Question about Whirlpool GBD307PRS Stainless Steel Electric Double Oven
Door when you try to turn the oven on it shows door on the control panel and will not work, also the light wont go off i assume there is a sensor somewhere that tells the oven when the door is open. any suggestions? i have tried turning the breaker off to reset and looked the door and latch over fairly good. thanks mike
    Novelist:
  • 116 Answers
The latch assembly should have a switch on it to indicate whether or not the door is open. Press in or sideways on the latch arm to simulate a door closed condition.
Posted on Mar 11, 2007
Oven light on display says door and now wont heat
The oven will not turn on the heat because it thinks the door is still open. It thinks the door is open because it has a sensor that gets pressed by the door when it closes (look around edges of oven that get covered when door closes) this sensor is wet, dirty or broken so when you close the door the sensor still says its open. Did you clean around the door with a wet cleaning fluid?
Dec 20, 2013 | Whirlpool GBS307PRS Stainless Steel...
CAN NOT CONTROL BOTTOM OVEN
I assume yiu had the electronic oven control repaired. Sometimes the touch pad also goes bad. I have had to replace them at the same time. If the oven indicator lights showing the oven being on shows up on the display it could be that the thermal fuse behind the oven has gone out. this in in the common line and will shut down both ovens at the same time but you will get the control panel to respond to the touch pad.
Nov 23, 2013 | Whirlpool RBD305PDS Electric Double Oven
My built in oven AKZ 110 is showing F 03 and nothing happens when I try to tune it in to work just stays on F 03 no fan no light either
This should help any further assistance please feel free to contact me.
WHIRLPOOL
Range/Stove/Oven Fault Codes Non Y-Line
NOTE: Not valid for Y line. If there is a Y near the end of your model number, do not use this chart.
Failure
Code
Condition Check/Repair 4 Digit Failure Code F0 - E0 Analog to Digital Failure Disconnect for 30 seconds - if display re-appears - replace control F1 - E1 Safety flip flop Replace Electronic Range Control/Clock (ERC) F2 - E0 Shorted keypad Replace Electronic Range Control/Clock (ERC) F3 - E0 Oven temperature sensor or oven temperature sensor fuse opened Replace oven temperature sensor or fuse F3 - E1 Oven temperature sensor shorted Replace oven temperature sensor F3 - E2 Oven too hot Replace oven temperature sensor F3 - E3 Clean temp too hot Replace oven temperature sensor F5 - E0 F5 - E1 and E2 Check door/latch switch Replace component 2 Digit Failure Code F0 or F1 or F5 Failed transistor Replace Electronic Range Control/Clock (ERC) F2 - E0 Oven temp too high 1. Test operation of door lock on self-clean models
2. Test relay contact operation
3. High resistance in oven temperature sensor F3 Open oven temperature sensor or thermal fuse Replace oven temperature sensor or thermal fuse F4 Shorted oven temperature sensor Replace oven temperature sensor F6 Problem in time keeping circuit 1. Reset time and/or cooking operation
2. Check for proper ground F7 Stuck function switch or button on Electronic Range Control (ERC) Replace ERC (Electronic Range Control/Clock) F8 Failure Electronic Range Control (ERC) Replace ERC (Electronic Range Control/Clock) F9 Door lock circuit Check wiring and test operation of door lock switch bkg-faultcodedivider.jpg txt-gototop.jpg WHIRLPOOL
Range/Stove Oven Fault Codes, Common
Failure
Code
Condition Check/Repair Digit Failure Code2 F1 Analog to Digital Failure Disconnect for 30 seconds - if display reappears - replace control board F1 Safety flip flop Replace board F1 Shorted keypad Replace keypad F3 Oven temperature sensor opened Replace oven temperature sensor F2 Oven temperature sensor shorted Replace oven temperature sensor F3 Oven too hot Replace oven temperature sensor F3 Clean temp too hot Replace oven temperature sensor F5 Check door/latch switch Replace switch if defective 4 Digit Failure Code F1 - E1 Safety flip flop Replace board F2 - E0 Shorted keypad Replace keypad F3 - E0 Oven temperature sensor opened Replace oven temperature sensor F3 - E1 Oven temperature sensor shorted Replace oven temperature sensor F3 - E2 Oven too hot Replace oven temperature sensor F3 - E3 Clean temp too hot Replace oven temperature sensor F5 - E0 F5 - E1 and E2 Check door/latch switch Replace switch if defective
Jul 16, 2011 | Whirlpool Ovens
Amana AEW4530DDS cancel button the only button to beep or work on control panel. Time of day lights up. oven wont work . before oven went t/u had it on broil with the door open a bit. did this fry the...
