Question about Seagate USB 2.0 External Enclosure + 300GB BARRACUDA 7200-ULTRA ATA/100 8MB-ST3300831A (NEWITEM31866554) Drive Case
Seagate barracuda + usb harddrive enclosure cant access hard dive
I have just purchased this hd enclosure:http://www.amazon.co.uk/gp/product/B000Q7K9DA/ref=s9subs_c5_23_at3-rfc_p-frt_p_si2?pf_rd_m=A3P5ROKL5A1OLE&pf_rd_s=center-1&pf_rd_r=0AFSBCMHMKKZ91MSQDBV&pf_rd_t=101&pf_rd_p=463374953&pf_rd_i=468294
and i own this hd:http://www.seagate.com/ww/v/index.jsp?locale=en-US&name=Barracuda_7200.10_250_GB&vgnextoid=e443577a7f53d010VgnVCM100000dd04090aRCRD&vgnextchannel=a32a2f290c5fb010VgnVCM100000dd04090aRCRD&reqPage=Model
also my computer is a dell studio 15 laptop running vista it has a main hard drive and a back up drive built in
i connect the drive to the enclosure then to my computer my computer tells me it has installed a generic usb drive but when i go to windows explorer .... nothing.
i have put the jumper on master slave and cable select and same result every time.
any ideas?? thanks in advance!
  • Seagate Master
  • 787 Answers
First, neither of the links work. The amazon shows a power adapter and the Seagate defaults to their home page. But I think I get the idea. You purchased a usb drive enclosure and a new hard drive and now it doesn't work.
The problem is that the hard drive has not been initiated, formatted or assigned a drive letter.
Plug in the drive
Click on the Start button
Right click on Computer
Select Manage
A screen opens, click on Disk Management
All the drives known and unknown will appear on the right.
Find the drive that says unknown, right click over the text and select Initialize Disk.
When done, right click the blank space to the right labelled Unallocated and select new simple volume then follow the steps to format and assign a drive letter.
If you are only going to be using this drive on this computer then format ntfs, if it maybe be connected to other devices including Mac, you may want to use fat32 or exfat.
Whats the Difference Between FAT32 exFAT and NTFS
Posted on Mar 01, 2017
3 Suggested Answers
SOURCE: 3.5" Dynex USB 2.0 External Enclosure + Seagate Barracuda 7200 RPM 500 GB HDD problem with computer recognizing the HDD and the enclosure
 If your running XP , go to control panal , Admin tools>Computer Management >Storage > Disk Management . Look for it there . If its there see if it says what file system . If none format it . If it isnt there then chack the jumper on the hard drive it self . It should be set to master or cable select .
Posted on Oct 25, 2007
parrotheadpc
  • 2600 Answers
SOURCE: I installed a Seagate Barracuda 1.5TB Hard Drive
Go to the contro panel > Administrative Tools > computer management > Look in the left side pane and click on "disc management". Your drives will appear here including ones that may not be "initialized". If you see a drive that has no letter, maybe just a number like drive 03, this drive is not initialized and needs to be done if it is to be recognized by the computer. With the disc management window open, look where it lists the disc. Your main hard drive should be disc 0. If this external is connected via a usb, this disc maybe listed as disc 01 or just 1. Right below the name it will say that the disc is offline. If this is the case, right click in that gray area where the name is and click on "initialize". A series of windows will open asking you to click ok on what kind of drive it is to be used for. Just go with the choice that is already given and click ok. The drive will then be initialized and it will then be ready for formatting. Simply right click on the area next to the name that says unallocated and select format, choose ntfs file system and the size of the partition if you want to make several partitions, this is the time. then choose quick format. The drive will the make the partitions and give the partitions drive letters. Your drive is all set up.
If it comes up and says that "the device is not ready" when you try to initialize it, then the drive or the interface is bad.
Posted on Dec 26, 2009
Testimonial: "I followed your instructions and now the drive is showing up. I had checked windows support, seagate support, and more, but this did the trick Thanks!"
I have a seagate barracuda 7200.2 and a i/o magic usb hard drive enclosure. it runs fine blue light comes on but,.....it doesn't show up on comp.
Have you tried the hard drive outside of the enclosure? Maybe it just isn't compatible with it. Else something with the connector could be broken
Jan 06, 2013 | Computers & Internet
Info: barracuda 500 gig in a kingwin elite enclosure (sata) - usb to computer. being used as a backup and storage drive on H.P. Quadcore running windows vista. Prob: Cant be seen on any computer ive...
Quite commonly on external drives the usb interface will go bad in the external drives the hard drive enclosed is probably functioning ok. Would try a different usb cord just to make sure the cord is not the issue. If still does not work you may need to purchase a new enclosure that will have a new usb interface circuit board with it. If taken in for service they will probably tell you to purchase a new external drive.
