Question about E-Machines eMachines Desktop PC
EMachine tower doesn't boot up. Only the fan is running
This is about my home computer. I have unplugged everything and re-plugged. Nothing is booting up.
  • 575 Answers
Check your power supply. Open it up and you will see that a capacitor has blown in the power supply box. Once you know for sure this is the problem, you can resolder a new one in or replace the whole power supply or bring it to a rapair shop. Good luck!
Posted on Nov 03, 2012
Try replacing your ram.if your ram is bad you wont get no picture on your monitor but your puter will start.2 if you have a video card turn off you puter for a few minutes and plug your monitor to your original display.
Posted on Nov 25, 2008
My emachine desktop tower will not power on
the sound you are hearing or heard could have been power surging through a powersupply unit that just blew.. hopfully it did not effect any of the other hardware..to trouble shoot this you can do one of two things..1 disconnect the 20/24 pin powerconnector from the motherboard 2 disconnect the cpu power connector 3 disconnect the 6pin power connector from the graphics card if there is one some machines have onboard video chipsets if thats the case then no worries 4 disconnect the Harddrive power 5 jump the power supply to see if you get any power from it any questions on that go to youtube and type in how to jump a power supply... or option 2 is buy a new power supply make sure its 80plus certified and replace it...i know its a lot of work but i hope this has helped you
Aug 26, 2012 | E-Machines eMachines Desktop PC
Need wiring diagram for emachines T3092
I sorry I am a computer tech there is no such thing as a wiring diagram you might need to take it somewhere or have a friend who is into computers fix it I wish it worked that way :)
Feb 29, 2012 | Computers & Internet
Fan works randomly....when it's not working plug
Hi, If the computer is hot near the electrical plug in the back of the computer then the power supply needs to be replaced. This will also cause overheating problems if the fan does not exhaust enough air. You should not run the computer in this condition because the power supply can short out and take other components with it. Also there is a risk that it will burn up. Power supplies are very inexpensive and can be changed by anyone with basic computer repair knowledge. Hank
Jul 26, 2010 | eMachines T5212 PC Desktop
Emachine won't start .power is on, fan is on, doesn't boot up
I love this one. I've actually done this many times before and have been successful.
1. Turn the computer off and unplug the power cord from the back of the tower.
2. Press and hold the power button for about 3 seconds while the computer2_bing.gif is unplugged (this drains the remaining power from the capacitors on the motherboard2_bing.gif).
3. Plug the computer back in and turn it on.
If that does not work, follow steps 1 and 2 again, but this time:
3. Open the computer while it is unplugged and unplug the power supply from the motherboard then hold down the power button again for 3 seconds. (You may also want to take the RAM out and put in back in)
4. Plug everything back in and turn the computer on.
Mar 14, 2010 | Computers & Internet
I cannot boot up the computer. When I push the front power button, nothing happens. When I flip the switch on the back, or unplug it for 30 secs and plug it back in, the fan starts up and a yellow light...
I had this happen to my emachines T1842 about a year ago. I replaced the power supply and it worked fine. It was about 25 bucks but fixed my problem. Make sure the red switch on the back hasnt been messed with. it should be on 115. If you have moved it, it may have blown a fuse inside the power supply.
Feb 04, 2010 | E-Machines eMachines Desktop PC
My emachine T1742 desktop will not turn on. When plugged in the power supply's fan turns on, cpu fan doesnt start, both hdd/power led's flicker and pressing power button doesnt power on/off system.
Disconnect all the devices from the computer(tower) including keyboard, mouse, monitor(everything)..even the power cable
Now keep on holding down the power button on the computer tower for 15-30 seconds..
Now release the power button, plug in the power cable, monitor, keyboard, mouse and turn on the computer...
If it works, great!!!
Otherwise, take it for repair..
Dec 03, 2009 | E-Machines eMachines Desktop PC
I have a T3626 emachine that I replaced the drive.
check all your ground screws on the motherboard. If that doesn't work try booting it up with out the hard drive. if that doesn't work, pop out the BIOS battery and unplug your computer, let it sit for about a min. and put the battery back in and restart.
Sep 18, 2009 | E-Machines Emachine T5026 power supply **...
Emachine tower unresponsive
Unplug the Monitor, and attempt to reconnect a seperate monitor to test. If that monitor works properly, then the problem is your regular monitor. If you do not have another monitor, Try unplugging the power from the wall jack to the tower. Then plug into another port, the reason the computer doesn't turn on is because the power outlet may be running but at a lower voltage then what is required for the computer to run at its full potential. If theese both fail, Try opening your computer and check if anything is blown out.
Feb 07, 2009 | E-Machines eMachines Desktop PC
NO POWER AT ALL!
Does the power supply have its own power switch?
It is located next to where the power wire plugs into the back of the PC.
Jan 10, 2008 | E-Machines eMachines Desktop PC
E-Machines eMachines Desktop PC Logo
182 people viewed this question
Top E-Machines Computers & Internet Experts
Alun Cox
Are you an E-Machines Computer and Internet Expert? Answer questions, earn points and help others
