Question about NEC (MTLAMP820/1020) Projector Lamp for MT820, 102
Nec projector vt590 doesn't project RED
18 month old nec vt590 projector that's been used less than 100 hours doesn't project RED, just BLUE and GREEN. On occasion the RED will flash in for a moment, then back to the B & G. Any ideas what's wrong?
  • 3 Answers
Red, Green, and Blue signals come from different wires in the VGA cable.  This sometimes happens if a cable simply is not connected fully.  But it will also happen if the cable is damaged.  The damage might be visible in the form of a bent, broken, or missing pin.  Or it might be internal to the cable.
Try another cable.
If that's not it, then the connector on either your computer or on the projector itself might be damaged.
Also try another computer.
Components inside the projector could also fail.  But I'd bet on a cable problem any day.
Posted on Jan 12, 2009
Lamp not glown, how check lamp is faulty or ok
These use a high voltage discharge bulb and there is no easy way to test them. The power ballast could be tested but that takes a special meter.
Oct 16, 2015 | NEC MultiSync VT590 LCD Projector
Red not projecting
Yes it could be the cord or it could be the projector or the PC
Apr 14, 2017 | NEC NP400 Projector
When on "computer" mode I
disconnect the cable at the projector end and plug into a monitor to check that the video signal is enabled on the cable. If it is then reconnect to the projector and select a lower resolution on the pc screen setting. See if anything appears on the projector
Aug 24, 2011 | NEC MultiSync VT590 LCD Projector
I have a nec vt590 projector.When you watch a movie. A big spot appears in the center of the screen. I believe one of the three lcd panels that is attached to the lense has overheated and is distorting...
If it is a bluish colour then the organic polarizer plate that allows the blue light to pass through it to the blue lcd panel is burnt due to old age.
If the spot is made up of pixel shaped spots rather than a blurred area, then perhaps the lcd panel is faulty, but this is less frequently the case.
You could disconnect the power cable and remove the cover and look at the optics parts to check where any overheated parts can be found.
Then you can be certain which bits to replace.
Another option is to buy a faulty VT590 unit off ebay for a fraction of the price and have a go at swapping the parts between the units.
The lcd panels can be removed and replaced, but require precision alignment and you need the extender cables to be able to do it successfully. So give that a miss, replace the whole lcd prism assembly as one item.
Hope this helps.
Apr 10, 2011 | NEC MultiSync VT590 LCD Projector
The projector is an NEC model VT590 and is connected to my computer for use with a SMARTBoard. In the bottom left hand corner a pink colour is starting to grow inwards. In the upper left hand corner, there...
It is not the smartboard, lamp or the computer as well know, it's the projector itself. This may not work but you at least need to try press the auto adjust button on the projector and then adjust the clock/phase in the menu. If not you will need to send in to NEC it could by the color wheel. Usually they have a warranty for a couple of years.
Jun 05, 2010 | NEC MultiSync VT590 LCD Projector
Wd 62327 DLP red 3 blinks 1 steady red light
Call for waranty repair if less than 3 months old.
Jan 08, 2010 | Mitsubishi WD-62327 62" Rear Projection...
NEC Multisync MT1000 Projector - Green Hue
its not the bulb problem . the lcd block need sto be replaced , better to buy new projector
Feb 06, 2009 | NEC MultiSync MT1000 Multimedia Projector
Nec projector vt 660
could be bad bulb is it setting in right is coler wheel freeley moving
Oct 06, 2008 | NEC VT47 Multimedia Projector
Two problems, first the menu appears to be burned into the projection, the bulb has less than 100 hours. Second when black is supposed to be projected it projects blue?
You have a bad lcd, you would probabaly have some blue lite leakage also. Any lcd projector should not be left on the same image for long periods, it wears out the pixels that control the lite thru. The blue lcd is usually the culprit.
Jun 12, 2008 | Sony VPL PX40 Multimedia Projector
NEC (MTLAMP820/1020) Projector Lamp for MT820, 102 Logo
504 people viewed this question
Top NEC Office Equipment & Supplies Experts
jasbo
jasbo
Are you a NEC Office Equipment and Supply Expert? Answer questions, earn points and help others
