Question about NEC PlasmaSync 42MP3 42 in. Television
Recently my Plasma has been displaying a range of flickering red and orange pixels across the whole screen when I turn it on. After a while they disappear 1-2 mins. Turn it off and on again no problems. If I turn off and leave off for about 10 minutes plus it happens again! Even with no other signal source attached to the plasma I get these symptoms! Had the unit for 4 years - was thinking of getting a technician out - thought I'd try a post first - :-) Any help appreciated!
  • hphubbard Jan 27, 2009
    During warmup (for teh first few minutes), the top 4-8 inches of my screen has these green and yellow vertical lines mapping with the image in that area.
    After a few minutes, the image is fine.
5 Suggested Answers
SOURCE: NEC Plasma Sync 42MP3 Problem
Hi, This model has some design flaws and yes NEC admitted to them a year ago. The problem with your monitor (hopefully) is a bad power supply. Have a Tech with a voltage tool check the boards as well as the connections Reason, this monitor generates a lot of heat ( no cooling fans) primarily at the power supply and sits there. So the wires tend to go weak by the heat build up. What the problem is the power is not going to the correct board in the right voltage. hope this helps out!!!
Posted on Jan 16, 2008
SOURCE: ariel
Its NOT a TV, its a display. It does not have its own TV tuner or RF converter. You have to runit from a VCR, A DIgibox or SKY TV.
Posted on Aug 20, 2008
satavlad
  • 405 Answers
SOURCE: need the part number for a remote control for nec
REM-T HAND UNIT RD-337 p/n 079646722
Posted on Dec 29, 2009
budmrtn
  • 11361 Answers
SOURCE: nec plasma sync 42mp3 doesnt
It does not have TV tuner, it is just a display for Video source, you will need Tuner box.
Read about it here:
http://www.plasmatvbuyingguide.com/plasmatv/nec-42mp3.html
Please leave rating if it helps.
Posted on Mar 06, 2011
PlasmaSync 42MP3 42 in. Television: i bought a anec hooked up speakers i cant get audi...
I dont' have the fix but I do have a work around. You can hook your source directly up to a surround sound unit if you have one using red and white audio cables to the aux input on the surround sound system.
May 07, 2010 | NEC PlasmaSync 42MP3 42 in. Television
I have a plasmasync 42 mp3 and the picture looses about 20% of its brightness. after a while, the normal picture returns but then it switches back to the duller image after 30 min or so. It's not the...
Exactly the same problem here on same model NEC but problem more intermittent, some days can be fine others unwatchable. Can see many dark pixels when i lose brightness, looks a bit like a big square patch over the screen. You ever manage to fix this gemguy?
Dec 14, 2009 | NEC PlasmaSync 42MP3 42 in. Television
NEC Plasmasync 61mp1 - won't turn on
Its the power supply board. If you cant get the whole board, check your transistors theyre most likely FSXXX-X (part #). Replacing them should solve the problem. And they're only about a dollar each so youll save a bunch too but it requires a little more work.
Mar 24, 2009 | NEC PlasmaSync 42MP3 42 in. Television
Ariel
Jul 27, 2008 | NEC PlasmaSync 42MP3 42 in. Television
Jan 06, 2008 | NEC PlasmaSync 42MP3 42 in. Television
Nec 42'' plasma
Try holding down the 'INPUT SELECT' button, then press the power button on, on the tv at the same time.
Oct 29, 2007 | NEC PlasmaSync 42MP3 42 in. Television
NEC plasma television
hi jubbi, actually i'm not sure your problem you describe. So you can go to this link http://www.fastrepairguide.com/plasma-tv-pdp-information/how-to-describe-explain-the-plasma-tv-problem-or-sym.html see your plasma tv problem is it inside this guide?
Aug 31, 2007 | NEC PlasmaSync 42MP3 42 in. Television
NEC plasmaSync 61mp1
this sounds like the engine or the lamps are bad.
Blank Screen
Hi Gemma - have a look at this forum - it may be similar to what you are experiencing. http://forum.eserviceinfo.com/viewtopic.php?t=5411&postdays=0&postorder=asc&start=0 Things don't look good for NEC owners I must say! Good luck Saty.
Dec 28, 2006 | NEC PlasmaSync 42MP3 42 in. Television
NEC PlasmaSync 42MP3 42 in. Television Logo
63 people viewed this question
Top NEC Televison & Video Experts
Kyle Steven OHare
Kyle Steven OHare
Jerry Greenberg
Jerry Greenberg
Are you a NEC Televison and Video Expert? Answer questions, earn points and help others
