Question about Intel Computers & Internet
Windows xp freezes when i start computer
Went to device manager and started to disable each device. im in safe mode by the way. under processor in device manager i have 2 items, both items say Intel Core 2 Duo E6750@2.66 GHz. when i disable one of them my computer starts right up. it doesnt matter which one i disable as long i disable one of them, it will start right up. i can surf the web and do emails, but i cannot play any computer games. i have a nVidia 650i Core 2 Quad (nforce 650i Ultra) motherboard. if i replace the processor will that solve my problem? thanks for ur help. Lance Murry
Hi space, thank u for ur replay. this is a gaming machine so i have a temp gauge on the front. and the temp is around 95 degrees when the puter is on. i have three cooling fans. i contacted the company that built this machine and they called me back the next day. and all we did was click on the default in the bios and now its working again. hope this helps someone down the line. Lance Murry
Posted on Dec 02, 2008
    Sergeant:
  • 177 Answers
I nthink the processor is overheating. Check the cooler. Also disable The option such as smart fan if there is any.
Posted on Nov 24, 2008
Sony vaio all in one touchscreen stopped working
XP and Vista Normal Mode Start your computer as you normally would. Click the "My Computer" icon on your desktop. Go to "C:\ Program Files\Sony\Setting Utility Series." Find and choose the "VCCPointingDevice" folder in the "Setting Utilities Series folder" to open the "Built-in Pointing Device" dialog box. Locate the "Enable" box on the "Built-in Pointing Device" dialog box. Check the box to enable the Vaio touchpad if you wish to use this device. Disable the touchpad if it is interfering with the external mouse. Uncheck the "Enable" box if you have a USB (PS/2) mouse connecting to your Vaio and wish to use that instead of the built-in touchpad. Pick "Yes, I'm Sure" when prompted to activate your choice, then close all the windows. Windows 7 Normal Mode Launch Windows as usual. Go to "Start" > "Control Panel" > "Mouse" > "Pointing Device" to open the Vaio touchpad control center. Uncheck the "Enable" box on the "Pointing Device" window when you wish to use your external mouse. Check the "Enable" box on the "Pointing Device" window when you want to use the Sony Vaio touchpad. Make sure the external mouse is not interfering with the touchpad if you have one connected. If so, unplug the mouse from your computer. Click the "OK" button at the bottom of the "Pointing Device" window. Close all other windows. XP and Vista Safe Mode Restart your computer. Press the F8 key before the Windows welcome screen appears to enter Safe Mode. Click "Start" > "Control Panel" > "Add/Remove Programs." Find and delete all software for mice and pointing devices. Restart your computer in normal Windows mode. Proceed to next step if the problem persists. Restart your computer in Safe Mode. Right click the "My Computer" icon on the desktop. Choose "Properties" on the drop-down list. Pick the "Device Manager" tab in the Properties window. Select the "Other Devices" folder and click on the "+" sign besides it. Delete all the devices under this "+" sign by clicking on the "Remove" button next to each of the items. Restart Windows in Normal Mode. Once Windows is operating, there will be a "New Hardware Wizard" pop-up that will load all the necessary drivers for the touchpad, mouse and other pointing devices. This should fix the corrupt driver for your Vaio touchpad. Windows 7 Safe Mode Reboot your computer and press the F8 key before the Windows welcome screen appears to enter Safe Mode. Go to "Start" > "Control Panel" > "Device Manager" > "Mice and other pointing devices." Click the touchpad icon. Choose the "Driver" tab and press the "Uninstall" button. Press the "OK" button to confirm. Restart Windows in Normal Mode. Go to "Start" > "Control Panel" > "Device Manager" > "Mice and other pointing devices." Choose the "Driver" tab and press the "Update" button. Press the "OK" button to fix the touchpad software.
http://esupport.sony.com/perl/swu-list.pl?mdl=PCGFRV26
Feb 08, 2013 | Sony VAIO Computers & Internet
Sony vaio touch screen stopped working
Feb 08, 2013 | Sony VAIO VGC-LV180J 24-Inch All-in-One PC...
Windows XP Professional, can't log in, try to type
Which model of laptop ?
