Question about EliteGroup P6VXAT Motherboard
Hard drive When my computer starts and goes for about 1 minute, it then restarts. Would that have to do with hard drive. or a motherboard. I mean the harddrive works until it come to windows Xp screen and then reboots to the first again.
  • EliteGroup Master
  • 4,806 Answers
Boot into safe mode and perform a system restore
regards
Posted on Nov 24, 2008
IROG-1 at start up keeps repeating how to fix
Not sure what you mean, but I assume that you mean that your computer starts to boot but never completes the boot process into Windows, it just freezes. Am I correct?
Jul 03, 2014 | Asu ROG Rampage IV Extreme Desktop...
I have a asus motherboard it restarts on starting windows screen I've tried to boot in safe mode that doesn't work
That means there is a problem in the booting environment of the system. This usually results from a virus attack that changes the booting environment. The best way to go around this problem is to slave the hard drive to another desktop computer, access it and make a data backup. By slaving the hard drive i mean, connecting it to a working computer but do not let that computer to boot from your hard drive because it can not. Boot form the working computer so that you can be able to see your hard drive in the 'my Computer" menu as drive E of D or F depending on how many partitions are available.
After making a backup, take it back to youe ASUS motherboard and perform a clean installation of an operating system. This should fix the restarting problem.
Mar 25, 2012 | ASUS Computers & Internet
In the boot device menu, drive 1: no ide device what does this mean?
test for secure dust free connections or replace the 40 pin ide lead from mother board to hard drive
include electrical extensions
operating system cant find ide hard drive
hope it helps
Nov 12, 2011 | Dell Dimension 3000 PC Desktop
Q - The computer start after 3 or 4 attempt when I press the power button. When the computer is on & I restart my computer from Start - Turn off computer - Restart. - my computer shut down instead of...
Test your PSU or replace it if your power supply units fan is not working your PSU is faulty
One bad lead can cause a computer to continue on a cycle or to shutdown or fail to detect/ boot up a computer hard drive
Test all leads that attach to your hard drive including electrical extensions,IDE,SATA
the leads from your ((motherboard to your hard drive)) make sure they have a secure connection and are not faulty or just replace them there probably old and faulty
make sure all leads that are attached to your drives dvd\cd 3 1/2 inch floppy have secure connections and are not faulty or just replace them they are probably old and faulty ?
hope this helps
Jan 14, 2011 | ASUS M2NPV-VM Motherboard
My computer keeps restarting after I tried to install windows. Now it goes through up to the point of starting windows then it restart over and over.\r\nafter trouble shooting I get this...
One bad lead will cause your computer to continue in a cycle
replace all the leads that attach to your hard drive including electrical extensions + IDE,SATA and the ones that attach from your motherboard to your hard drive
hope this helps
Oct 19, 2010 | Intel Motherboard
MY MAINBOARD RESET INMEDIATTELY
if you mean your computer restarts continuosly One bad/faulty lead can cause a computer with lots of problems
replace all the leads that attach to your hard drive including electrical extensions + IDE,SATA and the ones that attach from your motherboard to hard drive
hope this helps
Oct 11, 2010 | Computers & Internet
Installed a new hard drive. Now the system tells me it can't find the operating system. I checked the connections and they seem to be connected ok. Any ideas what the problem?
if it is ide haed drive you have to make sure that the red wire on cabel is on pin 1 as well as board ok check the power connections as well
Apr 16, 2010 | ASUS A7N8X Motherboard
1 TB is beeping
After doing some research it seems the beeping means that there is a disk failure.
Prop off the front of the unit, remove the drive and replace it. The unit will automatically rebuild the drive, which takes about 8 hours
Jul 15, 2009 | Buffalo Technology 1TB DriveStation...
Lost hard drive
Hi , try restart the computer , if still does not have detection hardrive ,
restart again and it will open starting window setup click del to view setup, set the hardrive to enable.save setting
Feb 06, 2008 | Computers & Internet
Notebook won't start
press the key F1 or F2 or F10 or DELETE when you try to restart your computer before 5 seconds that will open the BIOS page so go to boot order and change it instead of start with cd flopy hard drive put the hard drive first save it and restart the computer it have to work good un less there is a problem with your hard drive or windows software if that is the case restart the computer and press F8 before 5 seconds and you'll see black page with the next options last know good config and save mode click on last an then restart the computer if does not work try save mode of you can acces tue hard drive that means bad windows software if not bad hard drive
Jan 02, 2008 | HP Pavilion zd8000 Notebook
EliteGroup P6VXAT Motherboard Logo
55 people viewed this question
Top EliteGroup Computers & Internet Experts
David
David
Alun Cox
Iqbal Husain
Iqbal Husain
Are you an EliteGroup Computer and Internet Expert? Answer questions, earn points and help others
