Question about Epson Office Equipment & Supplies
Epson dx3800 stopped printing. I get a communication error message. All cables etc checked, scanner works and printer will print scanned article when not connected to computer. Seems files cannot be sent from computer to printer? I removed all epson programmes and reinstalled them, printed just fine for 3 pages and then stopped again, with the same communication error.
    Habit-Forming:
    New Friend:
  • 59 Answers
To get over this problem, First uninstall your printer and reboot your computer and again install the driver of printer and if the problem persist then consult Epson Printer Support team and get connected with the expert technicians of the customer service by just dialing 1-800-243-0019(toll free) and get your issue resolved in a short span of time.
Posted on Sep 04, 2017
SOURCE: Copies and prints but won't scan
if your scanner is on a wireless network, you will need to make sure the scanner address in epson scan settings matches the address your router has assinged to it. The DHCP address. Log on to your router by typing 192.168.2.1 or some variation thereof into your window internet explorer address bar. or find out how to log on to your router via the manufacturer of the router. When you do that find the DHCP client list and see what address your router has assigned to your scanner. Once you have this address open epson scan settings and delete the current information there, then add a new scanner by manually entering the address you got from the router.
I have to do this all the time!!!
email me at raygant@msn.com if you want more help
Posted on Mar 10, 2008
gwbm
  • 353 Answers
SOURCE: EPSON BX300F prints a page and then shows Printer Error.
Try uninstalling your printer, rebooting the computer, then re-installing your printer. If this does not work, it will require the printer top cover to be removed for further investigation. Either take the printer to a technician to investigate, or if you want to have a go yourself, post a new comment to this effect and I will provide information on how to proceed.
Posted on Mar 22, 2009
  • 526 Answers
SOURCE: epson cs5500 scanner software wont work
try downloading the latest drivers from epsons website. if coping is working and printing is working, it sounds like a software problem. Its possible there is a bug in the scanner part of the drivers.
Posted on May 07, 2009
seanpwright
  • 2030 Answers
SOURCE: Epson Stylus TX100 printer Woeks but scanner not
It is a scanner as well, but you have to access the scanner through the software that came with it
Posted on Aug 27, 2009
ohms
  • 1879 Answers
SOURCE: My Epson CX3900 prints fine. It's when I try to
if the unit is directly connected via USB, another program or prev installed scanner software is using "the path" to communicate with the scanner. Can only use one scanner at a time with windows.
Posted on Nov 25, 2009
3520 instructions
Go to epson's web site and check for driver updates.
Mar 02, 2018 | Office Equipment & Supplies
Epson scanner cannot communicate
My solution was that Epson Scan was set to connect via network instead of local. (All was working fine, then it quit-something changed this setting) Try this, go to start, choose all programs, choose Epson folder, choose Epson Scan, choose Epson Scan Setting. In the pop up box set the connection to local or network, whichever is appropriate. Close the window and open photoshop and all works fine. It could be that your problem is the opposite of mine- I try switching this to the other setting even if the change is wrong, then switch it back to see if that works too.
Good Luck.
Jan 05, 2013 | Epson WorkForce WF-7520 Wide Format...
Printer error
Here a few common problems that your Epson printer and ink cartridge can suffer from.
Improper Installation of Cartridges
A common Epson printer and ink cartridge problem! If you have changed the ink cartridges then you might just receive this error message. The message might state that the cartridge is not installed correctly in the printers. In such cases, re-install the cartridge in the correct manner. If the problem persists then it is advisable that you replace the cartridge as it might be defective. If you still get the same error message on installation of the replacement cartridge then its time that you clean the print head. You could do this yourself or could take it to a repair facility.
Printing Failure
Failure to print documents is yet another common problem with respect to Epson printers. The print heads of Epson printers are sensitive and this sensitiveness is the culprit behind such problems. If the print head is clogged or blocked you will have to unclog or unblock them. This can be done by using a special fluid that is available for just this purpose only. This fluid flushes the print head, and your printer is once again ready to print.
Communication Error
'Communication Problems' are yet another one of the common problems surrounding Epson printers. Once you give the print command you might be shown the message that there is a communication error between the printer and the computer. This means that there is the occurrence of a minor problem. One of the reasons for this problem could be the inappropriate selection of printers from the print options menu. Cable connections should also be checked. Another solution could be the re-installation of the driver of the printer.
Print Jobs that are Slow or Incomplete
These are problems that occur during an ongoing process. The printing might stop midway and then start again after some time. At times, the printing process will repeat itself several times and then finish printing the page. There are times when the page will finish printing, but you will find that it is an incomplete print. More often than not, this is not a printer related problem.
What might have happened is that the driver might have corrupted or a virus might have infected the computer; or a spyware might be affecting the working of the printing process. If such a problem occurs, the best solution would be to scan the computer for viruses and spyware. As can be seen these common Epson printers and Epson ink cartridge problems can be sorted out quite easily.
hope it helps..
Thanks for using fixya...
Dec 04, 2010 | Epson Office Equipment & Supplies
My Epson CX3900 prints fine. It's when I try to open Epson scan that I get an error message "Cannot properly communicate with scanner"
Nov 25, 2009 | Epson STYLUS CX3900 All-In-One InkJet...
HI, MY DX3800 SOUNDS AS THOUGH ITS PRINTING
it is problem printer cartridge head change it then solve your problem
Nov 21, 2009 | Epson Stylus Multifunction Inkjet Printer/...
Epson cs5500 scanner software wont work
May 07, 2009 | Office Equipment & Supplies
Scanner error message. Will print from PC fine
The Scanner has died. If you Know someone else who has the same model but is not printing but scanning fine you can swop over the scanners. This solution don't work 100% of the time but i have fixed a few this way.
Apr 01, 2009 | Epson Stylus CX3200 All-In-One InkJet...
Scanning error - cannot scan error code 2,155,0 ???
i found this while i had the same error msg... apparently its actully the USB cable where its does not suffice
here is the link : http://www.fixyourownprinter.com/forums/printer/49111
Thanks
Sanjieev
Jan 13, 2009 | Office Equipment & Supplies
Scaner Epson CX-5400 error message
What is the error message? SCANNER ERROR?
If that is what you getting, turn printer off then open scanner cover- on the left hand side there is a toggle log for scanner, position it to unlock then turn printer on then try scanning/copying again.
if your having a different error message pls indicate the exact error that you are getting.
Feb 22, 2008 | Epson Stylus CX5400 All-In-One InkJet...
121 people viewed this question
Top Epson Office Equipment & Supplies Experts
Alun Cox
Are you an Epson Office Equipment and Supply Expert? Answer questions, earn points and help others
