Question about Sony Grand WEGA KF50WE610 50" Rear Projection HDTV-Ready Television
KF-50WE610, have some pink lines/area that look like circuits.
Have some pink lines and small (pink) sections on my screen. Looks like little circuits strung together creating these lines/areas. No pattern, random area on the upper part of the screen. Doesn't go away regardless of media (cable, DVD). Called Sony service who said to Power down the unit. I did this for one hour but no change. Pink area/lines still there. The unit is 5 years old. I changed the lamp about 4.5 years ago. No other service has been done. Unit was recently moved cross-country but has been working fine for last 3 months.
  • 5 more comments
  • jimsaka Nov 24, 2008
    What board are you talking about? I don't want to solder something. Do I need to get a Sony tech in to change out something?
    I rather replace the main board knowing it gets done right vs. me trying to do it. What is the part number I need to order from Sony. Any idea of cost? It is easy to replace?
    Do you have a part number of the main board? I went to the link and they don't show anything under the product model number
    Do you have a part number for the main board?
    Had a spare lamp and changed it. Not the resolution. Pink area and lines still there.
    Do the screens go bad? It's like it's the screen itself. Getting picture, etc is fine. The area/lines don't move. It's the same spot. If it's the screen can it be replaced at a reasonable price.
    This is the problem, link had pictures of the problem - optical block and my unit was purchased in 2003.
  • 4,889 Answers
The problem is probably with the light engine itself as some experts have pointed out. It is extremely expensive (around 1000-1500$). The part number is A-1605-853-A. Not sure if its worth the repair. You can try looking for the part at www.partstore.com
Posted on Nov 24, 2008
  • 2,336 Answers
It looks like the optical block is causing specific issue. The part itself is very expensive and might not even be worth it to get fix unless you contact sony and ask them if they can extend the warranty for this issue. Sony is aware of this manufacturing failure.
Read more about your issue by clicking here.
  • Sony Master
  • 4,806 Answers
Get a sony sevice engineer out to sort the problem, if you go out and buy a new circuit board and then get it installed only to find out it may not work and there are other problems (which is the usual case) you are going to be pretty annoyed about the money you have spent, these boards are not cheap at all and could cost the same price of a certified sony engineer
regards
  • 10,594 Answers
In my opinion, your TV requires new Lamp and you can get it from Sony Accessories and price is approx $200 (once on page, write model number in search box)
Lamp part number is as follows...
A1606034B LAMP BLOCK XL-2100U
Good Luck.
    Genius:
  • 2,035 Answers
    Sergeant:
  • 276 Answers
U need to check the main board of your tv and resolder all the junctions .As u said u shifted the unit it must have caused some electrical component loosened up because of the jerks while transportation.
feel free for further help.
if any.
thanks.
  • smarttech Nov 24, 2008
    tv lamp part number ------A-1606-034-B
    Installation is Quick and Easy:
    In most cases, replacing your projection lamp is quick and easy. However, we recommend that you consult your owner's manual for more detailed instructions:
  • Unplug your TV from your power outlet
  • Allow the lamp to cool for at least one (1) hour before replacing it
  • Remove the Lamp unit cover (Usually located at the rear of the television)
  • Unscrew the lamp housing unit
  • Remove the old lamp housing unit and discard
  • Screw in the new lamp housing unit
  • Place the cover back onto your TV unit
    Caution: Do NOT touch the bulb directly with your fingers
    Sergeant:
  • 291 Answers
Try dry soldering all the points on the main board to solve this problem.it is due to the loose soldering joints.good luck.
I have a Sony vega KF-50we610 Flashing
Make sure your lamp door is completly latched. there are saftey switches in your set that will not let the TV operater if not properly closed.
Apr 17, 2012 | Televison & Video
Where can I buy a replacement bulb for my Sony KF 42WE610 in the Toronto, Ontario area?
Hi there
Here is address and phone number to call for Your replacment lamp
Bleeker Stereo & Tv
1400 Clyde Ave Nepean
Ottawa On
K2G 3J2
613 225 5191
Give them call ..Cheers
Aug 21, 2011 | Sony XL-2100U Projector Lamp for...
Have a kf-50we610 that I just replaced the bulb on but I still have nothing but vertical lines
The lcd panel may be faulty or one of the polarisers may have gone. May cost £300 to fix. May need to look at a new projector.
Hope I was of assistance
Aug 03, 2011 | Sony XL-2100U Projector Lamp for...
Sony Grand WEGA KF-50WE610 LED blinks 4 times
4 times blink shows Temp Error and requires temperature sensor replacement in Sony KF-50WE610 TV
May 21, 2009 | Sony Grand WEGA KF50WE610 50" Rear...
SONY KF-50we610
Go to Instuction Manual of Sony KP-50WE610 page-13, there you will see details where is compartment of lamp in tv and how to open it.
Need further info, let me know.
Sep 26, 2008 | Sony XL-2100U Projector Lamp for...
Vertical colored lines on Sony KF-50WE610
Hi Lucian
This is a common Mainboard failure problem on Projectors.
The unfortunate thing is that this can only be solved by having the part repaired or replaced.
Apr 20, 2008 | Sony XL-2100U Projector Lamp for...
PINK SPOTS, VERTICAL COLORED LINES ON INPUTS, TV SHUTTING OFF
I had the same exact problem I found an article on the internet
(http://splinke.googlepages.com/sonyrearprojectionlcdtv-opticalblock)-I took my tv to get diagnosed, thay said it required an optical block.I then phoned sony & then faxed the estimate & the bill of sale to them & 3 weeks later they phoned me with a offer-they offered me another tv ( 46 inch-retails for $2400) for $1150 plus an addition 2 years warranty on top of the 1 year & thats what I am watching now.
Apr 11, 2008 | Sony XL-2100U Projector Lamp for...
Purple scribbly lines it left hand corner of tv screen
if the lines on your screen looks anything like the image below, you do have a problem with the lcd, problem is you need to replace what is called the light engin. unfortunatly the price of this part is just about as much as a new replacement tv. Get a sceond opinion fron a sony service center near you, as i cannot see your picute. good luck
Dec 22, 2006 | Sony XL-2100U Projector Lamp for...
Sony KF-50WE610 no picture?
4 blinks = No Vert. Deflection (V STOP), Screen goes to a single horizontal line then the video signal muted. Check IC1509, Q1505.
Nov 28, 2006 | Sony XL-2100U Projector Lamp for...
Sony Grand WEGA KF50WE610 50" Rear Projection HDTV-Ready Television Logo
Top Sony Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
