Question about Hoover F7431-900 SteamVac Vacuum
Can't figger out the accessory hose connections
I can't find the instructions/manual for my relatively new machine. I have never used it for cleaning using the hand tool; only carpet cleaning. I can't figure out how the one end connects to the recovery tank. I wanted to examine an operators manual on-line, but can't find one. Can you help? Thanks.
  • Joseph Bogo Jan 01, 2007
    I found the instructions. Thanks! Je
Visit assist.hoover.com and review the available on-line manuals. If you do not find the appropriate manual, contact The Hoover Company Consumer Response Center at 1-800-944-9200.
Posted on May 16, 2007
Dirt devil ce6100
Hi there! Below are step-by-step instruction to assembling the hose to the cleaner so that you may use the attachments. I have also included a link to the instruction manual which gives instructions and illustrations as well. Hope this helps!
1. Put cleaner in its upright position. Connect the upholstery attachment to the trigger adaptor.
2. Remove the dirty water tank door.
3. Insert the hose adaptor into the dirty water tank.
4. Connect the base water supply connector into the fitting on the lower left side of handle facing cleaner. You are now ready to do above floor cleaning!
http://pim.ttifc.net/document/1549/
Jun 13, 2014 | Dirt Devil CE6100 Featherlite Upright...
How do you replace the tool hose on a Bissell Pro Heat 2X?
Here is the Instruction or User Manual for the 7910 and the 8910 series machines
Here is the Instruction or User Manual for the 8920, 9200, 9300, 9400, series machines
Here is the Instruction or User Manual for the 9500 series machines
Jul 03, 2013 | Vacuums
Vaccum seems to cut off after short use like its hot,,once it cools off i can use again
Check filter. Clean if needed. The filter should be cleaned when it appears dirty. Simply remove filter, rinse thoroughly under warm running water until clear, then allow to thoroughly air dry. The drying is very important. Additional filter cleaning instructions are on page 13 of the manual.
Check the pleated exhaust (HEPA) filter. If dirty, cleaning is necessary. Instructions for removal and cleaning are on page 14 of the manual.
Check hose, wands, and power nozzle for blockages.
Hose: detach at both ends. The ends of the hose are the most common areas for a blockage. Check visually and clear as much as possible if present. If not visible, hold one end up and drop a coin in. Lift the end until the coin falls through. If it doesn't, there's a clog.
The easiest way to unclog a hose is to use an air pressure hose, or a canister vacuum that has an exhaust blower that the hose can be held too. If enough pressure, it will blow the dirt out. Make sure to put a plastic bag around the loose end to hold the dirt.
Visually check wands and power nozzle. The bend in the power nozzle connection is another common place for clogs. A wooden spoon handle, or similar blunt object, can be used to push the debris back toward the brush to clear a blockage here.
If none of these are the problem, contact a vacuum service center, preferably Hoover, for assistance.
Manual:
http://www.hoover.com/pdfs/manuals/S3865.pdf
Thank you for providing the brand and model info. It helps a lot.
Mar 05, 2011 | Hoover Platinum Cyclonic Bagless Canister...
My Ultralux 2000 vacuum power head does not work on my machine but does work on a different machine. What are the possilbe problems? I tried replacing the hose with a new one and that didn't help.
It's probably due to bad wiring connections between the wands, hose and wand, or power nozzle and wand. If it came with the Sidekick, try using it on the end of the hose. If not, simply try using the power nozzle on the end of the hose (no wands). If it works, then the problem is going to be with the cord sections in the wands. Check them good for cracks, breaks, and discoloration at connections. Replace if necessary.
Jan 05, 2011 | Electrolux Eureka Easy Clean 2 in 1 Stick...
Replace accessory hose
i There,
I'll be happy to walk you through step by step how you can attach the hose to your Hoover SteamVac.
Here are step by step instructions for you:
Step 1. To prevent possible leaking, remove
clean solution tank by pressing down on
tank handle (D) and pulling forward; set
tank aside (do not set tank on furniture2_bing.gif).
