Question about GoVideo DV1030 DVD Player/VCR
Bad disc problem
I have a Go Video model DV1030 VHS/DVD combo unit that I have played only 3 or 4 DVD's on. Then unit is a little over 3 months out of warranty. When you load a DVD; 99% of the time I get the "bad disc" message displayed on the screen. As I have technical background on some electronics; I opened the unit, on my bench, to see what I could observe happening. I can tell that the laser is functioning. When the DVD loads I can see the laser assembly attempt to track on its guide rails to find the starting position. It looks like it finds the start position; but, again, most of the time it states I have a bad disc. I disassembled the unit far enough to remove the DVD sub assembly from the chassis. I reseated all the ribbon connections and re-lubricated the laser assembly guide rails. At first I thought this had resolved the fault; but after testing a few DVD's the problem started happening again. It appears that the movement of the laser assembly is inconsistent when loading a DVD. Sometimes it seeks the start position; and other times it doesn't move at all when a DVD is loaded. It looks like it helps sometimes if I physically move the laser assembly off of home position; forcing it to really have to try and find out where it is. The only other thing I haven't tried is a careful cleaning of the laser lens. As I have had "some very limited success" at getting a movie to play; it doesn't seem that there is a contamination issue on the lens. However; never say never. I will attempt blowing off the lens with compressed air and see if it helps. I'm still leaning towards a logic or other hardware fault as the "root" cause. I am also going to attempt to contact the Go Video people for feed back; but from other message boards I've read I give that about a 0% chance of being any help. Any thoughts or suggestions?
  • Anonymous Jan 25, 2008
    Same machine,same"Bad Disc"-no clue what to do-Fair Tax Man is way past my knowledge level.
  • Anonymous Jul 13, 2008
    It will play maybe one out of every ten movies. All the others has the bad disc message.
    Genius:
  • GoVideo Master
  • 1,689 Answers
I assume you claned the laser lens.
It may be an alignment problem, or the laser is on the edge of proper specs, or there is an electronics fault in the reading of the laser, or the servo control that is on the edge.
You cannot test the laser by assumption. To know if it is up to proper emission, you need the laser emission tester for DVD and CD lasers.
If you are experienced at aligning CD and DVD players, to check the alignment you will need the factory alignment disks, a 100 mHz digital scope, DVM, and the service manual.
Jerry G.
Posted on May 14, 2008
How do I play the second movie on a double feature dvd disc?
Hi Tia, put the disk in and when the main menu comes up select the movie you want.
Apr 03, 2018 | Televison & Video
No read record or play
A combo unit with DVD and VCR---if the DVD WILL not read the disc etc it is almost always with this type of unit a dirty or bad optical pickup in that unit.
Oct 30, 2012 | Televison & Video
I have my Samsung model dvd V9800 hooked up to my RCA RT2906. The dvd side is showing a picture but the video side is not. The RCA RT2906 has have a hook up for a vcr player by it's self but I do not think...
VCR video signal wont come out from Component Video Out of combo unit, it is low resolution signal so you need to hook yellow-red-white video cable in tv for VCR output.
Make sure to select VCR as source in combo while playback of VHS tape and select DVD as source when playing dvd disc in combo.
Hope these info will help you.
Let me know if you have additional question.
Thanks.
Dec 04, 2010 | Samsung DVD-V9800 DVD Player/VCR
Burned dvd doesn't work in other dvd players
Make sure that you finalize the disc when recording is finished, also some DVD players prefer DVD +R
Sep 07, 2009 | GoVideo Go Video DVD/VCR Combo
HOW DO I RECORD A DVD TO A VHS ON A VHS DVD COMBO BY PHILIPS
Cannot do this on a combo unit. There is a chip that senses copy protection and prevents recording a copy-protected DVD to a VHS and vice-versa. Solution: Use an outboard DVD player or an outboard VHS VCR and try the recording with the video routed through a "stabilizer" box. The stabilizer (about $30 or less on Ebay) defeats the copy protection on MOST DVDs, but not all. It works with Netflix DVDs. Route the audio as usual. Audio is not protected.
Dec 15, 2008 | Philips Magnavox MWR20V6 DVD Recorder/VCR
Can I upgrade an LG v782w combo DVD/VHS unit to play DivX Discs?
Turn on the DVD player with no disk, wait until the 'no disk' label pops up then press
1. 'Pause'
2. '1'
3. '4'
4. '7'
5. '2'
if That Don"t Work Im Out Of Options
Jul 07, 2008 | Televison & Video
LG DC593W - DVD & VHS Combo
hmmm..ok...sounds like a video setting issue on the way in..you'll need to go to the menu, and reset the input settings, so it's in alignment...
May 27, 2008 | LG DR-4810 DVD Recorder
VHS has audio but no video
we cannot get the vcr portion to work only the dvd player4.gif works what are we doing wrong?
Have the same problem? Click Here
dc2eb76.jpg MikeNJ1964
Rank:guru_s.gif Guru
Rating: 88%, 431 votes
On some of the DVD/VCR combo units, the VCR output is only available through the RF jack (channel 3), standard video1.gif (yellow) RCA jack and S-VIDEO jack. If you are using the Component jacks, the DVD side will work but the VCR will not. This is because the quality of video recorded on VHS tapes is so much lower than component quality video.
Thank you for rating this solution.
Nov 26, 2007 | Televison & Video
Transfer VHS to DVD
The illustrations within the PDF is very help!
To play disc in other DVD players…
The disc needs to be finalized.
Page 37 of the manual has “Finalizing a disc”.
Recording from DVD to VCR…
Page 39 “Dubbing Mode”
http://www.funai-corp.com/support/manuals.aspx
Type in the box: MWR20V6
Nov 09, 2007 | Philips Magnavox MWR20V6 DVD Recorder/VCR
Various LG DVD Player
Some models of PIONEER cd players had radio frequency problems that caused them to work on and off. Are you near any radio or braodcast towers? Poorly shielded power supplies cause this as well. A weak laser diode in the pick-up assembly in model runs could be the problem. You might want to Google the model number and see if this is common for these units.
Apr 27, 2007 | LG DK 9411P DVD Player
GoVideo DV1030 DVD Player/VCR Logo
121 people viewed this question
Top GoVideo Televison & Video Experts
Demonic-2011
Demonic-2011
Computer Repairing
Computer Repairing
Are you a GoVideo Televison and Video Expert? Answer questions, earn points and help others
