Question about Refrigerators
Cracks in a shelf
Dear Sir,
The plastic shelf on the bottom of my Viking refrigerator developed some cracks in it and I want to order a new one and replace it.
Who should I contact?
Mark Patriquin
3 Suggested Answers
SOURCE: Whirlpool Refrigerator Shelf falling off support pins regularly
I got a new refrigerator that has the same problem. I solved it by cutting a triangular pencil grip for children's pencils down so they extend out just past the pegs on both sides (making them longer). The grips fit on snug, just like on a pencil, you don't have to screw the shelves in permanently which allows them to be taken off and moved. Works like a charm and holds the shelves in very snug.
PAM
Posted on Apr 05, 2009
  • 61 Answers
SOURCE: how to order crisper shelf for refrigerator
try www.appliancepartssolutions.com they have great prices
Posted on Jan 16, 2010
I need a new bottom door shelf, the milk just comes flying out when I open the door bit of plastic has gone from side of shelf making it weak
use a different shelf then . contact manufacturer and perhaps you can order one . we can not even tell you where to look as no MAKE or MODEL was included in the question .
Aug 09, 2015 | Refrigerators
Crack in bottom of freezer?
Hello
this is not a problem as long as you do not let water or dampness into the crack, just switch of fridge and dry out the crack and seal with a good quality mastic or plastic sealer ..
tk
Oct 18, 2014 | Whirlpool WSF26C2EXB 26 cu. ft. ENERGY...
Ice in refrigerator
Usually a blocked drain at the rear just above the bottom shelf. Use a plastic drinking straw to clear the hole. Could just be condensation if you are in and out of the fridge a lot.
Aug 07, 2012 | Frigidaire FRT17B3A Top Freezer...
Fisher & Paykal Refrigerator. E 522 B Plastic piece in door hinge fell out . Door now travels around and has big dent in front panel. I need to replace outer stainless door panel and plastic piece in...
The plastic piece that is moulded to the inner door that holds up the shelf on a fisher & paykel fridge has cracked and no longer holds the shelf. Can I buy a new door liner or does the whole door need to be replaced?
Jan 29, 2011 | Fisher and Paykel E522BRXFD Stainless...
I have an LFRD25850SW Fridge. The bottom shelf above the crisper drawers has cracked at the left front and is causing the drawer to stick. I need to replace the shelf frame (glass is OK). Can you give a...
The shelf frame is cracked . It can be purchased if the part is still available from LG . I wouldn't hold out hope though because LG is notorious for discontinuing parts after 3 years. Find a parts supplier who has contact with LG parts to see if it's still available . I was able to order one for my customer back in the spring.
Oct 22, 2017 | LG LRFD22850 Bottom Freezer Refrigerator...
Noises in freezer area of refrigerator
Some refrigerators have a small plastic fan under the bottom shelf of the freezer that circulates air. It's not too unusual for a heavily loaded shelf to rub the fan blades making the noise you describe. If you empty the freezer, you'll fin a few screws holding the bottom shelf in. remove the shelf and inspect the fan and surrounding parts for signs of rubbing. Also tug on the fan blade lightly to see if it is still attached to the motor's shaft securely. New fan blades can be purchased at a good appliance repair shop. Good Luck
Nov 30, 2009 | Hotpoint HTR16BBSR Top Freezer...
Cracked border to bottom shelf of frigidare refrigerator
240350614 is the part number for the shelf border that you need...price is around $26
Oct 03, 2009 | Frigidaire FRS3R5EMB Side by Side...
Liebherr fridge parts? The plastic on the glass shelf has cracked and I need to replace the shelf but I don't know where I can do this... I'm also not sure what model the Liebherr fridge is either...
There should be a tag with model # on it somewhere on unit. Usually in inside side wall of fridge section. Or maybe on back of unit. Definitely need model # to order part.
Sep 08, 2017 | Refrigerators
Jenn air french door refrigerator
Can you place the unit into Turbo Cool? once it reaches 34 degrees it will reset to 40.
This can happen if you've recently added a lot of food lately, such as for a party. The energy saving nature of the unit cannot cope with the influx of a lot of food food from the grocery store all at once.
If that doesn't do it, stick around and someone will be along to help you.
Kind regards,
Worldvet
Jun 02, 2008 | Jenn-Air JFC2089H Bottom Freezer French...
Refrigerators Logo
47 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
