920:
542, 589, 590, 591, 592,609
You may also try Power Scan Instructions. Please follow the steps bellow.
1. While at the TV locations (TV1 or TV2 depending on which key is installed), point the remote at the TV. Press and hold the TV MODE button on the remote until all four MODE buttons at the top of the remote light up.
2. Press the RECEIVER POWER button on the remote.
3. Press the UP ARROW on the remote, about one press every two seconds. Stop as soon as the TV turns off. This process may take several minutes.
4. Press POUND (#) on the remote. The TV MODE button will flash three times.
5. Press TV POWER on the remote to turn on the TV. Press VOLUME on the remote to confirm the remote controls the TV. If this does not work, return to Step 1.
Keep me posted.
Thanks.
Lor04
Apr 07, 2011 | Sanyo DS32920 32" TV
Ihave a nexxtch remote control and I would appreciate your help to find the code.My tele is call orion.
Hi ladyebird,
Are you trying to program your nexxtch remote to control your receiver? If so, unfortunately you wouldn't be able to set it up like that. Only the DISH Network remote will operate the receiver. You can set up the DISH remote to control your Orion TV by holding the clear TV button until the 4 mode lights flash and then enter a code (from the website provided below) and then hit #. If the code is successful the TV light will flash 3 times.
Here is the website to obtain the code and will also list the instructions: http://www.dishnetwork.com/SupportSection/remote-setup
Nick Franta
DISH Network
Mar 31, 2011 | DISH Network IR Remote Control
I need a dish network code for a 52" Sharp Aquos.
Hi deidrapleasmy name is Mike Houston of DISH Network and I was going over your post and thecodes for your 52" Sharp Aquos are 628, 739, 521, 629, 741, 679, 112, 605, 625,111, 608, 740, 526, 585, 607, 652, 654, 655, 658, 669, 670 and 674. I will sendthe link to help with the setup for the remote to TV. http://www.dishnetwork.com/SupportSection/remote-control
Feb 14, 2011 | DISH Network IR Remote Control
Light comes on but nothing happens
You need to replace the remote more than likely. Thanks for using Fix Ya.
Jan 29, 2010 | DISH Network 135899 Remote Control
Cannot control Vip222 with sling classic
I have read elsewhere that Slingboxes required the Dish Network receivers to be set to Primary Remote Address 1.
To try a fix:
Using the Dish Network Remote Control -
1. Press menu 2 times to get to system info page
2. In the system info page the Primary Remote Address is in a white box (bubble) followed by a Green TV (1)symbol that says IR and indicates the channel to which remote control 1 is configured.
If the Primary Remote Address of your Dish VIP722 Remote control 1 is not set to channel 1, here is how to change it:
1. While displaying the system info page, press and hold the SAT button on your dish network remote until all other modes are flashing, about 3 seconds.
2. then press the '1' button on the numeric pad of your dish remote
3. then press the '#' button on the numeric pad of the dish remote
4. then press the 'record' button (red dot button - stores setting)
5. At this point you should see a number 1 in front of the primary remote address on the dish system info page
Ensure you enter the corresponding IR code into your slingbox remote control per the instructions in the Slingbox documentation.
Feb 05, 2009 | Sling Media Slingbox AV Remote Control
Programing Dish Network Remote to control a Vizio Tv.
Try 627 for Vizio TVs - that should work on the Dish remote.
Dec 22, 2008 | DISH Network IR Remote Control
Toshiba 32AF42 32" TV Logo
226 people viewed this question
Top Toshiba Televison & Video Experts
Jaime Hernandez
Steve Allison
Steve Allison
Are you a Toshiba Televison and Video Expert? Answer questions, earn points and help others
