Question about Brother BRTPT65 PT-65 Label Maker Printer
Too much blank label at the end of words
When I type names there is an excess of blank label. I don't want to waste the label material
I haven't solved the problem. I didn't know I had to pay someone to help me. What a crock of a service!!!
Posted on Nov 26, 2008
What in the world!! I have the Smart Label Printer 450, it is not advancing the label, and the power button is flashing. It will not print a label at all at this point, and when it will end up printing a...
Unfortunately, this is usually an indication that the label roll in the printer are too old. This action is by design, compatible labels should have a black rectangle on the reverse side and the Smart Label printer uses the black rectangle to orient the label. This means your Smart Label doesn't think its wasting labels, it's just trying to run through what it considers to be unsuitable labels as fast as it can. If you're only printing one label at a time you can recover some labels by correctly the label's line up after each label you print but there's nothing you can do so that your printer will properly advance its current labels.
Remove the current roll, open a new boxed label roll, remove a sealed roll, cut open the sealed plastic, remove fresh label roll and load it in your Label Printer. Power the label printer back on and press the label advance button, it should correctly line up.
May 08, 2014 | Seiko Smart Label 240 Thermal Printer
I have avery labels 06107 and am trying to print them in word but am not sure how to set up the margins
I suggest you go to the Avery WEB site and download the Word template for your Avery label. Use this template, enter your text and then print, don't forget to place the blank Avery in your printer.
You can download the templates from this WEB site.
http://www.averyproducts.com.au/avery/en_au/Templates-%26-Software/Templates/?Ns=Rank
Feb 24, 2012 | Computers & Internet
Mms/gprs settings.my network provider is smart
(How to get there? Open settings - Network - APN/Access point - New apn).
On internet settings try this first: Usually works but not always. Under are SMARTs own settings.
Connection name: Internet
Acces point name: Internet
NOTHING ELSE
Hope it helps.
I. GPRS/WAP Internet Settings
Connection name: SMARTGPRS
Data bearer: Packet data
Access point name: smart1
User name: leave this blank
Prompt password: No
Password: leave this blank
Authentication: Normal
Homepage: http://wap.smart.com.ph
Network type IPv4
Phone IP address: 10.102.61.46
Name servers: Automatic
Proxy server address: 10.102.61.46
Proxy port number: 8080 or 9201
(differs from one handset model to another)
Default access point: SMARTGPRS
Data bearer: Choose GPRS
Access point: internet
User name: (leave it blank)
Prompt p'word: No
Password: (leave it blank)
II. MMS Settings
Connection name : SMARTMMS
Data bearer:Packet data
Access point: mms
User name: leave it blank
Prompt password: No
Password: leave it blank
Homepage : http://10.102.61.238:8002
Network type IPv4
Access point: mms
Prompt p'word: No
Homepage: http://10.102.61.238:8002
Jun 08, 2011 | Sony Ericsson XPERIA X10 Cell Phone
Where do I SSID and find network key for printer hookup?
Network key by default is printed on label on bottom of router. If custom type 192.168.1.1 in any browser to access configuration utility to see what your network key is. By default on this linksys the pass word is blank and the user name is admin.
Jan 12, 2011 | Linksys Wireless-G WRT54G Router
How do I print just one mailing label without running through an entire sheet time I print using an Epson LQ-590 and printing from the mail merge option in MS Word (MS XP)? In other words, when I print...
I assume you are using a sheet of labels, such as the typical 3 x 10 sheet. Word sets up the mail-merge document for printing the whole sheet, so if you print just one or two labels, you will `waste' the rest.
One way of using that sheet over is to create a mail merge that contains blank `dummy' addresses. It is rather involved and at best time consuming, and considered not worthwhile to save a partial sheet.
I service printers, and personally do not recommend that any label sheet be re-used. The printer curls the paper, in some cases fuses it, and causes the corners of the labels to be exposed, and possibly get caught in the printer (I have removed a lot of labels from inside printers)
Oct 18, 2010 | Office Equipment & Supplies
Ink absorber is full
All inkjet printers have a small chamber with a sponge or other similar material for absorption in them. This is used to collect the excess ink that is wasted during head cleaning and other functions. All printers are set to stop working after a given number of cleaning cycles, etc. to prevent this waste ink container from overflowing and making a mess.
I'd suggest trying to find information on exactly how to cleanthis out before doing a reset, as you may end up with a large messdown the road if you don't.
There are instructions on the web on how to reset this, generally through a combination of key presses on your printer. Unfortunately, I can't point you to a specific method, as all printer models are different, and you didn't state which model of printer you have.
I'd suggest doing a Google search for your model printer and the word(s) "reset" or "reset waste". I've included a few links below that have procedures for different models, perhaps your model is listed on one of the sites; if not, you should be able to come up with something through a Google search as stated above.
Link1
Link2
Hope this helps!
Dec 12, 2009 | Canon Office Equipment & Supplies
Labels coming out blank
1. Replace the batteries (use only alcalines)
2. See if the tape is correctly inserted.
3. Clean the printer head
4. Replace the tape with a new one.
5. Check the contrast settings
Jul 20, 2009 | Dymo LetraTAG Thermal Label Printer
How can i open my GPRS?
hello..
please try to manually configure your browser settings with this one..
Prompt password: No
Network type IPv4
Prompt p’word: No
II. MMS Settings
Access point: mms
Prompt password: No
Network type IPv4
Access point: mms
Prompt p’word: No
hope it helps..
Jan 08, 2009 | Motorola Mobility SLVR L7 Cellular Phone
Printer labels do not line up with document as typed in Word using the Avery set label size. I type labels for Christmas cards. Previous years have had no trouble at all on other printers but now top of...
The only way I could get round it was to type one page of the labels, then print on plain paper. Check with label size then go back to screen and individually change the labels that were misaligned. Then when I printed on to a label page it was correct. Time consuming but at least I didn't waste any labels that way, only paper.
Nov 21, 2008 | Office Equipment & Supplies
Brother BRTPT65 PT-65 Label Maker Printer Logo
99 people viewed this question
James Cagle
James Cagle
Samyfam
Samyfam
Victorman
Victorman