Remove hose from storage rack.
Step 2: Step on handle release pedal (E) and
lower carpet cleaner handle until it rests
on the floor.
Unlatch back part of recovery tank and
remove lid.
Step 3: Remove recovery tank front panel (F)
by sliding it straight up.
Step 4. Replace panel with converter (G).
Slide converter halfway down opening
until it is firmly in place.
Step 5. Before connecting tube (H) to
cleaner, make sure black tabs are
extended by pulling tan collar toward
tube.
Open door on hood labeled “Stair/
upholstery Cleaning Connection”. Press
round solution tube connector onto
round projection inside door. Press connector
collar down firmly to ensure
that it is fully connected.
Step 6. The tank replaces in a hinge-like
manner. Position front of lid under tabs
(I) on front of tank. Rotate lid down onto
tank.
Make sure lid is secure on all sides
before cleaning.
For full suction, it is important that
the recovery tank lid is properly
secured before cleaning.
Reverse procedure to remove hose
and solution tube.
Raise carpet cleaner handle to upright
position.
I hope that this was helpful to you in hooking up your Hoover SteamVac hose. If you found this helpful, please be so kind and rate my repair helpful by clicking the 4 thumbs up icons in the top right hand corner of the repair, this is really appreciated.
Thanks again,
Chris J.
GoVacuum.com
Apr 15, 2010 | Hoover SteamVac F5914-900 SpinScrub...
My hoover mach 6 bagless overheats, shuts off for about an 1 hr will run again, all filters are clean, no blocks in hoses, how can i fix this problem
This is telling you that there is poor air flow or a blockage somewhere. To simply check for proper suction, remove the accessory hose to see if there is normal suction, if not then your problem is further in the unit. Troubleshooting from there will tell you where the problem is. Another possibility is that your thermal overload circuit is faulty. in this case a pro vac shop needs to service the issue.
I’m happy to assist further over the phone at https://www.6ya.com/expert/robert_b96ba3f038cf317c
Feb 28, 2009 | Hoover U5194-900 Mach5 Multi-Chamber...
Suction not working
Ok first thing to do is remove & clean the 2 piece premotor filter or purchase new.
Now remove soleplate from bottom of machine to do this rotate the 3 plastic screws to unlock position. Lift sole plate off now remove any blockagers or fluff that may be built up over the brush roller.
Remove hair from brush roll using scissors.
Check short clear hose for blockages & any damage rips or tares if it is damaged purchase new hose.
Now look at belts & rotate brush roller it should turn relatively easy if it is difficult to turn by hand remove the brush roller & pull off the end caps the axle will come out with one of the caps.
Check the roller bearings clean away dust build up replace end caps & axle spin roller holding on to end cap if freely to spin refit back on to machine.
If its stiff to rotate you will need new roller.
Now pull off the 2 inspection ports check them for bits of paper etc especialy the (U) shaped port at bottom rear of machine this can contain pens pencills stones all sorts of items that hinder the suction.
Now check the long flexi hose & metal wand for any obstructions.
If after all this machine is still not working correctly go to this site http://dysonmanuals.llc.nu/
On this site you will find Dyson service manuals covering poor suction, clutch,motor, etc.
Chris...
Sep 25, 2008 | Dyson DC07 Animal Bagless Upright Cyclonic...
No suction
Chris...
Sep 24, 2008 | Dyson DC07 All Floors Bagless Upright...
Suction loss on dyson animal
Hi.
Keep the axe on hold try this first.
Chris...
Sep 21, 2008 | Dyson DC07 Animal Bagless Upright Cyclonic...
Vacuums Logo
185 people viewed this question
Top Hoover Vacuums Experts
Jim Parker
Jim Parker
Kirk Thompson
Level 1 Expert
Are you a Hoover Vacuum Expert? Answer questions, earn points and help others
