Question about Miele Novotronic T1515A Electric Dryer
Door will not shut - Miele Novotronic T1515 vented dryer
I have a Miele dryer (Novotronic T1515 vented dryer) and the door is EXTREMELY difficult to close. It has to be shut with proper contact to operate the dryer. It seems to be a minor problem so I am reluctant to book a service call. Can anyone help please?
3 Suggested Answers
  • 177 Answers
SOURCE: How do you remove the top of the Miele T1515
hi,
on each side of the lid at the front there is a plastic white cover. remove this with your fingers or a small knife. then using a T20 screw driver unscrew each screw a few turns and then push the screw heads in with your finger. do not unscrew the screws too far or remove them.
last push the lid back a few inches and it will lift off. once off you will see the locking clips that you just unscrewed which hold the lid down. when re-fitting the lid do the reverse and just tighten up the screws.
Posted on Apr 25, 2010
  • 32 Answers
SOURCE: Miele T1515 - has started to make my laundry room
check the exhaust hose. it sounds like it has separated from the outlet and is spilling the hot exhaust into the room rather than through the vent outside
Posted on Sep 17, 2010
  • 83 Answers
SOURCE: Miele T1515 electric dryer -
is your dryer vented to the outside? Check the exhaust vent to be sure it is still attached to the duct and not plugged with lint
I need from manual guide on English for dryer Miele t565c
I have a t565c novotronic dryer,the light in the drum comes on but when i close the door and turn it on it want start .?
Dec 28, 2010 | Miele Novotronic T220 Electric Dryer
My miele novotronic t230c is not generating heat but work fine in all other areas. can you advise me please
Sorry to read about your problem. Their is a 80% chance you have a defective heat coil or coils. or the heat selector switch is defective. in addition you may have a clogged dryer vent.
I suggest you place a call to a service company.
I tried to help you. Please help me and vote/rate this response thanks.
If you live in Denver area, I can help you.
Dec 21, 2010 | Miele Novotronic T230C Electric Dryer
Miele T1515 - has started to make my laundry room feel like a sauna - why?
Sep 17, 2010 | Miele Novotronic T1515A Electric Dryer
Miele T1515 electric dryer - overheats and laundry room feels like a sauna. What can I do about it?
Sep 17, 2010 | Miele Dryers
How do you remove the top of the Miele T1515 vented dryer?
hi,
Apr 12, 2010 | Miele Novotronic T220 Electric Dryer
My miele T220 has recently started pumping out steam from the circular vent / hole on its lower right side. It didn't used to do this so I 'm wondering why it's started and how to stop it. Not sure if...
Only 2 things can cause this. The external vent tube is blocked or clogged, not allowing the moist air out of the dryer, or the internal portion of the vent is clogged. The external one can also be caused by the external flapper on the outside of the house.
Jul 20, 2009 | Miele Novotronic T220 Electric Dryer
Miele T220 Novotronic
Miele is a top notch machine. Try checking your vent hose. It may be blocked in some way.
Jan 28, 2009 | Miele Novotronic T220 Electric Dryer
Miele Novotronic T1515A Electric Dryer Logo
41 people viewed this question
Top Miele Dryers Experts
Tim Whalen
Dan Webster
Dan Webster
Mike
Are you a Miele Dryer Expert? Answer questions, earn points and help others
