Question about Epson Stylus RX500 All-In-One InkJet Printer
Too frequenet auto ink recharging
Epson DX 5050 all in one printer. When I switched on the printer it started run its recharging programme. after a couple of copies it required the yellow ink cartridge to be changed. It then ran a recharge cycle as usual but then when I asked it to print another document it ran the recharge cycle again. Now it needs to black cartridge to be changed!
Any help would be appreciated, it is costing so much in ink and I have only used genuine Epson cartridges. The printer is less than 18 months old and is used for home use only. Print quality remains excellent. I have a PC running Windows XP.
  • 2 more comments
  • bjpeedle Nov 27, 2008
    I cannot finf the ink recalibration facility. It isn't included on the driver disc that I can find. Please note that I am UK based.
    The cartridges at present in the printer are between 1 and 30 days old. It is the printer not the cartridfes that is 18 months old
    There may have been a loose fitting cartridge. The printer appears to be functioning correctly now, thank you. One additional problem: To save ink I sometimes use the 'draft' option for printing, however, it is very faint. Is there a way of increasing the density slightly please?
  • bjpeedle Nov 28, 2008
    Many thanks for your help
    Brian Peedle
    Brigadier General:
  • 6,966 Answers
Hi and welcome to FixYa,
To my knowledge, there would be only three (3) instances when the ink charging system would be activated, they would be:
  • when a cartridge is replaced; and/or
  • when the cleaning process is manually triggered; and/or
  • when the printer is powered on.
Possibilities:
  • Since you did not post that you cleaned as well, the the printer erroneously sensed that another cartridge was replaced (after the yellow) and self-initiated the recharging. Assuming this to be a possibility, then perhaps you may want to check that the ink cartridges are fully and snugly fitted to their cradle/holder. There might be a loose ink cartridge holder/cradle and the the ink cartridge is being jarred out of position/contact hence the false triggering;
  • another possibility would be a loose AC plug or connection to the mains. Unnoticed the printer may be cycling ON/OFF and then again requiring a re-charging.
  • other than the above, there are no other ways to defeat this as it is a feature and built-in to the firmware of the printer.
Just a start, do postback how things turned up or should you need additional information. Good luck and Thank you for using FixYa.
Posted on Nov 26, 2008
  • Louie  Role
    Louie Role Nov 27, 2008
    Glad to be of assistance and appreciate the rating.
    As the name implies, "Draft" copy level/density are pre-determined by the manufacturer, Epson in this case. To my understanding, the level/density is embedded in the firmware of the printer. There are no user settings that can change this.
    An alternative, when intending to print Draft, set font color to light gray. Assuming you are using MS Word, there would be several level of gray and you can settle on one to your preference.
    Cheers.
  • Louie  Role
    To qualify my previous post "An alternative, when intending to print Draft print normally but set font color to light
  • 849 Answers
Cartridges gone dried if the consumption is low. although 18 months is a huge time. if u could not afford new cartridges re-fill them.
    Master:
  • 763 Answers
Sir try to calibrate the ink by using calibration utility which is included on the CD driver from printer's box. This might help you and your printer.
thank you for using fixya
CHARCOIS
0x95 error
Epson Printer Error 0x95 occurs when the printer head is saturated,i.e; cleaned. Error may be due to installation or uninstallation of windows, update of application of Windows, etc. Follow these steps to resolve the Error.
Steps to Fix Error 0x97 in Epson Printer:
Solution 1: - Check Epson Printer Ink Head
Check Epson Printer Ink head. Generally, Printer ink is dirty meanwhile it is inked up properly because the ink pad is full. Often due to unbalance ink it generates the problem or displays a message of Error Code 0x95. Unplug the printer completely and leave it for a while. Then users must need to remove and replace the sponge and clean the eye.
If this step is not working to fix Error Code 0x95, then go to next step.
Solution 2: - Manually Perform Steps with Epson Printer
  • Try to switch on your Epson printer.
  • Then "press+hold" together to stop ink power buttons.