A qualified technician needs to troubleshoot the unit and determine if the bubble-keypad has broken or the control board that 'controls' it. The control board would be my guess, and would also cost the most.
Mar 16, 2010 | Amana AEW4530DDS Electric Single Oven
Lock light flashing after cleaning. Will not
OK, what has happen here is, the actual temp sensor has failed during the cleaning process, this has cause a temp that reached a dramatic high range(above 915F-930F). At these temps, there will be major damage that will weld the contacts on the door lock switch mechanism and control board.
If actual over temperature condition occurred: Look for welded relay contacts. If this happens, replace oven control (also called clock or ERC).
If no over temperature condition occurred: Look for a high resistance connection or any other cause of high resistance in the oven temperature sensor circuit. Check sensor, sensor harness and sensor harness connection at sensor and oven control. Replace sensor if found defective. Check door lock switches for faults as well(welded contacts and burned wiring harness)
Remember: Oven control (ERC) measures resistance of sensor circuit , not actual oven temperature.
Sep 23, 2009 | GE Ovens
Have a zephaire GL when you first turn on the
"sparks pilot lights" , "reset button comes on" can you be more specific on these terms you used? I know this posting is an old posting, but I maybe be able to help you as I have fixed all the problems (multiple with 6 G-L's zephaire. Here I'll try to "assume" your terms. The g-l has one light at the front panel. If you mean it comes on and off (the light that is), this is the due to continuous try ignition module, not reading the "flame sensor input right", assuming there is no flame at the pilot. This might be caused by a mulfunction of the ignition module, or by a bad "flame sensor wire" or sensor. See if the pilot spark / flame comes on when you turn the oven on. See if the white wire coming out of it is good and not chewed by rats or something. If the ingition control (the blue box) is reading flame sensor input right, it will light the main burners, (red wire on the valve) if I recall correctly. The ignition control works properly on max 150 F and the ventilation fan on top if it's not working should be replaced. They sell them on line, and also grainger has it for around $32. The o modules go for around $129 to 170. and sometimes you find them on ebay for around 50. Hope this helps.
H
Jul 13, 2009 | Blodgett Ovens
My oven will not turn on or off.....the fan is running and the screen is showing F 02
HI, the F-2 is signaling a higher than normal oven temperature. Follow these steps bellow.
1. Look for welded relay contacts on bake or broil relays. If this happens, replace oven control (also called clock or ERC).
2. For SELF CLEAN models: check door lock operation. If the door lock device is not working properly, replace.
3. Look for a high resistance connection or any other cause of high resistance in the oven temperature sensor circuit. Check sensor, sensor harness and sensor harness connection at sensor and oven control. Replace sensor if found defective.
Remember: Oven control (ERC) measures resistance of sensor circuit, not actual oven temperature.
May 18, 2009 | Whirlpool RBS305PDS Electric Single Oven
Oven wont heat
This may be a control panel issue. i would also check the glow ignition as well , assuming it is a gas range.
Feb 11, 2009 | Frigidaire 30" Self-Cleaning Freestanding...
What is the reset button for GE Profile JTP18?
For me the solution was in the temperature sensor. The Locked light kept flashing and the door locking mechanism kept cycling when the door was shut or if I just held the oven light switch in the closed door position. After replacing the control panel I still had the same problem. Next I turned off the breaker and then took off the wire covers on the back of the oven and disconnected the temperature sensor. I then checked the continuity of the sensor which was fine. With the sensor still unplugged, I turned the breaker back on and the panel said locked but the locking mechanism was not cycling. With power still on to the oven I connected the temperature sensor. It worked. All I had to do was press the clear button on the touch panel and everything was fine. I turned the breaker back off and reassembled the oven. Hope this helps.
Oct 12, 2008 | GE Profile JTP18 Electric Single Oven
F3 Error
This is due to a Defective control board..You have to get it replaced..
Oct 15, 2007 | GE Profile Advantium SCB2001KSS Stainless...
Whirlpool GBD307PRS Stainless Steel Electric Double Oven Logo
78 people viewed this question
Top Whirlpool Ovens Experts
Sal De
John Tripp
John Tripp
Are you a Whirlpool Oven Expert? Answer questions, earn points and help others
