Question about Jandy AQUALINK RS TELELINK KIT
Auto shut down function not working (Jandy Aqualink RS6)
My system is suddenly unable to shut itself off when the timer usually does shut it down. It indicates off at the indoor pad, but the pump continues to run. In attempting to shut it off at the outside pad, it is non-responsive to commands and does not shut off, nor does the "service" pause work either. The lights move as though it is working, but there is no action from the system other than ON. I have been able to "turn back on" at the inside pad and then "turn off" and that has shut it down (manually). Then next cycle the next day (or the freeze protection which turned it on overnight) will kick it back on, but again it won't shut off. Any ideas?
  • 6 more comments
  • betporter Nov 27, 2008
    I am unable to shut off my pool pump from the indoor Aqualink control buttons. The service panel outside also will not allow me to turn off the pump in any of the modes, Auto, Service of Timed Out. The only way I can turn on and off the pool pump is using the breaker switch in the panel. I have changed the 9V battery at the panel and also reset the controls but nothing seems to work. However, the indoor Aqualink control is still able to turn on and off the Spa, Water Feature and all the pool lights. Help!
  • tex_toolman Dec 03, 2008
    I am having the same problem. The indoor display says that everything is off but the pump is still running. The outside control box is in Auto. When I try to switch to service it is still running. I had to turn the fuse off as well.
  • peteatlanta Dec 08, 2008
    I have the same problem.
  • jbzer74 Jan 19, 2009
    Same problem as above. Going to test out the solution given...seem like it should work. Will post my results.
    Thanks for the help!
  • hornman41 Jan 27, 2009
    jandy indoor display says pump on but wont turn on outside
  • mfstansbury1 Feb 22, 2009
    Same problem - system worked flawless for about 8 years then my pump suddenly would not shut off. It was a head scratcher until I saw the posted solution about the relay switch. Sure enough, I saw that the black tab on the bottom of the relay was not moving. I shut off the main breaker to the junction box and moved the switch as few times with a screwdriver and problem solved. I will probably have to replace the relay eventually but that looks like a simple fix. Thanks for the solution!
  • marmarmar72
    marmarmar72 Jun 20, 2012
    I just want to say THANK YOU so much! I had exactly the same thing with mine. The filter wouldn't shut down and would just keep on running after the filter cycle time was up. I read all the comments below and it all sounded like me - had to shut it off using the circuit breaker, and would turn right back on when the circuit breaker was turned back on regardless if it was filter cycle time or not. I messed with the relay switch on the bottom as mfstansbury1 recommends and that would shut if off, but after the next cycle it would pop out and would not shut down again. I installed a new one <$70 at NPS> and it took about 25 minutes. It was super easy and everything is working now. Thank you everyone for commenting and adding your thoughts!
  • Jack Anderson
    Jack Anderson Apr 26, 2015
    On my Jandy AquaLink RS, the tab is down (out) when the pump is OFF. When the pump turns on the tab goes up(in). I did the same as mfstansbury and it works fine.
  • 22 Answers
Jandy relays are known to stick. You can diagnose this yourself with a screwdriver. Remove the four screws on the outside panel. You will see a series of black rectangular relays and a lot of wires. Typically the pump relay is the one in the upper right. It will certainly be the one plugged into the left hand socket at the bottom of the circuit board.
Be sure to do all of this simply be looking. You can move the twisted red/black wires a bit to determine which relay is plugged into the first socket. Try to notice on the bottom of the relay a small black tab that is sticking out. When out, the relay is on. If the pump is running, this tab is out. If you then put the controller into service mode and the lights go out without the tab popping back in, you have a bad relay. If turning the pump off does not put the pump light out, you have a bad board.
In most cases, the relay is bad and it is a simple fix.
Posted on Dec 22, 2008
  • Dau Le Dec 15, 2013
    I have replace with a new relay ( upper left ). But the pump still going on after timer reach off timing. Red light blinking for heater to tutrn off, but filter pump keep running. What else can I do now . thanks
RS6 All panel lights lite up window displays 6700 Rev C
Posted on Jul 21, 2010
  • Dave Witte Sep 17, 2012
    how do you replace relay?
My indoor control board (RS6) would light up for long periods, during which none of the control buttons could activate their function. Pushing the reset button (lower left hand side of case of the inside panel) accomplished nothing. The problem was a sticky reset button (recessed) on the outdoor control panel. The reset switch itself was fine. In any case, I lightly lubed the recessed button, which now moves fine.
Posted on Oct 22, 2009
Why is the Jandy RS6 Intellitouch Controller Extra Aux / Solar power plug always ON/Powered?
Your logic seems workable...
(I got nothing ... should work).
Trouble shooting says to check & clear "phantom"
programming... (Pg. 30: sounds like hokum 2 me).
My best advice..
Go to page 40 and contact their customer support.
Jandy AquaLink RS Installation Manual Warranty
1-707-776-8200
Carnac the Magnificent
Jun 22, 2014 | Jandy AquaLink RS All Button, Wired, RS6...
Aqualink rs6 loses date and time
if it loses time and date when turning off power needs new battery in aqualink 9 volt old style round nickel cadium on back of PCB board on new models
Apr 12, 2014 | Jandy Aqualink Rs4 One Touch Control...
I have Jandy/Zodiac LRZE legacy heater and Jandy RS6 controller. When hooked up to RS6 and there is a call for pool heat the heater ignites but shuts off in about 30 seconds. When I disable the TSAT...
check your dip switches on the inside panel of the aqualink if you still cannot get it to work i would use the pool to 1 wire of a new wire you will run to the heater then 2nd wire to com then on the on the PCB board going to pins 1 and 2 of the big plug then turn heater all the way up when heater button is pushed or activated it will turn heater on and off
Aug 05, 2013 | Jandy Legacy LRZ Heater
I am replastering my spa and want to put a new LED light in. Can I control the different light functions with th Aqualink and the button on the spa deck?
I have a Aqualink RS one touch control system, model 8157 RS6 Combo. The backlight in the control panal is out, the panal works fine, but does not light up, so it is hard to read. How can I replace the light? Do I have to replace the whole panal unit? Is there a bulb to replace? thanks, David
Feb 23, 2011 | Jandy Aqualink - Rs24 One Touch Pool / Spa...
I have an Aqualink RS6. light button pops GFCI
This is in your lights. Ether you have water in one of your lights or a short somewhere in the system. Were these new lights or just new bulbs?
Apr 28, 2010 | Jandy AquaLink RS2/6 All Button Dual...
Jandy AQUALINK RS TELELINK KIT  Logo
4,099 people viewed this question
Top Jandy Pool & Spa Experts
David Spradling
David Spradling
Craig Butler
Craig Butler
jhalston
Level 1 Expert
Are you a Jandy Pool and Spa Expert? Answer questions, earn points and help others