Here is a video on recovering data a side from an external drive.Some steps are not necessary if you have access to an ide/sata to usb adapter. These are pretty inexpensive on ebay as well as replacement enclosures.
http://www.metacafe.com/watch/1000351/recover_data_from_external_hard_drive/
May 01, 2011 | Seagate Barracuda 7200.12 ST3500418AS Hard...
USB port broke off. Can I connect to something else to get the data off the drive? I cracked open the case and it's a barracuda 7200 but I don't recognize the pin connections. Please help? Thank...
Yes just fixed mine. Went to radio shack bought a gigaware sata 3.5 external enclosure.
Took the harddrive out of old enclosure. pryed off external alluminum case to expose a panel that sticks out to the side where the broken usb plug went. Wiggled that off then placed in new enclosure fits good. secured with old screws. plugged it in and it works great. The new usb plug is much sturdier. The external case cost me about $40.00 and some change but Im glad i retreaved my data. I will never buy another seagate. Hope this helps...Alan
Jan 04, 2011 | Seagate FreeAgent Pro - 500GB, 7200 RPM,...
What kind of external enclosure do I need for a Seagate Barracuda 7200.9 hard drive?
You need something like this one
http://www.scan.co.uk/Products/Newlink-35-CDLSB-806-Aluminium-SATA-HDD-To-USB-20-Enclousure
Aug 22, 2010 | Seagate Barracuda 7200.9 300 GB SATA Hard...
Seagate 120 gig HD in Dynex enclosure not recognized by XP system
Ok, you didn't say if the drive had data or not? Anyway, if it is a drive with no data etc, you will first need to Initialize, & Format the drive before use. Is there any way you can connect it up to an "Internal" or "External" SATA port, & "See" if the drive is recognized, then at least you know the drive is OK.. Also try another USB port if available. If you know it is OK, then go to device manager and Uninstall the entire USB layer, reboot, it will re-install the USB again, with default settings, it NOW may be "Seen".
Feb 22, 2010 | Dynex USB 2.0 Hard Drive Enclosure Kit...
Cant access files on my harddrive
It sounds like either the enclosure or the drive inside has failed.
If the enclosure has failed and you don't have any crucial files on it that you don't already have elsewhere, contact Maxtor(Seagate) for a warranty replacement.
If the enclosure has failed and you DO have important files on it, try having your local PC shop move the hard drive into a new enclosure, if that works you're done, buy the new enclosure.
If the new enclosure fails, your drive is damaged and you will need a pro to help get back your files. If this is the case, reply back with you location(Country, State and City) and I will pass along recommendations for your neck of the woods.
Hope this helps FixYa,
Chris
Oct 24, 2009 | Maxtor OneTouch 4 500GB External USB 2.0...
Install a seagate 7200.7 in a cool max enclosure
They sure are !
You need an IDE or EIDE enclosure.
If you bought the enclosure very recently you may want to try taking it back and swapping it for another one
If its a big box store you might want to try the "it just doesn't work and I am clueless" routine
Seen that work quite a bit much to my dismay. Then the people usually get money back and go to another store to get the correct item.
NOTE I dont condone that method !
Aug 20, 2009 | Seagate Barracuda 7200.7 (ST360014A-20PK)...
How can i make my seagate hard disk an usb hard
It is quite easy, do not worry.
You only need to bought and USB enclosure, here is a link to many products on ebay
http://search.ebay.com/search/search.dll?from=R40&_trksid=p0.m37.l1313&satitle=hard+drive+enclosure+usb&category0=
then you have to connect your hard drive inside the enclosure and the enclosure to your computer using the usb cable and that's it.
Just be carefull about the enclosure, I guess it is a Hard drive from a desktop, is in it? because some enclosure are for laptop's hard drive.
Also you need to know if your hard drive is SATA or IDE, IDE is the normal gray bus cable with fourty some pins, and the SATA it is a really small cable (I do not use technicims to not confuse you even more).
Also, there are some adapters from IDE/SATA to USB that you can buy in your local computer store (do not go to bestbuy, compusa, ... they only sell external hd), or also get it from ebay.
The only diference between the enclosure and the adapter is that the enclosure looks better :D, and the adapter is just a bunch of cables.
Mar 19, 2009 | Seagate Barracuda 7200.10 320 GB SATA Hard...
Ethernet drive not spinning up.
You can always format it but if you have any data on it you will lost them
Dec 17, 2008 | Seagate Barracuda 7200.7 ST380011A 80 GB...
Computers & Internet Logo
98 people viewed this question
Top Seagate Computers & Internet Experts
Arora Singh
Arora Singh
Alun Cox
pankaj rautela
pankaj rautela
Are you a Seagate Computer and Internet Expert? Answer questions, earn points and help others
