Question about Samsung SyncMaster 400 T 40 in. Flat Panel LCD Monitor
DVI Connector on Samsung 40 inch syncmaster 400p won't work
I plug a DVI cable from a pc that has a DVI connection to the 40' inch monitor DVI and monitor won;t Detect the DVI connection,the green light on monitor just flash on & off what is the problem???/
3 Suggested Answers
Riziel
  • 116 Answers
SOURCE: Samsung Syncmaster 245BW, can't get it up and running !
Most of the time when this happens it is due to a bad monitor, if you have another pc try to hook this monitor up to that one to see if it actually works, these monitors sometimes get damaged during shipment!
Posted on Nov 26, 2007
  • 109 Answers
SOURCE: VGA connector wiring detail
Pink - red input - pin 1 green - green input - pin 2 blue - blue input - pin 3 ground shield wire - pin 6,7,8 and 10 black - ddc 5v - pin 9 violet - screen raster - pin 11 white - data or sda - pin 12 orange - clock or scl - pin 15 yellow - vertical signal - pin 14 clear - horizontal signal - pin 13
Posted on May 17, 2010
Hi I BOUGHT NEW Samsung SyncMaster P2070 20" LCD Flat Screen Monitor , AND I HAVE HP COMPAQ AND THE MONITOR NOT COMMUNICATE WITH PC
http://support.dell.com/support/edocs/video/p56135/en/connect.htmhttp://support.dell.com/support/edocs/video/p56135/en/connect.htm
you Monitor uses the DVI-I Port this link will show you what it is. you will need a adapter that can connect to VGA port on your PC. unless your HP has a DVI port. You need a DVI-I to DVI-I connection to work if it has one
this link will explain the difference of the DVI ports...
http://h20000.www2.hp.com/bizsupport/TechSupport/Document.jsp?lang=en&cc=us&taskId=120&prodSeriesId=51555&prodTypeId=329290&objectID=c01525281
the adapter you need is a DVI-I to vga ...
opensources_1.jpgcheck the pins on both the pc and the adapter and monitor
Sep 14, 2011 | Samsung SyncMaster P2070 20 inch LCD...
My Samsung SyncMaster 2253LW Monitor can't auto adjust problems
if your using a DVI cable instead of a VGA cable you won't need to auto adjust anything because it is done automatically when using a DVI cable. a DVI cable looks like this and a VGA cable looks like this
Apr 30, 2011 | Samsung SyncMaster 2253LW Monitor
I have a syncmaster 400p i need a new graphic processor can u reccomend a compatible one
Good day,
If your screen has a VGA, DVI, or HDMI port, most of the new graphics cards will be compatible with your screen. Most graphics cards come standard with DVI ports and include a vga adapter for the screen cable. Some of the new graphics cards come with HDMI and DVI ports or a HDMI converter if you want to use HDMI.
I would recommend a Nvidia graphics card. Depending on what your primary use is going to be they have an extensive range to cater for your requirements and price range.
Hope this helps!
Regards
Nov 28, 2010 | Samsung SyncMaster 400 T 40 in. Flat Panel...
Samsung syncmaster 2033sw monitor, till now i was using a vga cable for the display, but recently i bought a dvi cable and connected it. but its not detecting the display of dvi cable. if i remove the vga...
LCD Monitors having multiple inputs have option and option to select and switch between the displays from analog (VGA) or Digital (DVI) inputs. Go to the LCD menu and select input source (DVI)
Hope this helps!
CreativeTECH
Nov 15, 2010 | Samsung Syncmaster 2033SW Monitor
I think I might have fried my Samsung SyncMaster 191T, by plugging/unplugging a dvi cable while the power was on (on both the computer and the monitor). Right now, when I enable the display using the...
Unlikely unless you discharged a large static shock into the connector as you were doing this. I have never seen a monitor or computer video port damaged by connecting the cable while power is on.
Try unplugging the power cable to the monitor for 10min or more and then reconnect and see if it starts to work.
Mar 12, 2010 | Samsung SyncMaster 191T 19" Flat Panel LCD...
Floating box says check signal cable
plug the blue cable connection into the VGA port (also blue) on the back of the PC and then turn it on. If you have multiple VGA ports and it doesn't work the first time try the other port.
If the cable is white check that you have a white DVI port on the back of your PC and use that port.
Jun 13, 2009 | Samsung SyncMaster 2233BW 22" LCD Monitor
Jul 25, 2007 | Samsung SyncMaster 245BW Monitor
Samsung SyncMaster 400 T 40 in. Flat Panel LCD Monitor Logo
Top Samsung Computers & Internet Experts
Computer Repairing
Computer Repairing
Are you a Samsung Computer and Internet Expert? Answer questions, earn points and help others