Nearly every device in your computer system can be turned off and on by accessing the Windows Device Manager with a few clicks of the mouse. It gives you plenty of flexibility and allows you to customize your computer on a whim. The Device Manager will allow you to enable your factory keyboard and mouse and disable your current ones, effectively resetting them to the default settings
Make sure that your default mouse and keyboard are plugged into your computer. Click on the Windows "Start" button in the lower right corner of your desktop. Type "Device Manager" in the "Start Search" box. Click "Device Manager" under "Programs." Click "Continue" if the Windows permission window pops up. Click the "+" next to "Mice and other pointing devices." Right-click the default mouse and click "Enable." Switch to your default mouse then right-click your other mouse and click "Disable." Click "Yes" in the warning popup window. Unplug the other mouse. Press the "+" next to "Keyboards." Right-click your default keyboard and click "Properties." Click the "Driver" tab then click "Enable." Click "OK." Right-click your other keyboard and select "Properties." Click the driver tab then click "Disable." Click "Yes" in the permission window then click "OK." Your computer is reset to the default keyboard and mouse.
Jan 30, 2013 | Computers & Internet
Software freezing and skipping
Click Start - Run, type in %temp% and then click OK.
Once that temp folder is open and you can view its contents, select and delete EVERYTHING that's inside it.It's all junk and is a good place for "nasties" to hide.
  • Install and run antispyware software
  • Free up wasted space with Disk Cleanup tool
  • Defragment your hard disk drive
For an instant fix use a system utility tool like Reginout to fix windows corrupt registry and missing dll files.
Apr 29, 2012 | Hercules DJ Control AIR DJ Control Surface
Toshiba m45-s355 WinXP sp3, freezes in normal mode after 15 seconds. No error msg. Works fine in safe mode. Steps taken: Deleted partition and reinstalled from mfr disk. Chkd hard drive and memory with...
On the safe mode .
right click on My Computer >>> manage >>> device manager >>>locate processor >>> ( on the second processor >>>right click >>>disable) restart your unit.
Start your unit normally
Aug 16, 2011 | Toshiba Satellite M45-S355 Notebook
My laptop Toshiba A200-1V0 is freezen everytime when connected to the charge. Could you please help me on this ?
If this core 2 duo bug then you need to disable one of two cores in device manager..You can access device manager through Computer Properties than find Processor, disable only one core...
Anyway, if you can't reach your system due to freeze, you can use safe mode...Press F8 key during POST and system will prompt you that you can enter Safe Mode...
Aug 08, 2011 | Computers & Internet
With Vista OS , worked fine, upgraded to windows 7..realized cinedash/multimedia does not work, but ignored..the more irritant is - when A/C power is plugged in, the computer starts rebooting every 5-10...
Try this
Remove the battery, plug in the AC Adapter and reboot into safe mode.
  1. Click on the Start button and then choose Control Panel.
  2. Click on the System and Security link.
    Note: If you're viewing the Large icons or Small icons view of Control Panel, you won't see this link. Simply click on Device Manager and then proceed to Step 4.
  3. In the System and Security window, click on the Device Manager link located under the System heading.
Click on processors
disable all of the processors and restart your computer.
Sounds like the power utility is messing with you...disabling those and rebooting SHOULD solve the problem.
Of course this is just a guess...if you could post an event log of the shutdown that would make things easier.
I hope this helps! If this did help you, please give a thumbs up!
Thank you for choosing FixYa!
Jul 14, 2011 | Computers & Internet
How to uninstall deep freeze 6?
You havent mentioned the O/S you are using, try this if its XP
Here the small tricks to disable or unintal Deep Freeze ver 6 without password:
  1. Boot your computer from Windows XP Installer
  2. After appear “Enter to Setup” option, Press Enter then press F8.
  3. Selected R to repair Windows system ( Repair Setup)
  4. Continue repairing/installing windows untill finish.
  5. Prepare the Deepfreeze v.6 installed, open the file like you want to install the software.
  6. it’s will show “Uninstall Deep-freeze” options. Uninstall the software, after uninstall finished reboot your computer.
  7. Now the Deep-freeze has removed from your computer.
FOR VISTA / WIN 7
Power Off the PC
Start the PC and Press F8 key till you get Boot options,
Start the PC is SAFE MODE and try to uninstall it.
Jul 06, 2010 | Computers & Internet
LAN driver Freezes Computer
disable the motherboards built-in ethernet adapter in BIOS and get an add-on ethernet card. it sounds like your ethernet card is damaged and its affecting the rest of the computer.
May 22, 2010 | ASUS P5B-E Motherboard
Unexpectedly lost graphics, but theres a story to the issue.
You mentioned that you disabled the on-board graphics card using the device mamager.
You should disable the on-board video card in the BIOS.
Go to the BIOS config and disable the Video.
Mar 07, 2009 | MSI RC410M-L Motherboard
Computers & Internet Logo
236 people viewed this question
Top Intel Computers & Internet Experts
Alun Cox
David
David
vsri9
Are you an Intel Computer and Internet Expert? Answer questions, earn points and help others
