Question about Samsung DVD-V5650
Samsung 3450 surround sound, No sound
Just got a used unit. It all looks good but there is no sound. I know I have power to the subwoofer because the light is on. There is a cable (like the one you would use to connect a computor monitor to your laptop) that connects the unit to the subwoofer. And all the speakers are run from the subwoofer. I am not for sure that I even have all the settings correct.
Help please.
fwadley
  • 482 Answers
SOURCE: Samsung dvd player p142
use your remote to change it.
Posted on Dec 17, 2007
SOURCE: I just purchased and would
I found a manual (PDF) for the TV/Monitor online and downloaded it for "free". That told me what I needed to know. Yes, it will work. Page One
Posted on Aug 08, 2008
SOURCE: Samsung SWA-4000 Wireless connection problem - Not connecting with main unit
I have had the same problem with the wireless unit and thought the same, it didn't work. The way to fix this is simple. You need to do the 0, 1, 3, 5 on the remote and turn on the home theatre system on the main switch on the front panel (as I was doing this on the remote, and it was failing). The blue light should then stay illuminated. If not just switch the main on/off button again, and it shoud work.
Posted on Nov 09, 2008
SOURCE: Surround Sound Not Playing For TV Programs
In the display window, do you see the letters ASC? If so,press the ASC button on the remote to turn it off. You should now have the TV sound thru the rear speakers. Enjoy...
Posted on Jan 28, 2009
SOURCE: no sound from surround sound whilst tv on
YOU HAVE TO TURN VOLUME OFF ONTV AND PUT YOUR SURROUND SOUND ON AUX THATS HOW MINE WORKS
Posted on Mar 09, 2009
I have a Phillips hits 3450 surround sound system. I have no sound at all from day speakers
Usually the case that the subwoofer in the two capacitors are burning 16v 480nF
please check avsystemparts.com
Sep 24, 2013 | Philips HTS3450 System
Tip
How to wire multiple speakers to one channel.
This mainly concerns surround sound systems, with a subwoofer. It is possible to wire multiple speakers to one channel, most useful for subwoofers. Even though bass is nondirectional, the user can still sort of place it. I create "surround bass" with one subwoofer channel. Enough intro.
I purchased two old Sansui LM-110 multi-driver(woofer and tweeter with a passive crossover) and placed them around the back wall till i liked the positioning. I then replaced my ht-z320 subwoofer with a Samsung PS-WX50(from the HT-X50 system). The X50 went in front, under the TV. The wiring to he speakers must be exactly as follows, lest the amplifier in the main unit repeatedly shut the unit down to protect(PROT then shutdown) from damage.
This is easier to do if you know how to solder(it also grants better sound), but can be achieved with a twist on wire connector and wire strippers.
The purple plug positive(denoted as a + inside a circle) keeps its wire, going to front woofer(Samsung PS-WX50) RED. Cut some speaker wire to the back woofer last on the route the wire will take to the rear woofers. Split it, then cut one of the two wires on the speaker wire at the other woofer. strip both ends. Do this to two equal lengths of speaker wire. Split and strip the joined ends of the first wire and connec both ends to the black port on the front woofer, the othe ends to the back woofer RED ports. Take the other wire, join the unsplit ends to the negative wire(helps to cut that short) in the purple plug, using your wire nut. Strip and connect the other ends to the black ports on the back woofers. This basically is a series setup. The back woofers are one one parallel circuit, but are powered as one speaker. therefore, the front speaker and both back speakers(acting as one) are a series loop. To simplify, unit + to front red. Front black to both back red. Both back black to unit -.
on Jun 13, 2010 | Audio Players & Recorders
I have the following setup: AV Receiver: Pioneer
Very common problem with today's receivers. Receivers made today don't have a true preamp section in the amplifier and do not amplify the sound to the extent of an older receiver. I have large 15" front speakers on my system, and have stuck with my 15 year old receiver just because I know that a new receiver will not have the power to drive them well. Many of the newer receivers need to be turned up to 50-60% before you can even hear anything from the speakers.
Aug 08, 2013 | Pioneer Audio Players & Recorders
Repair Philips HTS 3450
What exactly is the issue? no deep bass? pffft instead of woof?! low volume?
Info needed,
Sep 12, 2017 | Philips HTS3450 System
I have a new Samsung Surround System but the only speakers that seem to be working are the front two. I have done the music speaker test and they all work ok there. Could u tell me what settings i need...
Make sure you are getting a stereo signal off FM or use a cd in DVD player. Then start selecting different sound processing modes like dolby digital 5.1 or surround sound, or theatre sound, etc. Give that a try and it should get u up and running... Sometimes the only way to select the modes is thur the remote. Keep that in mind and you should be good to go...Let me know how this turns out... Good luck...and happy listening... HDTV GURU JAY
Mar 17, 2011 | Samsung Audio Players & Recorders
My subs sound choppy
Sounds like your sub is "clipping". Clipping is when your speaker is trying to pull more power than the power supply. (head unit, amp) If it sounds good at a low volume and choppy at high volume, supply it with more power. Bigger amp. If it sounds choppy all the time, push gently on the middle of the speaker. It should go back and forth smoothly. If it feels rough, you have blown the coil. Replacing the speaker is the fix for that.
Apr 14, 2010 | Sony Xplode P5 Turbo Subwoofers Car...
Garbled / feedback sounds from powered subwoofer
The surround processing portion of the unit has a problem. In either stereo or direct mode, the digital procesing is bypassed. This could be just the surround processing IC, but that IC may not be available as a separate part. I would suggest that you bring this unit to an authorized Onkyo service center for an estimate.
Dan
Mar 18, 2009 | Onkyo TX-DS595 Receiver
How do i connect my subwoofer to my tv
Have you tried connecting an AV cable from yoursuboofer to your TV?
If so, what type of connection cable does your Woofer have?
Is your subwoofer apart of a surround sound system or is a separate unit?
Feb 10, 2009 | Harman Kardon AVR 300 Receiver
No signal on subwoofer out in Onkyo TX-SR703(E) - similar to TX-SR803
Hey Tad, I have the same problem and perhaps a solution. I just moved to the other SW "pre-out" and it seems to be working..the green light is on . Whatever works i guess.
Jan 24, 2008 | Onkyo TX-SR703 Receiver
Lost instructions
The 'Subwoofer' output on your receiver is used to connect to a powered subwoofer with a built in amplifier. Your KLH speakers use what is called a 'passive' subwoofer, it gets its power from the receiver and then passes the higher frequencies to the left and right front speakers after taking out the low frequencies for the subwoofer. A speaker system with a passive subwoofer is good for casual listening, but a powered subwoofer is required for really hearing low frequencies and rumble in movies. The KLH speakers you have were highly rated in their time for their price. The four satellite speakers and center channel speaker have very good sound compared to the little 'midget' surround sound speakers most people buy today.
Here's how you hook them up:
- The left and right front channels from your receiver terminals should go to the terminals on the subwoofer marked 'From Amplifier'
- Your left and right front speakers are then connected to the subwoofer terminals marked 'To Speakers', they do not connect directly to your receiver.
- Your center speaker is connected to your receiver terminals marked 'Center'
- Your rear speakers are connected to your receiver terminals marked 'Surround'
That should get you up and running. If the bass isn't good enough with the passive subwoofer, you can get a decent powered subwoofer like the Velodyne VX-10 for about $150 and 'kick it up a notch'. Good luck and enjoy....
Jan 07, 2008 | KLH HT-9900 System
Samsung DVD-V5650 Logo
297 people viewed this question
Jerry Greenberg
Jerry Greenberg
