Question about Maytag Neptune MCE8000AY Electric Dryer
The timer to dry clothes has been getting longer and longer
Ever since we got this dryer. The first day the timer said something like 75 min to dry on very dry setting. Now it's been 2 years, with every load, it got a minute or two longer. I'm now at 1 hour and 26 minutes. Tomorrow it will be like 1 hour 27 minutes. Is there something I need to do to stop this from progressively getting longer? is this normal??
    Problem Solver:
  • 8 Answers
You need to make sure the lint catch area and the whole venting system is cleaned out. It sounds as if the lint is building up and causing a blockage, making drying time longer and longer. Especially if the dryer is doing this on Sensor dry and Time dry settings. There are many different products to use, but the LINTEATER by Gardus is fanatstic, you can usually get it at any hardware/home improvement store. Depending on how long your venting system is it also has an extension kit available.
The lint catch area beneath the screen is a pain to get into, you can buy an attachment for your vac, a thin flexible one is best. There are many online and in stores. But the best way to really clean the lint catch area is removing the lower front panel of the dryer. A service manual would show you how. But if you haven't checked & cleaned or had a company clean the venting system in awhile I wouldn't use the dryer until doing so. It could be very dangerous if there is a blockage. VERY DANGEROUS.
If all your venting and lint catch area is clear and there still is a problem, it could be the moisture sensor or temp sensors in the dryer. If you're not familiar with checking these things w/ a service manual yourself, a service call would be best.
Also, make sure whatever you are using to connect the dryer vent to the wall/roof venting system is a good quality connection with as few loops, turns etc..as possible. Make it as short and straight as you can w/ a better quality material.
Good luck, and please check that venting system ASAP ; )
Posted on Dec 07, 2008
Dryer wont turn on
try to spin the inner drum. You could have a broken belt. if it spins really easy, that's probably what it is. There should be some resistance when you turn it.
Sep 08, 2012 | Whirlpool Dryers
My dryer is not drying my clothes completely. I have to set it to time dry for at least 120 minutes to get a load of clothes to dry. I can feel that the dry is warm .I usually dry my clothes on optimum dry...
Your dryer has a double set of heating elements
1 side of the coils is probably broken and you are getting half the heat.
This is making the dryer take longer to dry them clothes.
Air restrictions in the dryer and vent can cause the heater control to shut down quickly also.
If you have a bad breaker the power will sometimes work and sometimes not.
If all of these are good you might have a problem with the timer.
Most of the GE timers have leaf switches in the that get a burr on the contacts. The come apart simple enough.
I have more HERE
Apr 01, 2011 | GE DWSR463EGWW Electric Dryer
Takes long to dry clothes
on your side, it is better you don't touch anything internal in the dryer as you can hurt yourself and spoil the device even more. have a professional take a look at it before you use it any further.
Jun 11, 2010 | Kenmore 62802 Electric Dryer
Dryer taking longer to dry clothes
For a gas dryer:
Assuming the dryer is working properly and the control cycles are ok, look for things like a restricted venting system which inclides the exhaust, lint screen, etc. This would be the large pipe connected to the dryer exhaust that vents outside.
If it's an electric dryer, there could be issues with heating elements, thermostats, a control board, the timer, etc. Also check for any excessive lint build-up.
Apr 12, 2009 | Dryers
Dryer starts drying and thinks clothes are dry, but they aren't
Check the timer, and the sensor. Sounds like it is having a problem with the timer or sensor no noticing that the clothes are still wet. Please rate if satisfied. Thank you
Feb 12, 2009 | Kenmore Elite HE4 Electric Dryer
Sensor dry timer problem
Clean off the moisture sensor bars. They are the silver curved strips about 4 inches long inside the drum near the lint fitler. If you use fabric softner sheets, a waxy build up will coat the bars. The dyer can no longer sense the damp clothes, so it goes into the cool down and then shuts off. Time dry bypasses the moisture sensor.
Nov 30, 2008 | LG DLE5977 Stainless Steel Electric Dryer
UN-ending Auto dry cycle
This is caused by the dryer vent being blocked and not allowing the moist air to be removed from the dryer. To confirm this. Dry a load of close in a timed dry setting. Set the time on a specific time and then start the dryer. Wait for about 5 min. See if the timer has moved. If it has then the problem is not the timer. It is the exhaust vent being plugged up somewhere. Moisture how the auto dry setting works. The dryer sences moisture and runs longer to dry your clothes. With the dryer exhaust vent blocked, wet moist air is comming back into the dryer and fooling the sensor into believing the close are not dry and runs for a very long time. It is not uncommon for this problem to cause a dryer to never shut off. Your dryer exhaust vent is plugged up with lint somewhere.
Nov 10, 2008 | Dryers
LG DLEo332W electric dryer not drying full time
you have to change out the timer motor...
http://www.partselect.com/repair.aspx?appliance=dryer&part=dryer-wont-heat
Jun 08, 2008 | Dryers
My hotpoint vtd00 dryer seems to have stopped drying
Have you cleaned the exhaust ducting? The duct that runs from inside to outside. Try that first. Sounds like your exhaust line is blocked. Also with the filter out get a flash light and look down the venting if alot of lint vaccum out. NOTE: Unplug the unit, wheather gas or electric.....and if it is a gas shut off the gas to the dryer before moving just in case something gets loose while moving. Hope this helps.
Nov 11, 2007 | Hotpoint NWXR473EV Dryer
Maytag Neptune MCE8000AY Electric Dryer Logo
115 people viewed this question
Top Maytag Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Are you a Maytag Dryer Expert? Answer questions, earn points and help others
