Question about Hotpoint NVL333EY Electric Dryer
When the dryer gets hot it turns off, the dryer does dry
After using the dryer a couple off times, it becomes extremely hot and it turns off. We let it cool off and the dryer turns on again. The dryer does dry.
  • 706 Answers
Here is a link for an exploded view of your dryer
You may have a bad thermal limiter item # 1236 and your thermal safety switch is cutting in to disable power to your heater before it causes a fire. You may have a bad power resistor item # 1114 as well. Difficult to say which component is defective without being able to take measurements.. Hope this gets you headed in the right direction. Please remove or disable power before attempting to trouble shoot ( if you are doing this yourself)
Posted on Nov 25, 2008
We have a gas dryer purchased in 1996, Model #CDG800W. The dryer has started to make a strange grinding sound when we're drying clothes. Any suggestions?
Most likely a bad blower wheel. Over time the hub gets hot, melts, wobbles out, and start to rub the blower housing. The wheel slips and makes it take a long time to dry the clothes. This causes the filter to warp and the top to get extremely hot.fdd151b.jpg513b315.jpga1f312f.jpg77fbb60.jpg
I have posted more repair photos here
Nov 01, 2010 | Crosley Dryers
Kenmore Elite Oasis dryer 110.6708 that gets too hot
did u clean machine filters? in the back of your machine there is a big silver pipe itmay need to be clean too
Jan 21, 2010 | Kenmore 67082 Electric Dryer
My electric dryer is becoming extremely hot during the drying cycle. I replaced a blown thermal fuse several weeks ago and the dryer was extremely hot at that time. The dryer runs but becomes so hot you...
Clothes will get very hot in the dry cycle, especially when the dryer is set to the warmest or hottest setting.
There are controls built into the unit to prevent it from overheating to the point of causing a fire. The thermal fuse you replaced is one of them (and I assume you replaced a perfectly good fuse with a new one as you said it was very hot.).
You might want to check the following if you feel the unit is getting too hot -
1) Make sure the lint screen is clean.
2) Make sure the hose between the back of the dryer and the exhaust duct at the wall wall is not kinked or full of lint.
3) Make sure the exhaust duct leading to outside of the house is clear and not full of lint.
Let me know what you find.
Dec 14, 2009 | Kenmore 62602 Electric Dryer
Takes long time to dry clothes
clean out hose or if it's to long cut to fit with no slack thank you for useing fixya rate me
Mar 30, 2009 | Kenmore 73952 Gas Dryer
Dryer turns on, gets hot, but knob does not move with timer.
could be your operating thermostat on your heater or your timer if it runs on timed dry but not auto dry then it is a thermostat issue if it just does not run at all then it is a timer issue also make sure your vent is clear check by removing vent hose from back of unit and running a load if it works properly clean your vent.
Feb 23, 2009 | Hotpoint NVL333EY Electric Dryer
Back & top of dryer get hot, clothes take long time to dry.
First thing to check for is blocked airflow. Check the dryer as well as the venting from the back of the dryer to the outside of the house good airflow is neccessary. You could remove the venting from the back of the dryer and run a load to see if that helps. Do not leave it off as it is exhausting lint and if a gas dryer spent fuel.
Jan 08, 2009 | Maytag MDE2600 Electric Dryer
Dryer not drying
be sure vent to outside is not blocked or hose behind dryer flattened..quick ck is to dry a load with rear hose disconnected..if problem still there suspect heating element elements are double strung if 1 coil is open (burnt into) dryer will not get hot eneough
May 19, 2008 | Hotpoint NBXR463EBWW Electric Dryer
The top of the dryer gets very hot, but inside the clothes are not drying. I have to dry the clothes 2 or3 times.regular size load. When I use cotton setting, it's worse. Water gathers along the inside of...
okay this is a easy problem, your dryer is clogged, check your vent hose and make sure it is not kinked, also check your vent duct from wall to outside...What is happening is your heat and lint is not going outside but it is going back into your dryer, causing your dryer to get extremely hot....
your dryer is suffocating
marclavoris/Whites Appliance Repair
Apr 03, 2008 | Dryers
Clothes not drying
A couple of possibilities to check. First, is the lint trap empty? If so, then the symptoms point to hot air bypassing the drum. Look for broken or misaligned plastic ducting inside the dryer itself. Check the exhaust air for moisture, as that is a better indicator than temperature. Don't forget that towels hold an enormous amount of water, & can be extremely long in drying, especially if not spun enough.
Jul 10, 2007 | Kenmore Elite HE4 Electric Dryer
Hotpoint NVL333EY Electric Dryer Logo
349 people viewed this question
Top Hotpoint Dryers Experts
Gerry Harvey
Gerry Harvey
shaun taylor
Are you a Hotpoint Dryer Expert? Answer questions, earn points and help others
