Question about Kenmore 24032\24036 Top Load Washer
1994 Kenmore 90 series washer smells musty
I have been using eco-friendly detergent and running my washer cycles with only cold water for a year now. My washer is getting mustier and now the clothes come out clean but musty smelling. What should I do to fix this problem?
  • glueck Nov 29, 2008
    I have now run 3 full wash hot water loads with and without laundry with varried amounts of bleach (1/2 to 1 cup) with little or no improvement.
    I have never used much detergent (usually only half of the recommended amount), so I don't think the problem is build-up of suds, as mentioned in other solutions.
    Calling a repairman is not an option for me. I would rather spend the money on a new energy-efficient front loading machine.
  • 5,911 Answers
"Thanks for Trying"? We strive to improve our solutions and really appreciate feedback in order to provide you with better advice. Could you please provide some reasons as to why, instead of leaving adverse ratings with no comments? Have you attempted any of the advice given? I have experienced this problem before with washers and have never had a problem once I started using either a hot water or bleach regiment regularly. I also mentioned it make take a couple of times before you notice a difference. This is a common problem with consumers that choose only to run cold water settings.
Posted on Nov 28, 2008
  • 5,911 Answers
If you do not use a hot water cycle every so often it can contribute to the build up of mold or mildew inside the washer drain lines, pump and tub.. This is a common problem for those that only use cold water cycles. The detergent alone sometimes is not enough to kill bacteria. You also need the heat from hot water. I would recommend that you run a cleaning cycle on the hottest setting you have about once per week as a preventive measure. Add some bleach to the water to kill any existing bacteria. NOTE: This may take a couple of wash loads before you notice a difference. If you wish to conserve by not wasting water and energy by running an empty wash tub every week, switch to washing your whites in hot water with a little bleach to keep them brighter. This will kill bacteria in the washer in the process. I hope this helps you.
Posted on Nov 24, 2008
Stagnent water smell while filling
I found that running about a quart of white vinegar through a cycle with hot water and no clothes or detergent takes care of the musty smell. Vinegar removes detergent build-up.
Nov 12, 2011 | Whirlpool Duet GHW9150P Front Load Washer
Kenmore 90 Plus Series washer washer takes forever
is the cold water all the way on?
if so, the first thing to do would be to check the screens in the cold water fill hose and the screen in the cold side of the water valve on the back of the machine. if that is not the problem then replace the water valve.
(turn the water off before taking the hose loose)
Jun 16, 2010 | Kenmore 3.2 cu. ft. Plus Top Load Washer
Bath towels smell sour
I started adding 1 cap of bleach with 1 cup of water to all my loads in the bleach dispenser and this stopped the smell problem with my sweaty clothes.Sour towels i fixed with using Win high performance sports detergent plus my usual dose of he detergent along with a 2nd rinse.Keep the lid open when not in use always.
Dec 27, 2009 | Kenmore Elite Oasis 27052 Top Load Washer
Do a boil wash without clothes & detergents, with a cup of bicarbonate of soda in the soap drawer.
Mar 30, 2009 | Kenmore Washing Machines
Washer smells musty
there could be buildup in the outer tub causing some water to stay trapped and causing the smell, try running some loads uning Ahfresh or you can try pouring lots of bleach in there and letting it sit a while, then run it throu a cycle.
Feb 12, 2009 | Kenmore 23822 Top Load Washer
Musty smell
This problem is caused because the water does not get totally pumped out of the outer tub and sits in the bottom of the tub and in the front seals. Eventually a mildew type scum develops and causes the washer to stink and also impart the odor to clothes. Even though front loaders do use less water and energy, all of them have essentially the same design and therefore all will eventually develop this problem.
Run a load with just bleach (about 1 cup) and white vinegar (about 1 1/2 cups) poured directly into the washer with hot water and it seemed to help, but this does need to be repeated about once a month or so...
but with your wife's Asthma tho you could try
Typically the cause is the machine itself, but occasionally the water being used in the washer can be the source of the problem. If the smell resembles rotten eggs, you may need a water filtration system installed. After you eliminate any other possibilities, you can begin the treatment process. Create a mixture of baking soda and vinegar. Add 1/2 cup of baking soda to 2 cups of white distilled vinegar. 3Begin a wash cycle using the machine’s hottest setting. As the water rises, add the baking soda and vinegar mixture. Let the washing machine complete a full cycle. If you notice any residue that has been loosened, use a cloth to wipe the surface clean. Run a cold water cycle to complete the process. You should immediately notice that the smell has been neutralized.
Feb 09, 2009 | Whirlpool Calypso GVW9959K Top Load Washer
Clothes come out of washer smelling musty
It sound like lint bult up under agitator orIn Between inner and outer tub it would have to be manualy cleaned thanks and good luck:)
Nov 16, 2008 | Maytag MAV3855A Top Load Washer
Clothes smell musty
The big door seal is probably the problem. Put on gloves and using a solution of Laundry detregent and hot water and rags, carefully wipe clean all the folds of the seal. It will be icky. Next run a cycle with some detergent and oxyclean or bleach if you have it.
Especially during warm weather, damp clothing left in a front loader mildew slightly very quickly- you can't really see much but you can smell it! So get the clothes in to the dryer immediately. You'll want to relaunder the smelly clothing after you have cleaned the washer.
Good luck to you and Thank You using FiX YA!
Aug 19, 2008 | Kenmore 43052 Front Load Washer
Kenmore Series 90 Washer
Aside from complete disassembly & cleaning it, try a hot wash on full with nothing in it except a bunch of bleach.
Jan 09, 2008 | Kenmore 15864/15862 Top Load Washer
Smell in washer
What kind of smell is it?  If I can guess, I think it may be a musty or "locker-room" (sorry for bad memories) smell.  I have found that sometimes a change in detergent (or sometimes the same detergent you have been using for years) can cause build up and retain that musty smell.  I had to actually remove a inner basket completely and wash out both inner and outer drums to get rid of the funky smell.  She had used the same detergent for years.  Do you wash a lot of clothes in cold water?  This could also make the situation worse.  Try running a full empty load on hot with a bunch of bleach through the wash cycle, then stop the unit for a bit and let it soak and see if it clears up.  Also, try changing detergents and use a HE type soap.  HE causes very little sudding action, which in turn will stop the build up.  If this doesnt work, you may have to remove the inner tub and clean out both baskets (a lot of time, and need a special wrench, unless you know how to work it off).  Let me know if this helps any.   Jim
Oct 17, 2007 | Kenmore 24032\24036 Top Load Washer
Kenmore 24032\24036 Top Load Washer Logo
136 people viewed this question
Sal De
fordexpert
Jim Goldsmith
Jim Goldsmith