  • Wait for sometimes while the printer switches self OFF.
  • Next switch back ON and your error should have gone.
Solution 3: - Run the System Under Safe Mode
You should try to run the computer under safe mode, and then you may receive a message from the system about whether your error existence effectively solved.
Solution 4: - Uninstall Current Installed Software From System
  • On your Windows "Start" button, go to "Programs and Features".
  • In the "Control Panel", tap "Programs", and then tap "Programs and Features".
  • Choose that software program that you have just installed, and then tap on "Uninstall" button.
You can visit Epson Printer Support Number if you are still unable to resolve the Error.
Apr 01, 2014 | Epson B510DN InkJet Printer
Epson dx7400 windows xp service pack 3 top line on test shows only half of the top line printing changed all the inks---took off drivers and reinstalled --- cleaned printers via maintenance epson...
Follow these steps to print a nozzle check:
  1. Turn off the Epson Stylus dX.
  2. Disconnect any connected USB cables.
  3. Load letter-size paper in the sheet feeder
Hold down the Stop button as you press the On button to turn the Epson Stylus CX back on. Hold down both buttons until the On light begins to flash, then release the buttons.Tell me the result-->Nozzle check pattern with no gaps or with gaps?
You can use this service/repair manual for Epson dx7400 ->start download.
May 10, 2011 | Computers & Internet
How do I change the Ink cartridge in a Epsom DX 7450
Activate epson status monitor, if ink reach ink out, the message will appear. Then follow "How to..." Manually, turn on printer, and unplug power while carriage moving. Then move carriage by hand to replacement position. Replace ink tank, turn on printer.
Sep 20, 2009 | Epson Office Equipment & Supplies
Epson Stylus DX 8400
If ink cartridge Unrecognizable, there are two posibilities : Chip Error at ink tank, or printer error. For chip error, try to plug the ink tank to another printer (same type). If the ink tank recognized by other printer, so the problem is printer.
So ;
1. Check chip conector at head carriage.
2. Check the wiring of the head, and chip.
If two point above is ok, the last action is check the power supply and board. It may be epprom is damage.
May 28, 2009 | Epson Stylus DX8400 All-In-One InkJet...
It sounds like you have incompatible cartridges for your printer... Some folks have reported that disabling the Status monitor and turning the printer off/on, plus rebooting the computer can solve this but that's just something I've heard.
You may want to double check with the ink supplier that they have provided the correct cartridges for your DX rather than a CX model.
May 17, 2009 | Epson Stylus DX8400 All-In-One InkJet...
Epson printer
HOw do I clear a paper jam on my epsom dx 4450 printer
Apr 02, 2009 | Epson Office Equipment & Supplies
Installed compatable cartridge for epson dx 7450 printer rejecting non epsom cartridges
I have an Epson dx 7450 scanner printer that will not accept non epson so called compatibles .Anyone found a solution ? I've tried a number of manufactuers and they all don't work . I really don't want to fork out for epson inks ?
Sep 30, 2008 | Office Equipment & Supplies
Put compatable ink cartridges in to dx 5050 epson but will not accept message reads not compatable and printer wont work yet manufacturers say they will HELP is needed to get printer running
if the cartridges are saying not-compatable, this means the printer has detected non-epson original cartridges.
If you go into your printer preferences, or program. And look if there is an icon or application, that says ** Change A Print Cartridge** if there is, follow the on screen instructions.
If you have purchased the cartridges from a shop/store. they may have not re-charged the chips. ( which informs the printer that they are Full )
Also make sure, the cartridges are firmly pushed into thier slots. a positive click can be felt, don,t be bashful about putting a little pressure on them.
Mike @ Compurepair.
Feb 25, 2008 | Computers & Internet
Epson Stylus RX500 All-In-One InkJet Printer Logo
21 people viewed this question
Top Epson Office Equipment & Supplies Experts
Alun Cox
Are you an Epson Office Equipment and Supply Expert? Answer questions, earn points and help others
