Question about HP LaserJet P2015dn Printer
Printer not printing documents sent to it
There are several icons on the top of the printer, one is for ink, one is a paper jam, one is a broken circle (quarter arc is missing from the circle) - what does this icon represent, it is lit up?
    Problem Solver:
  • 8 Answers
Your talking about the LED with a horseshoe Icon. This LED should be green and it means the printer is ready to print if this the only LED lit.
If this LED is flashing, it means its processing some print job or is printing something.
Posted on Nov 24, 2008
On printer error cod 6A00 displayed, on computer screen icon says service error 5C10. Have cleaned ink wells and wiped off excess ink. After cleaning far right side a long skinny black piece came out,...
Hi
Error 5C10 means a paper jam or the printer has encountered an internal error. And error 6A00 is caused due a paper jam in the sheet feed unit or near the print head. You can also reset the printer to resolve this issue. On the printer press and hold the ON/OFF button or unplug the power cord. Wait for 10 seconds, press power button ON/OFF button again. If this doesn't resolve the error code then unplug the printer for 10 minutes. Also, inspect the back panel of the printer for any paper jams. To clear the paper jams---
Turn off the printer and disconnect the power cord and USB cable. Remove the jammed paper slowly using the following procedure. Open the rear cover to check if the paper is jammed. Pull out the cassette and check if the paper is jammed inside the cassette area. Stand the printer with the rear side down, holding the document cover. Press the tabs together and pull the green cover toward you. Check if the paper is jammed. (If you were not doing Duplex printing, you do not have to follow this procedure.) Close the green cover and place the printer back to a normal position. Reconnect the power cord and power on the printer. Confirm the Alarm light is off. Load paper back into the ASF or cassette. Press to clear the message and continue printing. If you are printing from application software, follow the instructions displayed on your computer. Hope this helps... Please post back if you need more information.
Daniel
Jun 20, 2011 | Canon PIXMA MP830 All-In-One InkJet...
There is a paper jam
The solution depends on which type of printer and which model it is. Generally, you must open the access door/compartment and try to get the paper out. I had a bad paper jam last week and I had to open the access door (same access area you use to change out the ink cartridges) and do a lot of pulling and maneuvering. Don't force the paper too much or you might break the printer.
Mar 06, 2011 | Kodak Office Equipment & Supplies
Printer is only half printing doc on each line, have done test page, very faint, aligned ink, clean cartridges, all with top v faint and bottom dark ink, new cartridge last fri and was working well,...
Open the rear of the printer and make sure theres no paper jam or broken parts.
Try printing a document with the rear of the printer open and watch to see if anything out of the ordinary happens.
Mar 01, 2011 | Lexmark X8350 Print, Scan, Copy and Fax...
I finally cleared a paper jam, and now my printer is trying to reprint all the documents I sent to print while there was a jam. I do not want these to print since it will waste a ton of paper and ink. How...
There should be a little print queue icon down by the clock.  Double-click on this to open the print queue program.  From there you can remove jobs from the queue.  NOTE:  It can take a minute or two for jobs to remove themselves.  It's not instant.
Please rate me if you found this helpful.  Thanks.
Mar 07, 2010 | Dell P1500 Laser Printer
I am a returning consumer i had problems with my printer printing from the computer. prior to contacting you the printer would print from the scanner. i was instructed to reboot the computer and the...
Hello
The reboot of the pc along with a unplug of the printer should clear the printing. Do you have several printers listed to print to and did you print to the wrong one perhaps.
You say the unit would print from the scanner which is sort of odd as well. My scanner prints but only cause it is hooked to the PC.
there will be a large additional charge :-)
Jan 25, 2010 | HP Photosmart C5180 All-In-One InkJet...
Both paper feed and power lights flash after printing several pag
lean head-eject ink ruler & clean point of contact betwin cartridges and head-ink unit.
Aug 07, 2009 | HP DeskJet 970cxi InkJet Printer
Left corner of paper wrinkles when printing
I know several reasons, and they are all related to an obstruction of some sort..whether it be a small piece of paper along the paper path, to something slightly bent, or broken...impossible to say for sure
Feb 28, 2009 | HP Photosmart C5180 All-In-One InkJet...
Error messages
Simply pull all the paper out, cancel all printing documents and then print the document (without putting the paper back) and if it comes up with the error that there is no paper than there is no jam and putting the paper back should be fine, however to be on the safe side try printing at first with one piece of paper for the first sheet then put a buch slowly adding to the pile per page utnil all the paper has been put back.
Hope theat Helps ^^
~VD
Oct 09, 2008 | Epson Stylus Photo R300 InkJet Printer
Will not print
We will experience this issue if the documents are pending on the printer icon or if the printer icon is paused. Check the status of the printer icon in control panel and clear all the pending documents and make it online if it is offline and then try to print.
Apr 28, 2008 | HP OfficeJet 6110 All-In-One InkJet...
HP Laserjet 1020 - prints blank documents
in my printer the resistor R348 on the motherboard printer was broken. The value that must have is 10 ohms. I have changed and the printer has resumed work.
Dec 05, 2006 | HP LaserJet 1020 Printer
HP LaserJet P2015dn Printer Logo
407 people viewed this question
Seeker5211
Seeker5211
